Ford Focus Windscreen Wiper Problem
Hi currently have problem with my windscreen wipers on my ford focus 1.6 zetec 05 ,when driving wipers just stopped working,
have checked motor this is ok,checked wiper stalk ok you can hear a clicking sound so must be sending signal(rear wipe and
washers are working fine) fuse ok,not 100% on relays but only two in fuse box in car and swapped these two but still not
working, anybody got any ideas ? cheers Paul
  • Quote
  • MultiQuote
  • Edit
I suspect, even though you are hearing a click, you are not triggering the actual microswitch correctly. I had this recently on my car, and I had the stalk replaced, as this also replaced the microprocessor.
Depending on your budget you could either buy the stalk from ford and have them fit it, self fit it, or take a chance by popping to a scrappie and getting one from a shunt / write off.
Have tried working stalk on still the same ,ford telling me its the multifunction fuse board £300+ GULP :(
I would take your car to a different dealer, its concerning that such a small problem is that cost! I cant say I agree immediately!!!
I had that. Water ingress on wiring loom. New gem/fuse box and 1 hr labour to programme it to the car.
Hi, Have you checked the wiper linkage? both my sons have focus,s and have had the same problem with the ball and socket parting company, if you can hear the motor turning this will be the problem, John
Hi Tommy had new gem/fuse fitted and programmed but kept blowing fuse, local garage stripped motor down cleaned etc now working ok for now, but interested to see where
water ingress was situated
Cheers John had checked these just turned out to be an expensive job :(
  • 3 weeks later...
just back on here after pc probs. Water ingress on mine was evident on a couple of pins on the largest connector. tbh, didn't look much, but the mechanics and the sparky seemed to know right away. Ingress through wiring loom by capillary action.
ford were meant to fit a revised panel to prevent water ingress to the wiper motor maybe you should call ford up and have it done it was recall work cant remenber the tsb number
http://www.warrantyguide.co.uk/vehicle-recall-EF182BEFEFA48C3E802570360044A568-ford-focus-and-focus-c-max-recall
http://www.warrantyg...us-c-max-recall
I have that done Arthur, the water ingerss was where the wiring loom comes throught he bulkhead, just in front of the fusebox/gem
  • 5 years later...
I have exactly the same problem , have checked fuses, relays and fitted another switch, everything else works, I do notice what sounds like a solenoid click from somewhere behind radio when I turn key in ignition.
Could it be a problem with ECU, I replaced this wit a rebuild about 6 months ago ( 2000miles)
Desperate for answer!!!!!
  • 2 years later...
Hi I’m having problems with my 2005 focus the stereo comes on when the car is turned off and locked it does it all the time and my wipes don’t work then all of a sudden they will come on then stop I’ve replaced the motor and arms but there still not working I had to put a new battery on a few weeks ago I have to disconnect my battery over night so the stereo doesn’t keep waking us up thanks
I am wondering if you have water and damp in the fuse box above the front passengers feet. Fuse box has tons of fuses and relays and cable plugs on it. I have heard of water getting in these. You can unplug it all and take it apart to see the circuit board inside which has computer chips etc on it.  I’m basing what i say on a 2008 mk2.5 but I thinks yours would be much the same.
More: focus mk2 is quite advanced for its age in respect of certain stuff being ‘computer’ controlled using ms-canbus and hs-canbus. Having had a load of problems with one of these cars, the more you look into the electrics , you will find it’s more complicated than you’d think
  • 3 months later...
I'm having the same problem. Rear wiper and front and rear washers work fine, but front wipers not budging. Checked fuse and that's fine. Unsure what to do now as my mechanical knowledge is poor. Was hoping to fix myself but looks like I'm off to the garage.
  • 1 year later...
Hi I've just come across the same problem and after spending days trawling the internet I stumbled on a website/video "Ask the Mechanic" they have their own website with loads of info. After researching and contacting them, my problem is the linking arm to the wiper arm had worn and dropped. They sell parts that can be easily fit by yourself with video instructions. Mine is a ford focus mk2 and the part cost £5.49 free postage. Hope this helps all who are struggling to resolve their issues. Not bad for a female novice eh 🙈
