ford escort Nreg - LOST KEY
h everyonei,
ive recently lost my key to my escort and dont have a spare key. I have managed to dis-engage the steering lock and i am able to turn the ignition wit a tool in the black ignition switch. basically i need to by pass the immobiliser and dont know quit where to start...
anyone pointers would be great,
Andyp
  • 1 month later...
right a bit of a fiddly job but rip off the steering column casing and remove the ingition barrel if possible ill check go to a good scrap yard get a new ignition barrel and ecu with the key change the ecu over and attatch the new barrel to it the chip under the red section of the key is unique to the ecu adn the engine will not start until the immobiliser chip matches with that ecu and if possible get the door barrels too then it doesnt look too suspicious if you sell the car on. that or go and talk to a ford garage and see what they can do ill talk to a few people i know down at my local garage and see if they can give you some more pointers
good luck
pete
