Water in my door!!!!
I've got a mk6 Fiesta facelift, and after a heavy down pour of rain about a litre of water flowed out of my door! Is this a warrenty job or is it something easy to fix? :huh:
check under the door to see if you have front drain holes, on some fiestas ford forgot to drill the holes at manufactor. if you have not got any get on to ford customer services on 0845 841 1111.
Thanks, the drain plugs must be blocked then because there are two of them. I didn't think that much water should get inside my door though.
you should have three drain holes (slots) in your door front middle and back. all window seals will let in some water if you think yours is excessive the seals could be worn.
