Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53
  1. Focus Instrument Cluster Lights Issue (0 )
  2. Cd6000 Tuning Problems (5 )
  3. Wires Come Out Of Connector And What Is This ? !!! (2 )
  4. Half Electrics Have Gone! Please Help (2 )
  5. Sub And Amp Install (3 )
  6. 2.0 Zetec Coolant Loss (2 )
  7. Trip Meter Not Working (4 )
  8. Failed Mot Today (2 )
  9. Focus Central Locking (2 )
  10. What Is The '100' In Focus Zetec 100? (2 )
  11. Rear Wheel Noise (2 )
  12. Fareinheit To Deg C? How... (1 )
  13. Changing Exhaust (4 )
  14. Focus Diesel (2 )
  15. Question On Servicing Rear Brake Drums (3 )
  16. Please Help (3 )
  17. Ford Focus 2002 Automatic Transaxle/cooling System Light (7 )
  18. Warranty On A Ford Focus? (9 )
  19. Focus Front Fog Light Wiring (4 )
  20. Focus Tddi Not Starting (17 )
  21. Random Engine Malfunction Warnings (15 )
  22. Shaking Focus (5 )
  23. New Ford Focus 2011 Mp3 Aux In Problem (2 )
  24. Considering 2.0Tdci Or 1.8 Petrol Zetec S 2010 (8 )
  25. Battery Or Alternator?.... (19 )
  26. Ipod Integration Kit For 2009 Focus 6000Cd Stereo (2 )
  27. 09 Focus Zetec - Aux Input.. (2 )
  28. Ford Focus 2002 Automatic Transaxle/cooling System Light (0 )
  29. Focus Zetec S (3 )
  30. Focus 1.8Tdci Fuel/engine Problem (1 )
  31. Focus Battery (2 )
  32. Abs Wire (0 )
  33. Intermittent Fault, Electrics/starting (0 )
  34. Wet Upholstery (12 )
  35. Intermittent Nightmare! (6 )
  36. Temperature Sender (4 )
  37. Side Lights On Focus (13 )
  38. Ford Focus Turbo Problem? (2 )
  39. Not Happy! (52 )
  40. Front Wheel Bearing Units (2 )
  41. Aux Button (7 )
  42. Aircon (8 )
  43. Temp' Sensor/guage Problems (8 )
  44. Hi There, Fusebox Problem! (7 )
  45. Glove Box Bulb (5 )
  46. Focus 2008 Wiring Diagram (1 )
  47. Wing Mirror Mounted Indicator Side Repeators (2 )
  48. Rear Wiper Swept Area (1 )
  49. Misfire P0301 = Throttel Body (Known Ford Issue ?) (0 )
  50. Ford Focus (2 )
  51. Air Con Knackered (1 )
  52. Car Revving When In Gear ? Clutch Engaging Without Pressing It ? (4 )
  53. High Revving When Accelerating (14 )
  54. Ford 1.8Td Mk1 Droping Out Of Gear And Light On Dash Flashing? (2 )
  55. Ford Focus Estate Tailgate Unlocking - Solution (0 )
  56. Cambelt Snapped, 8 Year Serviced Yesterday (!) (7 )
  57. Intermittent Dipped Headlights (Focus 1.6 Zetec 2002) (1 )
  58. Oil Pressure Low - Help (3 )
  59. Mpg 2.0L Tdci (7 )
  60. Cam Belts (14 )
  61. Brake Judder (12 )
  62. Passenger Door Lock (1 )
  63. Rear Bumper Removal (1 )
  64. Paint Bubbling / Rust Problem Rear Arch (7 )
  65. Fuel Cap (4 )
  66. Focus Xenon Standard Lights (0 )
  67. Keyless Entry Fault (17 )
  68. Strange Noise (13 )
  69. Focus 2003 18" Alloys Questions (0 )
  70. Master Cylinder (26 )
  71. How To Strip Boot Mk1 Focus (3 )
  72. Recover Key Code (5 )
  73. Worth Repairing? (8 )
  74. Front Engine Mount (4 )
  75. How Do I Remove Aircon Radiator? (Condenser?) (6 )
  76. Stupid Question (5 )
  77. Seat Cloth / Trim / Cover... (5 )
