Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54
  1. loss of power (11 )
  2. Newbie! (5 )
  3. bluetooth built into the head unit? 2009 focus (0 )
  4. Petrol in a Deisel (13 )
  5. mud flaps/ sill protectors-lockwood (1 )
  6. Focus clutch sqeaking (6 )
  7. A bit of advice, which may be more obvious for some. (4 )
  8. Focus TDDI jerking/kangerooing at small accelerator openings in 1st and 2nd gear. (10 )
  9. anyone ellse own a 1.4 (3 )
  10. unknown switch (5 )
  11. Very Strange (0 )
  12. Possible fix for powerloss issue? (3 )
  13. focus fault codes (2 )
  14. heated seat relays/wires (0 )
  15. radio 4000 code needed (2 )
  16. Tow Bar Fitting to 1.8 Estate (2001) (3 )
  17. strange noise (2 )
  18. Strange Noises from my 2002 TDCI (1 )
  19. 09 focus spare wheel (0 )
  20. Focus Engine Rattle Noise when Accelerating (0 )
  21. ex-driving school Ford Direct Ford Focus (0 )
  22. 2000 Focus 2.0l Ghia - Coolant leak, but where? (8 )
  23. Some dashboard lights staying on too long? (2 )
  24. How do you remove (2 )
  25. 1999 TDDI 1.8 feels low on power (3 )
  26. LAmp replacement in passengerside headlight (3 )
  27. Siezed spark plug (12 )
  28. Focus Service (1 )
  29. annoying starting issue (5 )
  30. Heated front screen (0 )
  31. Vibration on acceleration (3 )
  32. ST170 paint codes. (3 )
  33. Airbag warning light (1 )
  34. Mileage resets itself (2 )
  35. Replacement rear view mirror (1 )
  36. how to stop "artificial inteligence" (2 )
  37. Focus Ghia Drivers Seat Armrest stuck (0 )
  38. V reg 2.0i Ghia just stops among other things (1 )
  39. Diagnostics on P0420 code (0 )
  40. vibration under acceleration (1 )
  41. Paintless Dent Removal (4 )
  42. Focus Heated Seats (1 )
  43. Door Unlocking (3 )
  44. Ugly Roof Rails on '06 Estate (1 )
  45. 12v sockets (1 )
  46. Milage Helpppppp!!! (6 )
  47. What you think? (2 )
  48. Hot running 2003 1.6 Zetec SE (4 )
  49. radio code/wheel nuts (2 )
  50. ford focus tdci cuts out (1 )
  51. Oil Pump (0 )
  52. what sealant (1 )
  53. Removing door mirror covers on new Focus (1 )
  54. Focus Zetec 1.6 59plate (0 )
  55. Code for Radio 4000 (9 )
  56. Water pump replacement (3 )
  57. DURATEC HE 2.0 Power Output (2 )
  58. Fitting an Alternator (4 )
  59. window motor. (0 )
  60. Mk1 Focus Estate Storage (2 )
  61. FAO Scottish Members (0 )
  62. radio code please (4 )
  63. exhaust sensor post cat (1 )
  64. Is my car up-to-date? (2 )
  65. FM interference (0 )
  66. focus steering noise? (1 )
  67. 1.6tdci DPF filter removal (0 )
  68. Paint for zetec alloy wheels (2 )
  69. Setting Clock (1 )
  70. Car Seat Colour (12 )
  71. Focus 06 - poor radio reception (2 )
  72. Ford Focus 1.6 TDCi Sport (5 )
  73. Glowing Gear knob (3 )
  74. Steering Wheel Problem (3 )
  75. Focus 1.6 silver 2002 (0 )
  76. Engine management light!! Help!! (7 )
  77. Reverse parking sensors (3 )
  78. Haynes (4 )
  79. 58 plate Focus (7 )
  80. Climate control bug (3 )
  81. Cam belt (9 )
  82. Suggestions required for new headunit for 2009 Focus RS (1 )
  83. STALLING WHEN SLOWING DOWN I HAVE THE CURE AT LAST (1 )
  84. Central Locking - Rear Passesnger Door (8 )
  85. Mk2 Rear Light Cluster? (0 )
  86. New headunit for Ford Focus 2009 (1 )
  87. 1.8 focus. Long or short plugs? (1 )
  88. finis codes (0 )
  89. How low can i go? (0 )
  90. Mirror cover? (9 )
  91. New Mk3 Ford Focus (0 )
  92. heated seats (0 )
  93. ford focus titanium 1.8 :) (4 )
  94. '99 Focus gearbox noise (4 )
  95. New Rear Bumber (1 )
  96. new clutch (1 )
  97. stuck needles (0 )
  98. Decisions decisions (0 )
  99. Radio Fascia (1 )
  100. DIN Blanking (1 )
  101. Why was my post deleted? (2 )
  102. Focus wheel bearings (2 )
  103. Recurrent crank sensor fault (1 )
  104. st170 co2 sensor (5 )
  105. Engine Noise (1 )
  106. Coolant pump leak (0 )
  107. spark plug socket size (1 )
  108. Ford 6000cd Problem (0 )
  109. Side Repeaters (4 )
  110. 1.8TDCI help needed (0 )
  111. Bonnet adjustment (3 )
  112. [Youtube] Two Vids of my Focus + bonus vid (2 )
  113. Focus Engine (3 )
  114. Question about new Focus ST lookalikes (3 )
  115. Would a 2007 Focus CD6000 fit in a 2005 (MK2)? (0 )
  116. Is my lambda sensor to blame? (18 )
  117. solid fly wheel kit (1 )
  118. Central locking problem (2 )
  119. Buying Focus (3 )
  120. Car Won't Unlock (2 )
  121. New purchase - lights (0 )
  122. Whistle from Windscreen (3 )
  123. Focus 1.8 Duratorq TDCi Engine Layout (3 )
  124. Radio Reception (1 )
  125. 6000CD MW interference ? Bloody annoying ! (2 )
  126. Focus Edge TDCI 115bhp 04 plate (3 )
  127. tdci clatter on start up. (8 )
  128. Key fob reprogram (3 )
  129. Ford Focus TDDi has died (0 )
  130. illuminus dye coming from down near air con pump (3 )
  131. rattle (2 )
  132. suspension (3 )
  133. 1.8TDCI Missfire (1 )
  134. Speedo counter drops at any speed sometime ? (2 )
  135. Squeeling noise when full locked to the left (5 )
  136. mk 2 front fogs (3 )
  137. de cat performance (1 )
  138. upper radiator hose (1 )
  139. Focus 1.6 Zetec SE Crankshaft Pulley Removal (3 )
  140. Water Leak (5 )
  141. belt squealing (5 )
  142. BodyKit MK7 (1 )
  143. Tracking not the problem? (6 )
  144. new battery (11 )
  145. 06 Plate Focus 1.8TDCI Fuel Economy (2 )
  146. Focus 2007 Rear Wiper (3 )
  147. focus lights problem (3 )
  148. Dual mass flywheel (4 )
  149. Unstable oil-Fuel indicator (3 )
  150. Ford Focus 1.8TDCi For My First Car!!! (4 )
Full Colour Version: Ford Focus Club
