Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53
  1. Soon To Be New Owner (21 )
  2. Keyless Ignition Glitch (6 )
  3. 5 Cog Manual Compared To The 6 Cog Manual (6 )
  4. Aircon Query (3 )
  5. Ford Rear Badge (5 )
  6. Security Query (16 )
  7. Rear Window Woes (0 )
  8. Focus Underside Of Car (8 )
  9. Focus Modifications Advice Wanted/needed (13 )
  10. Full Geometry Setup At Drury Lane (2 )
  11. New Focus Titanium X (16 )
  12. Thinking About Fitting St Gauge Pod In Focus Tdci (16 )
  13. Sachs V Luk Dual Mass Fly Wheels (0 )
  14. Focus St Gauge Pod Fitted To Tdci (0 )
  15. Gets Stuck In 5Th (4 )
  16. 1.8Tdci Lumpy When Cold (11 )
  17. Horn And Electric Seat Blown Fuse (3 )
  18. Mk1 Focus Central Locking Issue??? (1 )
  19. Recommend A Dtc / Obdii Code Reader (9 )
  20. Key Problem (7 )
  21. Ford Focus 1.6 Tdci Estate 55 Plate - Help Needed (3 )
  22. Zetec S Rear Skirt (2 )
  23. Odd Shape Sponge Under Passenger Seat (13 )
  24. Looking To Get A Focus Within The Next 6 Months (0 )
  25. A Question For Focus Mk2 1.8Tdci Owners (9 )
  26. Mileage (7 )
  27. Problem With Aux Port On 6000Cd (2 )
  28. Should The Mileometer Light Stay On (5 )
  29. Focus Key Programming (3 )
  30. Which Antifreeze (6 )
  31. Dpf, Egr, And Turbo Replaced, Still Power Loss? (16 )
  32. Speed Signal (0 )
  33. Rough Idle And Lpg Problem (10 )
  34. Esp Light Stays On Dtc Code #01 A895 (7 )
  35. Ford Focus Cd Player (1 )
  36. Add Armrest (1 )
  37. Focus Goodies (24 )
  38. Move Internal Roof Handles (7 )
  39. Mk3 Focus Unlocking Problem (11 )
  40. 1.6Tdci - New Alternator Voltage Pulsating. (3 )
  41. First Detail Clean (33 )
  42. Tow Bar (13 )
  43. Clean Inside Of Headlights (5 )
  44. Problem Starting After Stalling (0 )
  45. Focus Temp Gauge Rising (2 )
  46. Focus Head Up Display (Speedview) (2 )
  47. Date And Time Not Staying Correct Please Need Help! (6 )
  48. Steering Clunk (3 )
  49. Pls Help Ford Focus 2008 Facelift 1.6 Or 1.8 Petrol (10 )
  50. Derv Zetec S.......... (8 )
  51. New Focus Power Fold Mirrors (7 )
  52. Dpf Or Not? (19 )
  53. Sony Dab Radio (5 )
  54. Focus Passenger Headlight Blown (2 )
  55. Engine Management Light (3 )
  56. Mk3 Ford Power Start Button (9 )
  57. Electrical Problem ? (9 )
  58. Cabin/pollen Filter (2 )
  59. Ideas (8 )
  60. Mk2 Ashtray (4 )
  61. Engine Malfunction And Then Engine Switches Off At Speed (7 )
  62. 12V Power Plug (11 )
  63. Iphone Bluetooth Question (2 )
  64. Climate Control Mk2.5 (3 )
  65. Time To Reach Normal Temperature (12 )
  66. Engine Revs (5 )
  67. Armrest (8 )
  68. Starting To Hate My Focus! (15 )
  69. Keyless Ignition Start? (5 )
  70. Lowering The Focus? (9 )
  71. Travelpilot Dx (0 )
  72. Seek Track ??? (9 )
  73. Changing The Fuel Feed Pipe (2 )
  74. Unknown Power Cable? (3 )
