Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53
  1. Ford Focus Mk2 Bixenon Headlamps (26 )
  2. Will I Keep My Mileage If I Replace Dashboard? (9 )
  3. Mk1 focus 1.8 misfire---help!! (11 )
  4. New Key Fob (16 )
  5. New Bodykit For Mk2.5 In Malaysia (2 )
  6. What Has Happened To My Wiper?! (14 )
  7. Spamming (8 )
  8. Light Switch Leds (3 )
  9. Where Should This Connect To? (3 )
  10. Club Sticker Problem (3 )
  11. Fuel Consumption On V Reg Focus 86K 2.0 Petrol (3 )
  12. Petrol In A Diesel, 2007 1.8 Tdci (17 )
  13. 2007 Ford Focus 1.8 Tdci Engine Rattle (6 )
  14. Sony Sat Nav (3 )
  15. Dim Head Light (3 )
  16. Flyeye Removed (4 )
  17. Mk2 Focus 1.8 Tdci - Possible Dual Mass Flywheel Replacement? (4 )
  18. Sony Headunit For Focus 2009 (21 )
  19. Focus Injector Problem (1 )
  20. Iphone Bluetooth Driving Me Mad!! 2009 Focus (3 )
  21. 02 Ford Focus Dash Problems (2 )
  22. Steering Wheel Knock 2009 Focus Mk 2.5 (6 )
  23. Were Can I Get A Decat Pipe For A Focus Tddi (0 )
  24. Fitting Engine Cover To 1.6Tdci (48 )
  25. Workshop Manual (1 )
  26. My Tdci - Anything To Make It Better? (4 )
  27. Mk1 Focus Boot Problems (Help Plz) (8 )
  28. Driver Side Front Foglight Smashed :( (7 )
  29. Alloys (2 )
  30. Best Way To Vacume Ac Drain ??? (3 )
  31. Clutch Bearing (2 )
  32. 2006 1.6 Tdci Fuel System Problem (2 )
  33. Cv Joint Failure? (4 )
  34. Zetec Diesel (5 )
  35. Zetec Diesel (6 )
  36. Insurance And Minor Mods (5 )
  37. Mpg - Your Experiences (91 )
  38. Dash Warning Light (1 )
  39. Dashboard Eroor Light ? (1 )
  40. 12V Socket No Longer Working Also Lack Of Fuses? (15 )
  41. Goldenleaf's Discreet Mods (39 )
  42. Egr Delete Or Not? (2 )
  43. Reverse Parking Sensors Error Beeps? (1 )
  44. 1.6 (100Ps & 125Ps) Mpg On Averages Please? (11 )
  45. Upgrade To Sony Head Unit. (11 )
  46. Ford Rds 6000 Cd Player Crackling On M Wave (2 )
  47. Help!, (4 )
  48. Zec S Wrc Decals Wanted (3 )
  49. Fine Metal Fragments In Jerry Can After Filling Up???? (2 )
  50. Intermittent Poor Starting 1.6 Duratec (8 )
  51. Focus Mk3 2012 Tit X Drl (15 )
  52. Starting Up Problems (22 )
  53. Rear Lights On Focus Mkii (1 )
  54. Mk2 Fog Light (2 )
  55. Would You Buy Focus Zetec S 2009 With Following Problems? (16 )
  56. High Revving? Tps?? (4 )
  57. Instrument Led Display Query (2 )
  58. Two Questions Please (2 )
  59. Boot Lock Fix *struck Lucky & Wanted To Share* (5 )
  60. Washer Fluid Warning (79 )
  61. Focus Making Funny Noises Whilst Idling (4 )
  62. Help! My Focus Is Playing Up :( (4 )
  63. Focus Lowering Springs (0 )
  64. Had Car Remapped. (12 )
  65. My First Of Many Mods Hopefully :) (7 )
  66. Mist Jets (19 )
  67. Cam Belt Change Should I ? (10 )
  68. Lack Of Low Rev Power (8 )
  69. Alloy Wheels (11 )
  70. Remap In Yorkshire (6 )
  71. Mk2 Focus Rear Wiper Mod... (2 )
  72. Ford Focus Mk2 Day Time Running Lights (6 )
  73. Exterior Door Handle Help (1 )
  74. Which Should I Buy? (5 )
  75. Side Skirt Offer (8 )
  76. Focus Zetec Diesel Battery Light Issues (3 )
