geordieric Posted December 30, 2009 Share Posted December 30, 2009 hope anyone can help. have had a fault light checked at my local garage near work has come up with the following. fuel/ignition code p0420 efficency below threshold bank1. have put new ht leads on as seemed to be a stutter/misfire which new leads has got rid of stutter. was thinking airflow meter in or one/both of the lambdas but on a budget so trying to avoid randomnly getting sensors and hoping. seems to be a possible sucking sound from the engine, easiest heard with bonnet shut, sounds like suckin in a constant pinging kind of way as in noise, i can sort most things but need a pointer from some pro's. have been told to chanhe oxy sensers but will it not be something that is causing the sensor not the actual sensor?? cheers Richie Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 30, 2009 Share Posted December 30, 2009 if you can hear a sucking sound you should check all the vacuum pipes for leaks. Quote Link to comment Share on other sites More sharing options...
geordieric Posted December 30, 2009 Author Share Posted December 30, 2009 if you can hear a sucking sound you should check all the vacuum pipes for leaks. had a quick look but couldnt see anythin. will have a closer look if the weather ever gets above freezin? cheers Quote Link to comment Share on other sites More sharing options...
