big col Posted June 9, 2011 Share Posted June 9, 2011 HI EVERYONE, I AM NEW TO THE FORD FORUM,SO HELLO TO EVERYONE :) ...I HAVE A 1997 (P REG) FORD ESCORT 1.8 GHIA X (WITH THE ZETEC ENGINE)...I HAVE BEEN HAVING A PROBLEM WITH THE TEMPERATURE GUAGE ON THE DASHBOARD..IT RARELY MOVES AND NEVER GETS INTO THE "NORMAL", PART OF THE GUAGE, BUT IT IS MOVING SOMETIMES...I HAVE JUST HAD A NEW THERMOSTAT FITTED..MY MECHANIC SAID THAT IT MAY BE MY TEMP'SENSOR...I FITTED A NEW ONE YESTERDAY,THE GUAGE STILL SHOWS NO CHANGE...ANY IDEAS CHAPS? CHEERS COL Quote Link to comment Share on other sites More sharing options...
johnH Posted June 9, 2011 Share Posted June 9, 2011 hi, please dont use caps in your post...looks like your shouting and being rude. anyways as for your issue, carry out the dash trick (sticky on forum) and to see if your cluster is faulty Quote Link to comment Share on other sites More sharing options...
big col Posted June 10, 2011 Author Share Posted June 10, 2011 hi, please dont use caps in your post...looks like your shouting and being rude. anyways as for your issue, carry out the dash trick (sticky on forum) and to see if your cluster is faulty hi john, thanks for your reply...sorry about the caps, i genuinly had no idea it would come over that way...lower case in future. the dash trick?, never heard of it.i am no expert on cars, i have a very small knowledge,but not on this proceedure..could you explain a bit more please. col Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 10, 2011 Share Posted June 10, 2011 Take a look at the top thread in the Ford Focus Forums... thats the dash trick. Basically (this will reset your odometer) Switch ignition off, press and hold the reset button on button then turn the key to start engine. leave the button pressed in then the trip computer will go into self test mode. Review the thread here for more info Quote Link to comment Share on other sites More sharing options...
big col Posted June 10, 2011 Author Share Posted June 10, 2011 Take a look at the top thread in the Ford Focus Forums... thats the dash trick. Basically (this will reset your odometer) Switch ignition off, press and hold the reset button on button then turn the key to start engine. leave the button pressed in then the trip computer will go into self test mode. Review the thread here for more info hi jeebowhite, thanks for your reply....sounds simple enough, the trouble is, as my car is a 97 escort, it has no digital readouts anywhere on the dashboard. the odometer is the simpler "push-button" sort, one pushes the button in,and it reels the numbers round to zero again (i hope i have explained that clearly enough).the information only covers the digital aspect, would it work for my earlier version?. obviously,i dont want to call my mechanic if i can fix it myself. cheers jeebowhite col Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 10, 2011 Share Posted June 10, 2011 Should have really read that! - if you have the OBDII port (i know they werent standard around then) so you might be able to use an OBDII scanner, could well be a wiring issue, or faulty sensor, but its difficult to say with little diagnostics and being unable to see the car! It could even be a fault that has developed on the dial itself, from my understanding there is an electric reel that when heated the metal expands, and so the needle moves, so if their isnt a full connection, then it wont expand all the way! Quote Link to comment Share on other sites More sharing options...
big col Posted June 10, 2011 Author Share Posted June 10, 2011 Should have really read that! - if you have the OBDII port (i know they werent standard around then) so you might be able to use an OBDII scanner, could well be a wiring issue, or faulty sensor, but its difficult to say with little diagnostics and being unable to see the car! It could even be a fault that has developed on the dial itself, from my understanding there is an electric reel that when heated the metal expands, and so the needle moves, so if their isnt a full connection, then it wont expand all the way! yes..i was starting to think that it might be a wiring issue. the needle moves sometimes but never gets into the "normal", position..as you know, it could be a number of things...process of elimination huh. i have decided to get my mechanic in, obviously one cannot determine exactly what the problem is, without ascually seeing the vehicle etc. many thanks for your advice and help matey, i appreciate it thanks again col Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 10, 2011 Share Posted June 10, 2011 will be interesting to hear what the outcome is! hope its nothing too expensive! Quote Link to comment Share on other sites More sharing options...
big col Posted June 10, 2011 Author Share Posted June 10, 2011 will be interesting to hear what the outcome is! hope its nothing too expensive! i will keep you posted....hopefully my experience of the problem, may help others.and not be as expensive as i thought! haha cheers buddy col Quote Link to comment Share on other sites More sharing options...
