Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53
  1. Spare Key (0 )
  2. Oil Leak Down Front Of Engine (0 )
  3. St170 Fog Lights (6 )
  4. Focus Tdci Performance (8 )
  5. 2009 Plate Bumpers (1 )
  6. Central locking problems - possible solution (2 )
  7. Engine Problem (1 )
  8. Been At It Again (4 )
  9. Hesitant 1.8 Diesel? (5 )
  10. Drive By Wire Problem ?? (0 )
  11. Alarm, Is It Possible To Make It Beep As The Cars Locked And Unlocked (0 )
  12. Engine Systems Fault (0 )
  13. 6000 Rds Lock / Need Pin Pls (2 )
  14. Frauds Damaged My Car Bad (2 )
  15. Over Heating (10 )
  16. Focus Power Fold Wing Mirrors (1 )
  17. Flashing light on dashboard (5 )
  18. 8 Year Old Focus (7 )
  19. Speedo (9 )
  20. Radio Prob, Dash Trick Prob (2 )
  21. Magnetic Sump Plug (1 )
  22. Ford Focus (5 )
  23. Front Bearing Problem (0 )
  24. Xenon Headlights Mk1 Focus? (2 )
  25. Exhaust Problem, Possible Cost? (8 )
  26. Heated Seat Wireing (0 )
  27. Voice Command (0 )
  28. 2.6K Off A Brand New Rs Through Ford Owners Club (0 )
  29. Burning Smell / Smoke "please Help" ! (3 )
  30. Problem Reprograming Key Fob (4 )
  31. Engine Noise (3 )
  32. St170 Issues (9 )
  33. Creaking Door (0 )
  34. Dead (6 )
  35. How Do I Replace Front Indicators On Focus? (5 )
  36. Timing Belt Change (3 )
  37. Focus Mk3 1.8 Petrol Shakes When Starting Up (8 )
  38. Mot Failure (2 )
  39. Focus high idle - with a twist... (3 )
  40. Which Handbrake Cable (2 )
  41. Help Code Needed For 5000 Stereo (2 )
  42. Focus Heated Seats (3 )
  43. Focus Titanium Headling (3 )
  44. Drivers Side Door Jammed - Please Help! (0 )
  45. Towbar 2005 Focus (0 )
  46. Taking The Mick (4 )
  47. Ticking Noise (3 )
  48. Mk1 Bumpers (2 )
  49. Focus St170 03 Plate (1 )
  50. Service Costs (7 )
  51. Endura C170 100Ps Tci Sticker On The Engine But... (0 )
  52. Induction Kits (4 )
  53. Can't Decide Which Focus To Buy (6 )
  54. Droning Noise (2 )
  55. Ford Focus And Multi-Spoke Wheels (?) (0 )
  56. Vibrating Noise (0 )
  57. Focus 5000 Rds Stereo (0 )
  58. Rasping Noise From Engine (0 )
  59. Engine Fan Stays On After Switch Off (10 )
  60. Speedo Goes To Zero Any Advice? (11 )
  61. Whinning Noise (0 )
  62. Ford Focus 2001 (0 )
  63. Steering Knock (2 )
  64. Focus 1.4 03 Reg - Cambelt Or Chain (4 )
  65. Cooling Fan (8 )
  66. Air Conditioning (2 )
  67. New Car (0 )
  68. Help! Advice on warning light on Focus (10 )
  69. 2009 Focus Wheelarch Rattle (5 )
  70. Drivers Door Will Close But Not Open With Key (3 )
  71. Should I Avoid Using Neutral On My Auto Box? (2 )
  72. Ford Focus Bonnet Lock (0 )
  73. Whining Air Conditioning (2 )
  74. Washer Jets (1 )
  75. Speed Sensor (2 )
  76. Focus (1 )
  77. 2006 1.6Tdci Engine (2 )
  78. Idle Air Control Valve (5 )
  79. T-Cut (8 )
  80. Windscreen Wiper Problem (1 )
  81. Side Skirts (0 )
  82. Center Consul Trim (0 )
  83. Replaced 6000Cd For Decent Stereo - Warranty Issue? (3 )
  84. X Reg Focus Ghia Front Suspension Squeak. (1 )
  85. Nackered Road Wheel (4 )
  86. Weak Turbo (5 )
  87. Rubbing Sound From Rear (4 )
  88. Double Din Stereos (1 )
  89. Centeral Locking (0 )
  90. New Car (4 )
  91. Front Spoiler Needed, Focus Mk1 54 Plate (5 )
  92. Ford Focus Coliover Kit (0 )
  93. Front Headlight Problem (2 )
  94. Pollen Replacement (7 )
  95. Towbar Confusion (3 )
  96. Bodykit (9 )
  97. Spare Wheel Options? (9 )
  98. 4Wd Ford's (5 )
  99. Metric And Imperial At The Same Time? (1 )
  100. Eggy Smell (5 )
  101. Focus Squealing Noise? (7 )
  102. Ford Focus Back Box (2 )
  103. Why Does It Spent Too Much Fuel?? (1 )
  104. How To Tell A Bad Cat (6 )
  105. Cam Belt (6 )
  106. Electrical Issue?? (3 )
  107. What If... (1 )
  108. Confused Over Price (2 )
  109. Watery Woes (0 )
  110. 59 Plate Door Panel Removal ? (5 )
  111. Where Can I Get A Cd Radio Player For My Focus (2 )
  112. Mystery Engine Problem 02 Focus (1 )
  113. Turbo Replacement For Tdci In Birmingham Uk (0 )
  114. Power Windows (0 )
  115. Focus Heavy Steering (6 )
  116. Ford 6006 6-Disc Player (8 )
  117. Focus Seats (7 )
  118. Heated Front Screen Only Works In One Side (2 )
  119. A/c Electrical Fault, Help! (3 )
  120. Air Con (6 )
  121. 2006 Focux Zetec. Auto Window Switch (7 )
  122. Redex...has It Done Harm To Anybody's Engine? (19 )
  123. Central Locking (5 )
  124. Tyre Speed Ratings (1 )
  125. Double Din Unit (2 )
  126. Focus St Cambelt Change? (9 )
  127. Fords Are The Most Stolen (9 )
  128. Mk1 Focus Fan Problem (11 )
  129. Upgrade 6000Cd 2008 New Shape Focus (4 )
  130. Oil In Air Filter Hose (3 )
  131. Washers Not Working (2 )
  132. Mpg For 1.8 Petrol (7 )
  133. 2006 1.6Tdci Engine Rattle (0 )
  134. Ford Focus 2009 (1 )
  135. Ford Focus Tdci Sport Clutch/fluid Issue (1 )
  136. Fault Air Conditioning (3 )
  137. Buying A Foucs What To Look For??? (3 )
  138. Not Started For 2 Years (5 )
  139. Front Interior Light (3 )
  140. How To Get To Back Of Roof Antenna? (1 )
  141. Focus Estate Reverse Wiring Diagram Help (4 )
  142. Ford Focus Keys And Keyfob? (51 Plate) (10 )
  143. Mot Concerns (6 )
  144. Is My Focus Cambelt Or Chain Driven (2 )
  145. Focus Rs500 Sold In Only 12 Hours (16 )
  146. Focus Mk2 Engine Rattle (2 )
  147. Water Dripping From Underside. (4 )
  148. Y reg Focus Rust will it be covered by Ford? (6 )
  149. Service Indicator (0 )
  150. Problems Replacing Front Lower Arms (1 )
Full Colour Version: Ford Focus Club
