Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88
  1. Leaking Clutch Fluid (10 )
  2. Code For Radio (1 )
  3. Temp Guage Fault 1.6 Focus Automatic 2004 (4 )
  4. Spray Sound On Ignition (5 )
  5. Air Vents 1.8 Tdci (4 )
  6. Rs Series 1 Focus (0 )
  7. Ken Block's Fiesta Rs Wrc (1 )
  8. Focus Central Locking Prob (1 )
  9. Water Leak (1 )
  10. Focus 1.8Tdci Dtc (1 )
  11. Advice Needed (3 )
  12. Smashed Rear Fog Lamp Focus 2007 Current Shape (3 )
  13. Help With Roof Bars !! (1 )
  14. Fronting Car Insurance "should I"?? (5 )
  15. Ford Focus 2003 Model With New Radio's (1 )
  16. Focus Elle + 0 Ncb + Only Just Passed (7 )
  17. Focus Drivers Handbook (11 )
  18. Turbo Failure? (7 )
  19. 1.8 Tdci Mods And Foc Stickers (1 )
  20. Xenon Lights (1 )
  21. Some Advice Needed From New Member (1 )
  22. Oil For 2008 Focus 1.8 Tdci (1 )
  23. Water Leak (0 )
  24. Oem Suspension (1 )
  25. Gradual Loss Of Mpg (10 )
  26. Focus Induction Kit Problem (2 )
  27. Dash Board Problem (2 )
  28. Ford Focus 2008 (1.8 Petrol) (6 )
  29. Headlight Brightness - Focus Mk1 1999 1.8 Zetec (8 )
  30. Reverse Doesnt Go In Properly (8 )
  31. Cam Belt Intervals (26 )
  32. Dual Mass Flywheels Or Not (4 )
  33. Clutch Return Spring ? (3 )
  34. Help Needed (1 )
  35. Pollen Filter Cockup On Mk2 Focus (5 )
  36. Focus Bluetooth & Voice Control Stopped Working (1 )
  37. 2006 Tdci Rear Wiper (1 )
  38. Ford Focus T Plate 1.8 (1 )
  39. Mk1 Focus Fuses (7 )
  40. Dmf Replacement (8 )
  41. Heated Seats Ford Focus 52 Plate (0 )
  42. Koni Fsd Vs Koni Sport (0 )
  43. Goodbye Ford Hello Mazda (8 )
  44. Help 0.4Amps Draining My Battery (2 )
  45. Luggage compartment open (3 )
  46. Ford Focus Tddi (1 )
  47. 04' Focus Screenwashers Not Working (28 )
  48. Is This Correct (5 )
  49. Mk1 Air Bag Compatibility (Large/small Bagde) (0 )
  50. Ford Focus Titanium 1.8 Petrol 2008 (4 )
  51. I Hate Squeaks And Rattles. (0 )
  52. Fuel Filter (4 )
  53. Strange Acceleration (0 )
  54. Creaking Noise (3 )
  55. Ford Focus Mk1.5 1.8 Tdci (7 )
  56. Fitting Fogs And Switch (2 )
  57. New Focus 1.6 Zetec S (6 )
  58. Oil Leak - Help (0 )
  59. Thottle Problem - Help! (2 )
  60. Focus 1.8 Tddi Gearbox Noise (3 )
  61. Gear Stick Not Returning To Centre (1 )
  62. Drivers Door (11 )
  63. Starts Then Stops (1 )
  64. Just One Heater Vent Not Blowing On Focus (7 )
  65. Water Drip (7 )
  66. Engine System Fault - Please Help :/ (2 )
  67. Brake Disc Life (6 )
  68. Aux Input (1 )
  69. Loud Ticking Sound From Engine..... (4 )
  70. Focus Speedo (3 )
  71. Passenger Footwell Leaking Badly (7 )
  72. Focus Test Drive - Engine Warning Light (2 )
  73. Rear Alloys Bonded To Sub Axle 'top Tip' (2 )
  74. Key Programe (5 )
  75. Weirdest Electrical Problem I've Seen (2 )
  76. How To Make Your Ca Shine? (1 )
  77. Focus1.8 Idle Dipping 07 Plate (3 )
  78. Retro Fit Climate Control (3 )
