Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86
  1. Focus Breakdown 1.8Dti 2000 (6 )
  2. Focus Dash Pod Replaced - Similar Fault Still There (4 )
  3. Focus Zetec 2009 gear knob (7 )
  4. 6000Cd Player.....anyone With One? (7 )
  5. My Focus (2 )
  6. Do's And Don'ts Of Diesels (9 )
  7. Need Help With Led's And Wiring... (1 )
  8. Focus Mk2 Trim (5 )
  9. 2.0 Tdci (19 )
  10. 59 Plate Zetec Door Panels (6 )
  11. Footwell Lights (17 )
  12. Dtc Codes (17 )
  13. Bolt Seized In Bush (11 )
  14. How Do I Do It ??? (9 )
  15. Focus Replacement Key (1 )
  16. Radio Code (4 )
  17. Rear Door Card Removal. (7 )
  18. Ford Focus Trip Computer (1 )
  19. Help!! Crankshaft Sensor (2 )
  20. Bulb Fitments (2 )
  21. Overheating (2 )
  22. Door Wont Open From Inside Or Out, And I've The Card Off! :( Help, Please! (6 )
  23. Heated Windscreen Issues (3 )
  24. Replacing Dipped Bulbs (5 )
  25. Rubbish Pull Away (15 )
  26. Ford Focus 56 Plate Stone Chip Problems (25 )
  27. st170 clutch probelms? (3 )
  28. 1.8 03 Focus High Rev Noise (6 )
  29. Error P0234 - Engine Overboost Condition (0 )
  30. Fog Lamp Kit (7 )
  31. Where Is My Maf??? (1 )
  32. What Options And Equipement Should I Get With My Ford Focus Zetec (9 )
  33. 1.6 Zetec Grey Smoke (13 )
  34. Ford Focus Tddi (6 )
  35. Steering Wheels (2 )
  36. Electrical Diagram (3 )
  37. Replacement Headlights (3 )
  38. Focus 1.8 Petrol Clutch Problems (7 )
  39. Which Cd Player Do I Need?? (6 )
  40. Keys For Ford Focus Zetec (5 )
  41. Focus 1.6 Conversion (9 )
  42. Got Me Stumped (5 )
  43. 09 Focus Front/Rear Park Sensors drilling location required (7 )
  44. Squeaky Gearshift (0 )
  45. Windows Misting Up (4 )
  46. Speedo Drive (4 )
  47. Air Filter (9 )
  48. Conversion Questions (3 )
  49. Glow Plug Warning Light Flashes (1 )
  50. Vacuum Horse (1 )
  51. Ford Focus (32 )
  52. Mk1 Front Mud Flaps (2 )
  53. De-Badging Driver's Door On Mk1. (2 )
  54. Ghia Map Lights (2 )
  55. Oil (5 )
  56. Ford Focus 3Dr Roof Rails (0 )
  57. Tddi (1 )
  58. Windows Down On Their Own (3 )
  59. Focus Mk1 1.6 Or 1.8 (7 )
  60. Focus Mk1.5 Seat Belt Issue. (7 )
  61. Focus 1.6 (7 )
  62. St170 (0 )
  63. Thought Id Share This With You Guys (4 )
  64. Help Choosing Aftermarket Headlights (12 )
  65. Low Pitch Thudding Noise From Rear Passenger Wheel (1 )
  66. Phone Compatability ? (8 )
  67. Blower Come On But Weak Air Flow (1 )
  68. St170 Instrument Cluster Fault (1 )
  69. Exhaust And Coil Pack (5 )
  70. Mud Flaps (14 )
  71. Focus Mk1 (19 )
  72. Focus Reviews (12 )
  73. Focus - Which Oil (6 )
  74. Foc Stickers (1 )
  75. Heater Problems After Heater Matrix Change On Mkii (4 )
  76. Sony Wiring Harness & A Focus Mk1 (2 )
  77. Heater Failure (6 )
  78. Unlocking (9 )
  79. Confused If The Buy Alloys Or Steel (8 )
  80. Focus 06 Water Leak (4 )
  81. 2001 Tdci Ford Focus Paint Code Help (7 )
  82. 18" Wheels (2 )
  83. Windscreen Demister (27 )
  84. Every Single Year! (2 )
  85. New Focus (10 )
  86. Both Dipped Headlights Out (6 )
  87. Finally Picked Up My Focus Today ... (33 )
  88. Focus 1.4 16V Zetec S (0 )
  89. Diy Full Service (5 )
  90. Focus Noise/vibration (0 )
  91. Ford Focus 1.6 Zetec S Engine Problems (3 )
  92. Cd Player Upgrade (2 )
  93. Excessive Engine Noise When Under Load? (7 )
  94. A Few Problems (16 )
  95. Injector Plug Case (0 )
  96. Interior Leds (7 )
  97. Focus 2.0I Zetec Esp Engine Problems (3 )
  98. Stuck In Gear, Gearstick All Floppy (14 )
  99. A Few Problems (1 )
  100. Ford Focus Problem (Again) Engine Sounding & Feeling Rough (5 )
  101. Aux Belt Tensioner - Focus St170 (1 )
  102. Beam Deflector Mk2 Focus (3 )
  103. After New Main Battery In Car Voice/bluetooth/phone Gone (1 )
  104. Mk1 Focus Side Mirror Covers. (5 )
  105. Reversing Camera (1 )
  106. Wet Or Dry Sleeves (0 )
  107. Trip Computer (41 )
  108. Suspension (0 )
  109. How Much Should I Expect? (2 )
  110. 2006 Ford Focus 1.6Tdci Seat Change Over (2 )
  111. Bumper And Badge Help (6 )
  112. Focus Tdci Wont Start (4 )
  113. Focus (0 )
  114. Ecu Remapping Petrol Engine (1 )
  115. Crank Sensor And Ecu (0 )
  116. Ford Focus Keys (1 )
  117. Would You Buy A Car That Has Already Done 150'000 Miles? (16 )
  118. Tow Bars (9 )
  119. Have I Found A Concealed Button? (6 )
  120. 1999 Ford Focus 1.8 Tddi (4 )
  121. Help (14 )
  122. St170 Instrument Cluster "earth" (0 )
  123. Front Dimister (6 )
  124. Which Multispoke? (2 )
  125. Lower Arms And Ball Joints (10 )
  126. Flickering Lights (2 )
  127. Stereo. Am Interference On Acceleration (9 )
  128. Focus 2006 Steel Wheels. (6 )
  129. Front Mud Flaps (11 )
  130. Noisy, Smelly Cat On Focus St170 (4 )
  131. Engine 'lumpy' Lacking Power (4 )
  132. St170 Leather Seat Repair (2 )
  133. Erratic Revs When Cold With Added Whining Noise! (6 )
  134. Low Idle On 1.6 (6 )
  135. Under Bonnet Insulation (8 )
  136. Bonnet Adjustment (5 )
  137. Erratic Revving On 1999 Focus (8 )
  138. Using Oil (12 )
  139. Which Remote Key? (3 )
  140. Power Steering (3 )
  141. "open Door" Warning Light (4 )
  142. Radio Interference (1 )
  143. Loss Of Power? (1 )
  144. Central Locking Gremiln (4 )
  145. Mk1 Thermostat Housing Retrofit... (1 )
  146. How To Replace The Arb Drop Link Rod (7 )
  147. Cat-Back (11 )
  148. Stereo Problem!!! (6 )
  149. No Sound From 'woofers (9 )
  150. Servicing (18 )
Full Colour Version: Ford Focus Club
