wheel is red hot
The rear wheel on my mondeo has started to give of a smell like a burning clutch and the wheel gets so hot you cant touch it
could it be the break binding or the worst case the wheel bearing burning out :blink:
the guy said on its MOT it will need new pads and discs soon and feeling the disc it is worn around 2mm out of it
cheers
it is most likely a binding caliper that requires cleaning and some copper grease, try jacking the car up and spinning the wheel by hand to find the extent of the binding, also check for play at the bearing.
thanx m8
others on another forum have said the same stickiy piston
its getting booked in for a disc and pad change so i will let them clean it out
had 2 new discs and pads fitted the caliper was fooked so needed replacing
the guy even broke his tool
