Traffic Alert (Ta) Volume +5 Minimum On 6000Cd
Hi, I have a 6000CD audio unit. I can increase the Traffic Alert (TA) volume from +5 & above, but not below +5.
Does anyone know if +5 is the minimum level ?
found this, however dont know what the base level is set at!
Traffic announcement
volume
Traffic announcements interrupt
normal broadcasts at a preset
minimum level that is usually louder
than normal listening volumes.
To adjust the preset volume on all
units except 2050:
• Press and hold the TA button.
• Use the volume control or, on
Sony units, the up/down arrow
buttons to make the necessary
adjustment. The display will show
the level selected.
To adjust the volume on 2050:
• When the traffic announcment is
broadcasting adjust the volume
using the volume up/down
buttons.
Ending traffic
announcements
The audio unit will return to normal
operation at the end of each traffic
announcement. To end the
announcement prematurely, press
TA during the announcement.
Note: If you press TA at any other
time it will switch all announcements
off
