Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53
  1. Focus Steering Centre Rattle (2 )
  2. Steering Rack Boot/gaiter (0 )
  3. Help Speedometer Stops Working Then The Car Stalls What May Be The Problem (1 )
  4. Warning Light (19 )
  5. Looking To Buy A 2Nd Hand Ford Focus (23 )
  6. Will 6006E Fit My 2000My Foucus? (1 )
  7. Will They Mend It? (1 )
  8. Differences (7 )
  9. Climate Control Backlight (2 )
  10. Anyone Ever Done A Clutch On A 1.6 Focus Mk1? (0 )
  11. Drums To Disks (12 )
  12. Low Idle Speed When Warm?? (1 )
  13. Delayed Acceleration (18 )
  14. Cable Or Drive By Wire?? (3 )
  15. Thinking About Buying A St170 Conversion (3 )
  16. Driver's Side Lecky Window (4 )
  17. Blower/fan (4 )
  18. Brake Help (21 )
  19. Dahsboard Light Dimmer Switch (9 )
  20. Crap Brakes (17 )
  21. Auto Lock On Doors (9 )
  22. Engine Racing During Gear Change (1 )
  23. Throttle Surge 2009 1.6 Tdci Normal? (1 )
  24. Engine Light On, Burning Smell, Imrc Stuck Open? (1 )
  25. Replacement Rubber Seals? (5 )
  26. Isofix Not Installed On 57 Plate (1 )
  27. 1.6 Zetec Problems In 2Nd & 3Rd Gears?!?! (0 )
  28. Radio Code Needed Please (2 )
  29. Reprogramming Key Fob...update (7 )
  30. Genuine Ford 12N Dedicated Wiring Kit (0 )
  31. Are These Tyres A Good Choice (17 )
  32. Radio Code (2 )
  33. Erratic Idle, Stalling And Lack Of Power (5 )
  34. Car Park Dent Removal (3 )
  35. Blown Turbo On 2003 Focus Tdci 100Bhp (1 )
  36. Which Cleaner Is Best To Be Poured Down In The Tank? (9 )
  37. Alarm System (0 )
  38. Interim Oil Change And Warranty Implications (6 )
  39. Help......can't Fill Up....... (3 )
  40. Focus 1998 Road Test (5 )
  41. Kwik Fit Air Con Recharge. (1 )
  42. Low Revs (4 )
  43. Bluetooth (2 )
  44. Re-Progam Key Fob Problems (12 )
  45. Installing A Tom Tom Hidden Cable (2 )
  46. Focus Diesel Fuel Cap Lose? (0 )
  47. Focustddi (6 )
  48. Belt Or Chain On The 1.8L Petrol (56Reg) (9 )
  49. Install Rear Parking Sensors (8 )
  50. 2006 1.6Tdci Cambelt Change (9 )
  51. Accessory Belt Tensioner (8 )
  52. Stripes On My Focus (3 )
  53. The Dreaded Mot (9 )
  54. Engine Swop....? (4 )
  55. Focus Mk1 Body Trim (4 )
  56. Focus Mk1 Body Trim (0 )
  57. Focus Mk1 (3 )
  58. Mountune Performance (27 )
  59. Focus Passenger Door - Won't Open! (6 )
  60. Chips (5 )
  61. Throttle Response On 1.8 Tdci (2 )
  62. Footwell Lights (3 )
  63. Number Plate Lights Not Working On Side Light (3 )
  64. Condensation In Rear Light Cluster (7 )
  65. Mk1 Rear Drum Stub Axle Bolts (2 )
  66. Noise From 1.6 Petrol (6 )
  67. Speed Mph At Odds With My Tomtom Indicated Mph (27 )
  68. Squawking Brakes (14 )
  69. Spare Key Fobs (2 )
  70. Turbo Pipe (3 )
  71. 18 Tdci Noise?? (2 )
  72. Roof Rail Bolts Replacement (1 )
  73. 1.8 V 2.0 (2 )
  74. Mobile Phone / Car Tracker (0 )
  75. Focus Zetec S Mudflaps (5 )
  76. Heated Front Windscreen (2 )