  77. Replacing The Abs Pump / Ecu Module (0 )
  78. 2006 Focus Mk2 Tdci Goes Into Limp Mode With Several Fault Messages (1 )
  79. 2006 Focus Mk2 Tdci Goes Into Limp Mode With Several Fault Messages (0 )
  80. How To Activate/deactivate Chime And Warning Light For Seat Belt (10 )
  81. Correct Oil: Advice Please (6 )
  82. Don't You Just Gate This Time Of Year..... (5 )
  83. I Can't Go Backwards !!! (2 )
  84. Changing Seats (0 )
  85. Annoying Powertrain Light / Glow Plugs Issue (0 )
  86. Annoying Squeak (0 )
  87. May Have Found Possibly The Most Awkward Place To Have A Hose Blow (0 )
  88. Focus 1.4 Pinking And Hose Cold (1 )
  89. Waterleaks - Floorpan/footwells Focus 3 Door (0 )
  90. Ford Focus Mk3 Audio/usb Lead For Ipod (2 )
  91. Electric Windows (1 )
  92. Ford Focus Cosworth (2 )
  93. 2014 Rs (5 )
  94. Speed Camera (59 )
  95. Fault Codes (0 )
  96. Thoughts On Dab In Car Radio? New Headunit? (7 )
  97. Bulbs Don't Fit. (3 )
  98. Replacement Instrument Cluster (0 )
  99. Heater Stuck On Cold (0 )
  100. Sd Navigation (12 )
  101. Tyre Recomendations? (21 )
  102. Focus 1.6Tdci Should I? (2 )
  103. Intercooler Piping Upgrade? (4 )
  104. Gearbox Noise (22 )
  105. Dasboard Warning Light (6 )
  106. Flip Cubbyhole Removal (Traditionally An Ashtray) (7 )
  107. Restrictive Pipe To Airbox (9 )
  108. Dpf Removal (6 )
  109. Various Dash Lights (5 )
  110. Latest Ecu (3 )
  111. Sensor Location (0 )
  112. Big Engine Judder/rattle When Turning Off + System Fault Light (0 )
  113. Ford Focus Knocking Noise (3 )
  114. Head Unit (6 )
  115. Front Fog Lamp Inserts! (3 )
  116. Coolant Leak (3 )
  117. Poor Start Up / Non Start (5 )
  118. Ford Focus Mk2 2005 1.6 Petrol Oil In Spark Plugs Area (9 )
  119. Replacement Front Grill (3 )
  120. Jump Starting - A Problem Or Not (19 )
  121. Newbie, Arrrrg. Locked Out (8 )
  122. "engine Systems Failure"(On Cluster Lcd Display) (8 )
  123. Steering Tight Spot (1 )
  124. Where Is It Leaking From?? (3 )
  125. Headlight Dip Manual Adjustment (10 )
  126. Osram 'cool Blue Intense' Bulbs (13 )
  127. Mondeo Starting Issues (4 )
  128. Focus St170 Headlight Adjustment (2 )
  129. Inner Door Panel Removal? (8 )
  130. Mk2.5 Speaker Wiring?? (2 )
  131. Headlight Bulbs (15 )
  132. Ford Focus 57 Tdci (0 )
  133. My New Car (1 )
  134. Third Times A Charm (10 )
  135. Can't Find Power Steering Fluid Resovoir (4 )
  136. My New Car (9 )
  137. Ford Travelpilot Ex (2 )
  138. Mk 3 Focus Engine Cover? (9 )
  139. Focus Mk2 Eibach Lowering Springs (1 )
  140. Mk3 Focus Titanium Alloys (13 )
  141. Red Light On Dash At Top Between Rev And Speed Counter? (29 )
  142. Auto Wipers Not Working Correctly? Advice Please (4 )
  143. Converting Non Heated Side Mirror To Heated Mirror? (13 )
  144. Clutch / Gearbox (1 )
  145. What You All Getting (1 )
  146. Mark 2 Sidelight Wire (7 )
  147. Ignition Alarm (1 )
  148. 2009 Focus Zetec S Cruise Control As Standard? (8 )
  149. 1.6 Tdci 115 - Low Mpg (24 )
  150. Exhaust For 1.8 Zetec S (2 )
Full Colour Version: Ford Focus Club
