Cmaxed Posted November 24, 2010 Share Posted November 24, 2010 Hi out there, Newbie here Im having trouble starting my 2004 2ltr diesel on cold mornings. I've tested the battery which is fine, and research on various forums has led me to try replacing the glow plug relay(Ford dealer recomendation). Typically, this is not as straight forward as i thought, because I can not find the glow plug relay on the car to replace it! So can any body point me in the right direction to 1: where the glow plug relay is on a CMAX 2004 tdci 2.0 2: a decent maintence manual similar to a haynes? look forward to your response! Quote Link to comment Share on other sites More sharing options...
tommy.h Posted November 24, 2010 Share Posted November 24, 2010 Hi Cmax it should be in the engine bay fuse box it is F6 & it is a GLOW PLUG CONTROL MADULE. should be third from the left 60AMP fuse. also bottom right number 14 is the ENGINE CONTROL RELAY. hope this helps tom Quote Link to comment Share on other sites More sharing options...
Cmaxed Posted November 25, 2010 Author Share Posted November 25, 2010 Thanks Tom. The relay I was given by dealer is a little black box/plug? Checking the engines box the two do mot seem compatible? Am I missing something? Quote Link to comment Share on other sites More sharing options...
tommy.h Posted November 25, 2010 Share Posted November 25, 2010 (edited) Hi Cmaxed find attached are these any good? tom Edited January 27, 2012 by stef123 Copy protected information removed Quote Link to comment Share on other sites More sharing options...
gixerwill Posted January 27, 2012 Share Posted January 27, 2012 Hi there just joined this forum today after finding the above post. I have the same problem trying to start the car. Always fires up on the second start. Mine is a 57 plate 2.0 Diesel. Also suspect Glow Plug Relay. Does anyone else or Cmaxed have an update on this? Can't find one online, are they only available direct from Ford. Any help appreciated :) Will Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 27, 2012 Share Posted January 27, 2012 Have you checked to make sure the plugs are getting 12v? Quote Link to comment Share on other sites More sharing options...
gixerwill Posted January 27, 2012 Share Posted January 27, 2012 Hi there I have not no. I'll need to get me a multimeter in the morning Thanks Quote Link to comment Share on other sites More sharing options...
