Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88
  1. Sluggish TDCi 1.8 (3 )
  2. Cough Cough (3 )
  3. Manual Aircon To Climate Control. (0 )
  4. Sat Nav (4 )
  5. Compression Ratio (3 )
  6. Front Lights On When I Brake (26 )
  7. Focus 1.6ltr poor mpg (61 )
  8. Esp Help (7 )
  9. Mk1 Spare Wheel (10 )
  10. Random Stalling When Braking (3 )
  11. 2001 Focus Tddi Engine Mangerment Light (1 )
  12. Fitting Drl (1 )
  13. Rattle (1 )
  14. Diff Bearing Gone? (0 )
  15. Focus Tyres (2 )
  16. Ford Focus X Reg 1.8 Ghia Clutch Problem (4 )
  17. Detachable Tow Bars (2 )
  18. Focus 55 - trip computer choices missing (11 )
  19. Mot Day (4 )
  20. Starter Motor (5 )
  21. Plastic Footwell Trim? (4 )
  22. Newbie Questions (0 )
  23. Focus 1.8 03 Model Gearboxes (1 )
  24. Misfire? (4 )
  25. Ford Focus Rs - Full Wrc Decals. (0 )
  26. Parking Sensors (6 )
  27. Fuel Filter (6 )
  28. Focus Bonnet Issue (1 )
  29. 1.8 Tdci (3 )
  30. Bhp (6 )
  31. Strange Unknown Fault Codes (5 )
  32. Focus Steering Centre Rattle (2 )
  33. Steering Rack Boot/gaiter (0 )
  34. Help Speedometer Stops Working Then The Car Stalls What May Be The Problem (1 )
  35. Warning Light (19 )
  36. Looking To Buy A 2Nd Hand Ford Focus (23 )
  37. Will 6006E Fit My 2000My Foucus? (1 )
  38. Will They Mend It? (1 )
  39. Differences (7 )
  40. Climate Control Backlight (2 )
  41. Anyone Ever Done A Clutch On A 1.6 Focus Mk1? (0 )
  42. Drums To Disks (12 )
  43. Low Idle Speed When Warm?? (1 )
  44. Delayed Acceleration (18 )
  45. Cable Or Drive By Wire?? (3 )
  46. Thinking About Buying A St170 Conversion (3 )
  47. Driver's Side Lecky Window (4 )
  48. Blower/fan (4 )
  49. Brake Help (21 )
  50. Dahsboard Light Dimmer Switch (9 )
  51. Crap Brakes (17 )
  52. Auto Lock On Doors (9 )
  53. Engine Racing During Gear Change (1 )
  54. Throttle Surge 2009 1.6 Tdci Normal? (1 )
  55. Engine Light On, Burning Smell, Imrc Stuck Open? (1 )
  56. Replacement Rubber Seals? (5 )
  57. Isofix Not Installed On 57 Plate (1 )
  58. 1.6 Zetec Problems In 2Nd & 3Rd Gears?!?! (0 )
  59. Radio Code Needed Please (2 )
  60. Genuine Ford 12N Dedicated Wiring Kit (0 )
  61. Are These Tyres A Good Choice (17 )
  62. Radio Code (2 )
  63. Erratic Idle, Stalling And Lack Of Power (5 )
  64. Car Park Dent Removal (3 )
  65. Blown Turbo On 2003 Focus Tdci 100Bhp (1 )
  66. Which Cleaner Is Best To Be Poured Down In The Tank? (9 )
  67. Alarm System (0 )
  68. Interim Oil Change And Warranty Implications (6 )
  69. Help......can't Fill Up....... (3 )
  70. Focus 1998 Road Test (5 )
  71. Kwik Fit Air Con Recharge. (1 )
  72. Low Revs (4 )
  73. Bluetooth (2 )
  74. Re-Progam Key Fob Problems (12 )
  75. Installing A Tom Tom Hidden Cable (2 )
  76. Focus Diesel Fuel Cap Lose? (0 )
  77. Focustddi (6 )