  79. Check Engine Light Again (11 )
  80. 18Tdi Economy (11 )
  81. 2010 Model 1.8 Petrol. Awful Fuel Consumption (17 )
  82. Top Tip Spacesaver Spare Wheel (1 )
  83. Pothole Damage To Alloy Wheel (2 )
  84. Yellow Headlights (9 )
  85. Focus Diesel Poor MPG (4 )
  86. Wing Mirror Multiplug (0 )
  87. Boot Seat Conversion (9 )
  88. Question Re: Spec (3 )
  89. Question About Ford Warranty/service Schedule (7 )
  90. Noisy Brakes (8 )
  91. Buggered My Mirror (1 )
  92. Anti Roll Bar Bushes (2 )
  93. Aftermarket Alarm For Fiesta Mk7 (0 )
  94. Advice (0 )
  95. Glow Lamp Stays On Too Long (3 )
  96. Should Used Car Dealer Top Up Dpf Additive? (2 )
  97. Bit Of Advice Please (5 )
  98. 2005 1.6TDCI injector removal/re-sealing (2 )
  99. Is Haynes Manual Right (2 )
  100. Steel Wheels Compatability (8 )
  101. 1.6 Focus Overpressurising (0 )
  102. A Wheel Pain In The ... (13 )
  103. Trip Computer (0 )
  104. Advice... (5 )
  105. Poor Idle (4 )
  106. Condensation (14 )
  107. Ford Focus 2.0 Ghia (7 )
  108. Ford Focus Rs (2 )
  109. Steering Groan (8 )
  110. Help-Does Stabilizer Link For Mazda3 Fit A Ford Focus (0 )
  111. Access Rear Of Dashboard (0 )
  112. Recaro Seats In Mk7 Fiestas (1 )
  113. How Can I Remove My Rear Number Plate? Screws Wont Work. ! (3 )
  114. 1.6 Lx Mkii (6 )
  115. Focus Daytime Running Lights (2 )
  116. Weak Points When You Drive Your Focus Over A Roundabout (5 )
  117. Replacement Ceys (12 )
  118. Transmission Fluid, Gear Box Problem??? :-( (2 )
  119. Transmission Fluid (4 )
  120. Not A I've Just Recently Bought A Ford And It's Been A Now't But Trouble Purchase (11 )
  121. Headlight Bulb (5 )
  122. Alternator Renewal - Is This Easy (1 )
  123. Focus Oil Consump (6 )
  124. Weird Noises From The Rear (1 )
  125. Weird Noises From The Rear (0 )
  126. Intermittent Strange Problem! Please Help (15 )
  127. 98 1.6 Focus Non Start (3 )
  128. 2006 Focus 1.6 Fuel Pump Help? (4 )
  129. Ford Focus 2.0 Tdci Diesel Review (1 )
  130. Ford Focus Coupé On Its Way (0 )
  131. 1.6 Tdci Injector Seals (0 )
  132. Part Of Dial Not Lighting Up (5 )
  133. Focus Zetec Auto (2 )
  134. No Exhaust Tone?! (4 )
  135. Induction Kit (0 )
  136. Semiconductor Diode Pack - Where Do I Get It From And How Much (1 )
  137. Fitting A Sub (0 )
  138. For Sale (0 )
  139. Poorly T Plate 1.8Tdi/tddi Focus (4 )
  140. 3 Times Fuel Consumption - Please Help!! (8 )
  141. Error Codes And Gearbox Clunk? (2 )
  142. Flashing Red Light (0 )
  143. Mk2.5 Focus 1.8 TDCi Diesel - problems problems... (6 )
  144. Grumbling Noise In First With Feet Off The Pedals (2 )
  145. Problem Fitting Rubber Exhaust Mount (2 )
  146. My Focus Has No Power And Shuters (2 )
  147. Ford Focus 1.6 Cl Estate Cluster Problem??? Help!! (10 )
  148. Ford Focus Locking Problem (0 )
  149. New Owner With A Few Q's :) (5 )
  150. Electric Windscreen Problem (4 )
Full Colour Version: Ford Focus Club
