Wizz Posted March 23, 2012 Share Posted March 23, 2012 I had a drive-by the other day which damaged my side mirror.... I need to replace the side mirror body, because the edge was damaged.......but the glass remained intack. How do I remove the glass from the old body without breaking it........so I can put it in my replacement body ( which apparently is supplied sans glass ) Is there a recommended method of doing this ? Quote Link to comment Share on other sites More sharing options...
Preee Posted March 23, 2012 Share Posted March 23, 2012 Hiya Haynes manual states Remove trim on inside by where the tweeter is , undo the retaining , then starting at the top , pull the exterior mirror trim panel fromt he door , disconnect the wiring plug Unscrew the mirror mounting bolts , then release the clip and withdraw the mirror. mirror glass , pull the outer edge of the glass rearwards and inser a flat screw driver and gently prise the glass from the place and unclip the mirror and then remove the wiring from the mirror glass. hope this helps Quote Link to comment Share on other sites More sharing options...