  75. Service Oil / Regen Advice? (12 )
  76. Beeping Audible When Indicating (4 )
  77. Fault Codes (0 )
  78. Focus Wont Start (4 )
  79. New Key And Programming (0 )
  80. Rattling Window (1 )
  81. Power Steering Fluid Black ? (5 )
  82. Abs Light Issue (4 )
  83. Engine Warning/management Light (2 )
  84. Reverse Lamp Wiring (2 )
  85. Hesitation (7 )
  86. I Hear A Clicking When Front Wipers Are On Intermittent (4 )
  87. Old Focus Water Leak (2 )
  88. Anti Roll Bar Links (3 )
  89. The Sweeney & The St... (6 )
  90. Dash Material (30 )
  91. Streeing (4 )
  92. Glovebox Removal - Mk2 (4 )
  93. Central Locking Problems (0 )
  94. Droplets On Top Of Plugs (2 )
  95. Headlights/side Lights (13 )
  96. 1999 1.6 Gearbox Removal (2 )
  97. Cd Playing In 2010 Ford Focus 1.6 (0 )
  98. Mk3 Focus Iphone / Ipod Mount (7 )
  99. Reverse Gear Selection (2 )
  100. Got My New Car Today (11 )
  101. Zetec S (0 )
  102. Mk 3 Focus 1.6 Ecoboost 150 Fuel Consumption (7 )
  103. I'm Gonna Blow My Car Up!!!!! (3 )
  104. Steeing Issues (0 )
  105. Interior Lights Staying On (7 )
  106. Focus Dashboard Esp???? (3 )
  107. Loss Of Power (21 )
  108. 05 Focus Mk2 Clutch (2 )
  109. Focus Lx 2004 Abs And Brake Lights Errors (2 )
  110. Bluetooth Update Keeps On Failing (0 )
  111. Turning A Mk 1 Focus Into A Decepticon! (Transformers) (0 )
  112. Mk 1 Parking Lights (0 )
  113. 2009 Focus 1.6 Tdci Maf (2 )
  114. Steering Column Problem (7 )
  115. Thought On These Pedal Guys (16 )
  116. St170 Replacement Genuine Stereo? (2 )
  117. Cooling Fan (0 )
  118. Engine Noise (1 )
  119. Power Folding Mirrors (1 )
  120. St170 Clutch Slipping - Help Pls (6 )
  121. Dash Display Problem - Fuel Gauge, Speedometer (4 )
  122. She Needs A Bit Of Attention (4 )
  123. Front Fog Lights Facelift 2008 Focus (7 )
  124. Cycle Carrier - Advice Please! (8 )
  125. Replacing Track Rod End 52 Plate Facelift Focus (2 )
  126. Sat Nav Map Display (4 )
  127. St Side Skirts (8 )
  128. Is It Terminal? (1 )
  129. Dmf Question (3 )
  130. Iphone 4 Ios 5 Update (8 )
  131. 2003 Focus - Reversing Ligt (3 )
  132. Warranty? Whats Not Covered? (10 )
  133. Heated Rear Window (9 )
  134. Focus Drl's (25 )
  135. Exhaust For My 2003 Focus 1.6 (1 )
  136. Help! Rich Running Engine, (0 )
  137. Newbie Questions (19 )
  138. Mass Air Flow (2 )
  139. 2010 (10) Ford Focus 1.6 Zetec 100 5Dr (7 )
  140. Replacement Radio To The Sony Dab (0 )
  141. How Do You Split The Key?? (1 )
  142. Dfp Removal And Remap (2 )
  143. Oil Pressure Sensor (2 )
  144. Switches On Brake Pedal (3 )
  145. Aux Plug (1 )
  146. Codes (3 )
  147. Esp Warning Light On 2008 Focus (1 )
  148. New Focus Ownerh (2 )
  149. Focus Engine Cover (3 )
  150. Infomation Display Light And Start Button Help! (2 )
Full Colour Version: Ford Focus Club