  78. Belt Or Chain On The 1.8L Petrol (56Reg) (9 )
  79. Install Rear Parking Sensors (8 )
  80. 2006 1.6Tdci Cambelt Change (9 )
  81. Accessory Belt Tensioner (8 )
  82. Stripes On My Focus (3 )
  83. The Dreaded Mot (9 )
  84. Engine Swop....? (4 )
  85. Focus Mk1 Body Trim (4 )
  86. Focus Mk1 Body Trim (0 )
  87. Focus Mk1 (3 )
  88. Mountune Performance (27 )
  89. Focus Passenger Door - Won't Open! (6 )
  90. Chips (5 )
  91. Throttle Response On 1.8 Tdci (2 )
  92. Footwell Lights (3 )
  93. Number Plate Lights Not Working On Side Light (3 )
  94. Condensation In Rear Light Cluster (7 )
  95. Mk1 Rear Drum Stub Axle Bolts (2 )
  96. Noise From 1.6 Petrol (6 )
  97. Speed Mph At Odds With My Tomtom Indicated Mph (27 )
  98. Squawking Brakes (14 )
  99. Spare Key Fobs (2 )
  100. Turbo Pipe (3 )
  101. 18 Tdci Noise?? (2 )
  102. Roof Rail Bolts Replacement (1 )
  103. 1.8 V 2.0 (2 )
  104. Mobile Phone / Car Tracker (0 )
  105. Focus Zetec S Mudflaps (5 )
  106. Heated Front Windscreen (2 )
  107. Rear Wiper...poss Bad Earth? (6 )
  108. Clutch Problem With Rental Car (1 )
  109. Silver Dash Trim Peice (11 )
  110. Loving My Car (1 )
  111. Facelift Focus Stereo In Mk2? (4 )
  112. Crashed My Focus (19 )
  113. Engine Noise After Shutdown (4 )
  114. Mk2 Rear Courtesy Light (6 )
  115. 2004 Focus Front Suspension Noise (7 )
  116. Irritating Noise From 1.8Tddi Estate ... (5 )
  117. Focus 2.0 Tdci Issue (9 )
  118. Oil In Air Filter Hose (0 )
  119. Central Locking Motor Removal Tutorial Needed (1 )
  120. Satnavs & Heated Screens (14 )
  121. Mk 2.5 Rear Lights (5 )
  122. Fitting Leds? Read First (0 )
  123. Replacing Tie Rod End Boots With Or With Out Grease (6 )
  124. Fse Boost Valves (1 )
  125. Fuel Gauge Not Working (2 )
  126. Blower Direction Problem (0 )
  127. Focus Mk1 Key...price? (3 )
  128. 6000 Cd (2 )
  129. Gear Knob + Handbrake Questions (8 )
  130. Dashboard Indicators & Heated Front Windscreen Problems (3 )
  131. Buying A Used Ford Focus (4 )
  132. Focus Front Wheel Bearing (5 )
  133. Where Do I Wire/ Tap In A Charger For Tom Tom Fixed Installation (5 )
  134. Trouble Starting. (2 )
  135. Ford Focus Adaptive Headlight Not 'adapting' (8 )
  136. Have I Lost My Nut?? (13 )
  137. Focus Diesel Engine Same As Mondeo? (7 )
  138. Focus Zetec Boot Won't Open (1 )
  139. 17" 7 Spoke 4 Stud Alloy (1 )
  140. Reverse Light - Change Bulb (3 )
  141. Ford Focus Mk2 (Uk) Temp Problems (1 )
  142. New Focus - diesel vs. petrol (13 )
  143. Engine Cuts Out :s (3 )
  144. Clutch Problem (9 )
  145. Cambelt Replacement (4 )
  146. Traction Control Light (2 )
  147. Stupid Suspension (11 )
  148. Focus Mk1 (0 )
  149. Headlight Lamp Change On 03 Plate (5 )
  150. Focus Breakdown 1.8Dti 2000 (6 )
Full Colour Version: Ford Focus Club
