Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53
  1. white smoke (22 )
  2. Front wipers won't work (6 )
  3. Focus cylinder head help... (1 )
  4. noise from suspension (11 )
  5. 56 Need to know about reverse light plus bumper info (0 )
  6. Replacing headlamp bulb (5 )
  7. Thanks Instructorpiggy suspension now FIXED (0 )
  8. stereo flickers when lights on (2 )
  9. Knocking from O.S.F (9 )
  10. Advice on tow bars (12 )
  11. Oil warning light (8 )
  12. Spare key for focus (14 )
  13. Locking Problems (2 )
  14. Fuel and Temperture guage not reading correctly (3 )
  15. Locking (8 )
  16. MK1 Focus Wing mirror (6 )
  17. fuel/ignition code p0420 efficency below threshold bank1. (2 )
  18. Battery Cover (4 )
  19. Cover under bottom of Focus (4 )
  20. Installing Additional Cigarette Lighter (7 )
  21. airbag fault code b2855 or fault 4 2. (1 )
  22. FORD RECALL (4 )
  23. Focus rear brake conversion (5 )
  24. Glow plug problem on common-rail diesel? (9 )
  25. Outside temperature (0 )
  26. help on airbag short - front sensor (0 )
  27. Coins inserted in air vent!! (11 )
  28. what spark plugs are you using (2 )
  29. diesel running lumpy over 3000rpm (4 )
  30. 1.8 16v Zetec (1 )
  31. Ford Focus Mk1 1.6 Zetec (22 )
  32. stereo (9 )
  33. Cooling - Thermostat? (10 )
  34. Focus Zetec TDCi tuning advice (2 )
  35. clutch noise (11 )
  36. Starting Troubles (3 )
  37. Heated Seat's (6 )
  38. 12v cigarette lighter question (4 )
  39. Battery voltage issues (3 )
  40. Playing MP3s on Ford Focus 6000CD (4 )
  41. Antifreeze and Oil question (8 )
  42. Gearknob options for a Mk1 focus? (3 )
  43. Why do people jam up to you (10 )
  44. Ford Focus Problem (5 )
  45. WHAT ROM DO YOU HAVE? (0 )
  46. Aligning bonnet (6 )
  47. Rear Door Child Locks (2 )
  48. Ipod solution for new Focus owners (0 )
  49. Key FOB programming (2 )
  50. fabric seats (5 )
  51. Drivers side Electric window not working every now and then (9 )
  52. '09 focus instrument query (5 )
  53. Newbie (5 )
  54. protective film (9 )
  55. Loss of Power (2 )
  56. Running Lights (1 )
  57. Corvette owner???? (0 )
  58. Cigarette lighter (10 )
  59. Help With Electrics (2 )
  60. Focus CD Stereo 6000 (1 )
  61. normal idle speed (7 )
  62. Ford Focus TDCI Sport (1 )
  63. 02 1.4 focus head, where to buy? (1 )
  64. Tyres worn on the inside (3 )
  65. Driver side tail light not working (5 )
  66. Ex Mobility Car (2 )
  67. hard starting 1.6 mk1 (6 )
  68. tasteful mods (33 )
  69. Focus 1.8 16v random sensor! (17 )
  70. focus shimmed tappet adjust procedure? (0 )
  71. INFO ON INSTRUMENT PANEL SELF DIAGNOSTIC MODE (2 )
  72. HELP! Focus Timing belt/HG=NOISE! (4 )
  73. Anti Theft Alarm (1 )
  74. Focus 2006 Remote Operation (3 )
  75. Wiring up (1 )
  76. hid conversion kit for the mark 7 (10 )
  77. Different settings? (1 )
  78. Misfire after 15-20 minutes 1.8 Zetec (17 )
  79. Noisy exhaust heat shield (3 )
  80. More horse power (4 )
  81. Servicing (1 )
  82. Computer in European format? (2 )
  83. catalytic converter 1.4 (1 )
  84. Key copy? (8 )
  85. dim lights (9 )
  86. Seatbelt Wight and Chime problem (2 )
  87. routing cables (4 )
  88. cruise control (10 )
  89. Replacing headlamp bulbs (8 )
  90. Strange rattle & slight jolting sensation.. (0 )
  91. Ford Focus Communications Pack (0 )
  92. Starting issue (6 )
  93. Ford focus control bulbs??? (2 )
  94. Heater is playing up (5 )
  95. Cutting out when driving (3 )
  96. Cabriolet roof noises (2 )
  97. How to Replace (1 )
  98. Poss temp sensor issue (6 )
  99. Injector connection (2 )
  100. What to look out for (13 )
  101. Flip Key for a 2006 Zetec? (2 )
  102. Dancing needles (2 )
  103. Picked up a Focus 1.6TDCi Zetec Climate today (12 )
  104. 2.0iESP - ESP/TCS problems, lateral sensor, brake change (3 )
  105. information needed on a facelift from 2001 focus to st170 focus (1 )
  106. CD 6000 AUX Connection (0 )
  107. Focus price (8 )
  108. Ford Focus Zetec 1.6 (3 )
  109. mot failed ? help (2 )
  110. Focus 1.8 TDDI EGR Probelm...Please Help (4 )
  111. Panther Black (5 )
  112. Aux input for 5000 RDS on a 1999 Focus LX (1 )
  113. Drivers side locking problem, locking but not opening. (1 )
  114. Changing idle control "Changing Part Tips" (6 )
  115. Ford Focus RS at the 2009 SEMA Show (0 )
  116. loss of power (11 )
  117. Newbie! (5 )
  118. bluetooth built into the head unit? 2009 focus (0 )
  119. Petrol in a Deisel (13 )
  120. mud flaps/ sill protectors-lockwood (1 )
  121. Focus clutch sqeaking (6 )
  122. A bit of advice, which may be more obvious for some. (4 )
  123. Focus TDDI jerking/kangerooing at small accelerator openings in 1st and 2nd gear. (10 )
  124. anyone ellse own a 1.4 (3 )
  125. unknown switch (5 )
  126. Very Strange (0 )
  127. Possible fix for powerloss issue? (3 )
  128. focus fault codes (2 )
  129. heated seat relays/wires (0 )
  130. radio 4000 code needed (2 )
  131. Tow Bar Fitting to 1.8 Estate (2001) (3 )
  132. strange noise (2 )
  133. Strange Noises from my 2002 TDCI (1 )
  134. 09 focus spare wheel (0 )
  135. Focus Engine Rattle Noise when Accelerating (0 )
  136. ex-driving school Ford Direct Ford Focus (0 )
  137. 2000 Focus 2.0l Ghia - Coolant leak, but where? (8 )
  138. Some dashboard lights staying on too long? (2 )
  139. How do you remove (2 )
  140. 1999 TDDI 1.8 feels low on power (3 )
  141. LAmp replacement in passengerside headlight (3 )
  142. Siezed spark plug (12 )
  143. Focus Service (1 )
  144. annoying starting issue (5 )
  145. Heated front screen (0 )
  146. Vibration on acceleration (3 )
  147. ST170 paint codes. (3 )
  148. Airbag warning light (1 )
  149. Mileage resets itself (2 )
  150. Replacement rear view mirror (1 )
Full Colour Version: Ford Focus Club