  77. Rear Wiper...poss Bad Earth? (6 )
  78. Clutch Problem With Rental Car (1 )
  79. Silver Dash Trim Peice (11 )
  80. Loving My Car (1 )
  81. Facelift Focus Stereo In Mk2? (4 )
  82. Crashed My Focus (19 )
  83. Focus Tddi Won't Start When Parked Facing Up A Hill.. (8 )
  84. Engine Noise After Shutdown (4 )
  85. Focus Black Edition 1.6 Zetecse 51 Plate (7 )
  86. Mk2 Rear Courtesy Light (6 )
  87. 2004 Focus Front Suspension Noise (7 )
  88. Irritating Noise From 1.8Tddi Estate ... (5 )
  89. Focus 2.0 Tdci Issue (9 )
  90. Oil In Air Filter Hose (0 )
  91. Central Locking Motor Removal Tutorial Needed (1 )
  92. Satnavs & Heated Screens (14 )
  93. Mk 2.5 Rear Lights (5 )
  94. Fitting Leds? Read First (0 )
  95. Replacing Tie Rod End Boots With Or With Out Grease (6 )
  96. Diagnostic Code Reader (5 )
  97. Fse Boost Valves (1 )
  98. Fuel Gauge Not Working (2 )
  99. Ford Key System Explained (1 )
  100. Blower Direction Problem (0 )
  101. Focus Mk1 Key...price? (3 )
  102. 6000 Cd (2 )
  103. Gear Knob + Handbrake Questions (8 )
  104. Dashboard Indicators & Heated Front Windscreen Problems (3 )
  105. Buying A Used Ford Focus (4 )
  106. Focus Front Wheel Bearing (5 )
  107. Where Do I Wire/ Tap In A Charger For Tom Tom Fixed Installation (5 )
  108. Trouble Starting. (2 )
  109. Ford Focus Adaptive Headlight Not 'adapting' (8 )
  110. Have I Lost My Nut?? (13 )
  111. Focus Diesel Engine Same As Mondeo? (7 )
  112. Focus Zetec Boot Won't Open (1 )
  113. 17" 7 Spoke 4 Stud Alloy (1 )
  114. Mk1 Focus Ib5 Vss Removal (5 )
  115. Reverse Light - Change Bulb (3 )
  116. Ford Focus Mk2 (Uk) Temp Problems (1 )
  117. New Focus - diesel vs. petrol (14 )
  118. Engine Cuts Out :s (3 )
  119. Clutch Problem (9 )
  120. Cambelt Replacement (4 )
  121. Traction Control Light (2 )
  122. Stupid Suspension (11 )
  123. Focus Mk1 (0 )
  124. Headlight Lamp Change On 03 Plate (5 )
  125. Focus Breakdown 1.8Dti 2000 (6 )
  126. Focus Dash Pod Replaced - Similar Fault Still There (4 )
  127. Focus Zetec 2009 gear knob (7 )
  128. 6000Cd Player.....anyone With One? (7 )
  129. My Focus (2 )
  130. Do's And Don'ts Of Diesels (9 )
  131. Need Help With Led's And Wiring... (1 )
  132. Focus Mk2 Trim (5 )
  133. 2.0 Tdci (19 )
  134. 59 Plate Zetec Door Panels (6 )
  135. Footwell Lights (17 )
  136. Dtc Codes (17 )
  137. Bolt Seized In Bush (11 )
  138. How Do I Do It ??? (9 )
  139. Focus Replacement Key (1 )
  140. Radio Code (4 )
  141. Rear Door Card Removal. (7 )
  142. Ford Focus Trip Computer (1 )
  143. Help!! Crankshaft Sensor (2 )
  144. Bulb Fitments (2 )
  145. Overheating (2 )
  146. Door Wont Open From Inside Or Out, And I've The Card Off! :( Help, Please! (6 )
  147. Heated Windscreen Issues (3 )
  148. Replacing Dipped Bulbs (5 )
  149. Rubbish Pull Away (15 )
  150. Ford Focus 56 Plate Stone Chip Problems (25 )
Full Colour Version: Ford Focus Club
