Power Steering Fluid Leak - track Rod End
Hi Guys - Im new to this forum - this is my first post !
The problem i have is this: I have a N reg 1996 Mondeo - in January of this year the high pressure hose for the power steering ruptured and needed replacing. since then, i have noticed a small leak on coming from the front left wheel. recently that leak has become worse. Over the last week i have noticed that when i turn my wheel there is a 'screeching' noise coming from the steering - my power steering fluid thingy was completely empty- so i topped it up. in the last 7 days i have had to put over 1ltr of power steering fluid into the car - the fluid appears to be leaking quite badly - looking under the car it looks like it is coming from the track rods (please see pic attached)!
any suggestions on what this could be? is it expensive to repair?
Thanks guys.
tracy
Thanks guys.
tracy
The leak is from the rack gator, which shows you have an internal leak from the rack which is by-passing the gator, if you can pull it back and look closer would be an advanatge. You can buy the tie rods but looks more like a rack job.
On closer inspection of the gaitor - it appears that the metal clip on the end is missing - the gaistor is simple held in position with a plastic wheel-tie used to keep wheel trims on! Im wondering whether the garage had put this in place when they replaced the high pressure hose for the power steering in January of this year - as it has only really been leaking since that initial repair!
Thanks guys.
the noise that your getting is because steering fluid is low and air this in the steering pump, the noise will stop when you top up
