Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88
  1. Grinding Noise On Passenger Side Front (6 )
  2. Coolant Leak - Head Gasket Or Less Serious...? (7 )
  3. 1.6 Focus Petrol Warm (1 )
  4. Broken Key Fob? (3 )
  5. Wheel Nut Size? (3 )
  6. Reverse Switch Mk2 Focus (2 )
  7. Position Of Egr On 2008 2.0 Tdci (16 )
  8. Mk1 Key To Flip Key (15 )
  9. Focus 1.8Tdci - Wooshing Noise When Accelerating (22 )
  10. How To Remove Rear Indicator Bulb Holder? (7 )
  11. Focus Cc Rear Window Fault Cured And Roof (0 )
  12. Ford Focus 08 Key Fob (3 )
  13. Fuel Filter...1.8 Petrol Mk2.5 (16 )
  14. Rear Parking Sensors (24 )
  15. Dash Storage Box (3 )
  16. Where Do I Stand (6 )
  17. Electric Window Fault (20 )
  18. Grinding Noise On Take Off (5 )
  19. Engine Malfunction Warning Message (18 )
  20. Accelerator Lacking Progression (2 )
  21. Window Mind Of Its Own (20 )
  22. Thule Roof Bars On Focus (0 )
  23. Usb Playback (3 )
  24. Headlight Wire (0 )
  25. 52 Plate Focus Engine Swap (1 )
  26. Oily Smell - 1.8 Tdci (8 )
  27. Focus Zetec S Mpg? (28 )
  28. Focus 2Nd Hand Gem? (11 )
  29. Power Steering Bolt Leaking................... (6 )
  30. Focus 1.6 Zetec Electrical Problem (11 )
  31. 14 Plate Focus Wing Mirror Replacement Parts - Help! (4 )
  32. Possible New Clutch � (3 )
  33. No Boost After Blanking Egr (0 )
  34. 2009 Focus 1.8 Tdci Duratourq (2 )
  35. Radio Stalk Not Working. (6 )
  36. Helllllllpp !!!!!! (7 )
  37. Test Driving 2007/8 Mk2 Or 2.5 Focus 1.8 Zetec Climate Help/advice (4 )
  38. Mk Ii Alarm Issues (0 )
  39. Engine Swap Diesel To Petrol (49 )
  40. 2.0 Throttle Body To 1.8Tddi Zetec (5 )
  41. Scraping Noise (1 )
  42. Problem Starting When Hot (2 )
  43. 1.8Tdci - Where To Put The Egr Blank? (3 )
  44. Revs Sticking (2 )
  45. New Exhaust System Or New Car! (26 )
  46. Focus Non Starter (3 )
  47. Sensor In The Boot On A Mk2.5 (6 )
  48. More Power (6 )
  49. Mk1 1.6 Manifold/cat (0 )
  50. Mk1 Ford Focus Rear Fog Light Not Working (0 )
  51. Mk1 Ford Focus Rear Fog Light Not Working (0 )
  52. K&n Panel Air Filter (7 )
  53. Coolant Leak From Joint In Engine.. Help !!! (2 )
  54. Revo Remap (0 )
  55. Focus Mk2: What Is This "deflector"? (2 )
  56. Very Noisy Inside Focus (12 )
  57. Mk1 Focus Tddi Back Box Mod (3 )
  58. Bulb Problems (10 )
  59. Focus Titanum 1,6 Tdci 2008 Eberspacher Heater (20 )
  60. 3000 Revs Juddering ?? Tdci 1.8 (0 )
  61. Ive Got Rust At The Top Of Hatch I Believe This A Common Fault/ Any Solutions (0 )
  62. Dash Light (2 )
  63. What Would Happen If.. (1 )
  64. Limp Mode Before Turning Engine On (1 )
  65. Zetec 1.6 100 Noisy (5 )
  66. Where Can I Get One Of These (6 )
  67. Focus 1.8 Tdci Engine Fire (11 )
  68. 2011 Focus Titanium 1.6 Tdci (0 )
  69. 1.8Tdci Ghia 2004 Dmf (1 )
  70. 2007 1.8Tdci P0489 Throttle Peddle Disables (4 )
  71. Focus Mk1 Clicking Noise (6 )
  72. Ford Focus Edge 1.8 (04) Revive Or Dead? (8 )
  73. 2008 Focus Tsb (6 )
  74. Soundproofing In The Mk2.5....... (5 )
  75. Gel Overlays.. (2 )
  76. Td 115 Glow Plug Melt Down Help! (17 )
  77. Electric Windows Not Working (5 )
  78. Clicks And Knocks After Front Bearing Replacement (8 )