  78. Thinking Of Buying A Ford Focus Diesel (8 )
  79. Focus Turbo To Cat Gasket (0 )
  80. Door Blew Open (6 )
  81. 1.4 To 1.6 Conversion (3 )
  82. New Cat' Fitted - Missing Heat Shield (1 )
  83. Ford Focus Parts (1 )
  84. 2003 Focus 1.8Tdci Zetec - Cutting Out/dirty Diesel? (7 )
  85. Dreamscience To Suit St 170 Wanted. (0 )
  86. Wanted: Ford Cd6006 Or Cd6000 (2 )
  87. Poor Mpg On My 06 1.6 Tdci (Climate) Focus? (26 )
  88. Fitting A Tow Bar On A 2000 Ghia Ff (0 )
  89. Ford Focus Clutch Pedal Return Spring (5 )
  90. Team Dynamic Wheels To Fit 2001 Focus (2 )
  91. What Version 3 4 5 6 7??? (3 )
  92. Door Mirror Cover (3 )
  93. Stuttering?! (6 )
  94. 6000Cd Bluetooth (1 )
  95. Exhaust Manifold Replacement - Cost? (10 )
  96. Focus-None Dpf. (46 )
  97. 2001 Focus 1.8 Zetec Running Issues (9 )
  98. Remove Audio Sys From Focus Mk2. (4 )
  99. Wheel Bearing Kit + Headache (2 )
  100. Eac Fail Massage On Dash (4 )
  101. Worst Cars You Have Ever Owned (0 )
  102. Help Needed (2 )
  103. Why I Don't Like My Focus. (37 )
  104. Focus Fog Lights (0 )
  105. Newbie Please Help, My Focus Battery Died Now Stereo Locked No Code, (4 )
  106. Focus Sill Damage (9 )
  107. Rear Suspension Bushes Poor Condition (1 )
  108. Ford Focus 1.8 Td 2002 (0 )
  109. Lights (3 )
  110. Imbalance On Front Wheels After Brake Pad Change (4 )
  111. Why Somethings Are Better Done By Ford (13 )
  112. Ford Focus Drinking Engine Oil (10 )
  113. Remove Sony Stereo From All New Focus (0 )
  114. Steering Is Heavy (5 )
  115. Rear Rattle - Remove Rear Light Cluster (2 )
  116. Opinion Needed On Colour (9 )
  117. Battery Current (0 )
  118. New Keys Cut (3 )
  119. Clutch Alternator Pulley, Where To Buy One??? (3 )
  120. Powered Steering (12 )
  121. Focus Auto Gearbox Solenoid "a" Part Number ?? (0 )
  122. Sidelights (1 )
  123. Which One Shall I Get ? Opinions Please (22 )
  124. Newbie Needing Help! (1 )
  125. Knackered Alternator? (10 )
  126. Water Leaking From Under Engine (1 )
  127. Rough Idle On A Focus 2005, 1.6 Vct (1 )
  128. Is Ford Parts Centre No Longer Trading? (16 )
  129. Farewell And Thanks For All Your Help In The Past (10 )
  130. Change Temperature Display To Celsius (6 )
  131. Air Con Stopped Working (9 )
  132. 2005 Focus 1.8Tdci Stopped And Wont Restart (4 )
  133. Is This A Good Deal? (11 )
  134. Fuel Gauge (1 )
  135. 1999 Ford Focus Tddi Breaking For Spares (0 )
  136. Focus Rear Lights (3 )
  137. Aux Port Ford Focus (4 )
  138. Focus 1.8 Tdci 2006 Alternator (0 )
  139. Smoke (8 )
  140. Tdci Problems (1 )
  141. Remapping (4 )
  142. Mk2.5 Focus Trip Computer (6 )
  143. Mk2.5 Focus Trip Computer (0 )
  144. Rhd Adaptive Headlights For Driving In Europe (0 )
  145. Clutch Pedal Return Spring Broken (Mk2 Focus) (0 )
  146. Zetec S Body Kit On A Zetec (2 )
  147. Aircon Smell (1 )
  148. Vibration - Update (5 )
  149. Arm Rest Broke (5 )
  150. Replacing Front Bumper (1 )
Full Colour Version: Ford Focus Club