  79. New Battery: Over Capacity And Cca An Issue? (2 )
  80. Flip Key Reprogram (17 )
  81. Best Tyres ? (18 )
  82. Mk1 Focus Seats, Removed Air Bag Seats And Put Leather Heated Seats In (4 )
  83. Software Update/ Module Update (4 )
  84. Rear Window Collecting Water (7 )
  85. Redex Fuel System Cleaner???? Any Good???? (20 )
  86. Wheel Nuts (11 )
  87. 1.8 Petrol Duratec He Mk2.5 Hesitation Issue? (12 )
  88. Irish Meet August 2014 (227 )
  89. Has My Turbo Gone? (9 )
  90. Is This Normal Of An Egr Blank? (0 )
  91. Egr Blanking Plate (131 )
  92. Daytime Running Lights On A Focus 58 Plate? (6 )
  93. Uo118 Fault Code (3 )
  94. Window Uv Filtering (3 )
  95. Mk1 Sometimes Will Not Start (Had Much Work Done) (2 )
  96. 2.0 Tdci Focus Juddering Only On Full Throttle, Only Between 1800-2100Rpm (25 )
  97. Flip Key (5 )
  98. Loss Of Power In My Mk1 Ford Focus (5 )
  99. Egr Valve No Clicking Sound After Engine Turned Off (7 )
  100. Drl Insurance Situation (10 )
  101. New Headunit, Patch Lead Problems? (3 )
  102. Disconnected Wire?? (13 )
  103. Had New Brake Disks And Pads, Does This Look Right? (7 )
  104. 2007 1.6 Tdci Engine Vibration, Low Torque And More (3 )
  105. Why Is Only One Of My Self Levelling Focus St 2.5 Head Lights Not Adjusting?? (4 )
  106. Genuine Ford Focus Coil Pack. Great Price (4 )
  107. Owners Manual (5 )
  108. Show Us Your Mk3 (7 )
  109. Are Focus Mk2 Engine Fuse Boxes Interchangeable? (0 )
  110. Quick Question On Led Circuit (9 )
  111. Does My Car Have Remote Central Locking (2 )
  112. 2006 1.8Tdci Dmf Being Changed This Weekend (14 )
  113. Small Styling Mod To Front Grille (11 )
  114. Possible Dash Lighting Mod... (20 )
  115. Mk3 Focus Headlamp Bulbs (1 )
  116. New Injector (4 )
  117. Ford Focus 2003 Door Light (2 )
  118. Urgent! - Turbo Help Required. (15 )
  119. Glow Plugs Replaced. (9 )
  120. Transmission Fault (14 )
  121. L.e.d Daytime Lights (13 )
  122. New Member (3 )
  123. Focus Mk3 Tech Advice Needed (1 )
  124. 2004 Focus Mk1 Edge - Is My Gearbox Weird? (1 )
  125. Focus Mk1 2001 1.8Tddi, Can You Make It Sound Sporty (6 )
  126. Tuning On A Tight Budget (4 )
  127. A Few Personal Touches. (4 )
  128. Car Book In For Terraclean Service... Excited! (45 )
  129. P2008 Code Help Please (5 )
  130. Wanting A Mk1 (2001) Focus 1.8Tddi Super Chip (4 )
  131. A/c Condensation Drain Pipe (4 )
  132. 59 Ford Focus Tdci - Noise Problem (0 )
  133. Focus 2005 Mk2 1.8Tdci With Egr Valve Fault! (7 )
  134. Focus '06 1.8Tdci - Ems Problem (4 )
  135. A-Pillar Trim Clips (10 )
  136. 1.8 Tdci Focus Egr Valve (19 )
  137. Focus Mk3 Oem Ford (Nolden) Drl Fitting Instructions (0 )
  138. Need Help On Rear Doors (0 )
  139. Phone And Sony Head Unit (2 )
  140. Dashbord Problems (6 )
  141. Problem With Transmission/alternator? (0 )
  142. Lost All Electrics & Stalled: Any Ideas? (2 )
  143. Headlights (0 )
  144. Cabin Filter Replaced. (10 )
  145. Fiesta Alternator On Focus. 3Pin To 2Pin Battery Light. (0 )
  146. Fog Lights To Drl (30 )
  147. Gotcha! (3 )
  148. Focus Mk2.5 Electric Steering Problem (0 )
  149. Fault Code C1288 Abs Pump (2 )
  150. Car Seat Cover? (3 )
Full Colour Version: Ford Focus Club
