Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88
  1. Auto Gearbox (1 )
  2. Focus Illuminated Gear Know??? (12 )
  3. Went Through A Puddle......bad Idea! (15 )
  4. Aerial Wire Route (5 )
  5. Zetec S Spoiler On Titx (5 )
  6. Focus Dashboard Instrument Cluster Fault (1 )
  7. Changing The Ford 6000 Cd To A Sony Ford Cdx5F611 (6 )
  8. Location Of Main Common Rail Connector For Tuning Box (1 )
  9. Ford Focus Mk2 - Body Kit (3 )
  10. Water Leak In Drivers Side Under Carpet (15 )
  11. High Pitched Elecrical Noise (2 )
  12. Yay Or Nae (4 )
  13. Problem With Digital Display, Miles Remaining Not Showing, Please Help! (2 )
  14. Mrk 3 Focus St (16 )
  15. Well I Laughed ! (6 )
  16. Family Pack, And What Kind Of Rear Locks Are Standard? (8 )
  17. Where Can I Get These? (12 )
  18. Focus 1.4 Cl (1999) Remote Central Locking (7 )
  19. Wire Up Heated Windscreen To Rear? (12 )
  20. Engine Wont Turn Over But All Interior Electrics Work (12 )
  21. Help With Mk3 (4 )
  22. My Car. Just Recently Started To Improve The Looks. Heres What Ive Done So Far. Any Other Ideas What I Can Do Will Be Appreciated. (23 )
  23. Blue Smoke (8 )
  24. Help With New Purchase (6 )
  25. What Is The Top Speed Of The 1.6 116Ps Tdci Mk3 Focus (21 )
  26. Gear Box Trouble (10 )
  27. Problem Selecting Gear 1999 Focus 1.8 Tddi (7 )
  28. Car Servicing (7 )
  29. My New Zetec-S (15 )
  30. Ford Focus 2009 1.6 Zetec (6 )
  31. Focus St3 Owner With Some Questions.. (5 )
  32. Smoking Wheels (8 )
  33. Focus Lighting (25 )
  34. Just Saw A Focus Zetec S With Lambo Doors (9 )
  35. Where Does This Wire Go (0 )
  36. Look What Arrived In Post.... (6 )
  37. P0113 Intake Air Temperature Circuit High Input (1 )
  38. Ford Focus Stereo (18 )
  39. Air Con (2 )
  40. Read Disc Conversion (3 )
  41. Focus And Long Commute (14 )
  42. Ecu Remap (18 )
  43. What Model Do You Advise Me To Get Next? (13 )
  44. Help Please! Boot Keeps Opening By Itself (1 )
  45. Replaced Dials On My Focus And Now Have Trouble With The Needles? (1 )
  46. 2002 1.8 Tddi Uneven Idle (3 )
  47. Geerbox Oil How To Add (3 )
  48. 2006 Focus Dipped Beam Failure - Both Headlights @ Same Time (4 )
  49. Gear Box Noise Have A Listen (8 )
  50. Need Help (12 )
  51. Focus Idle Problem When Stopping? (2 )
  52. Led Number Plate Lighting (13 )
  53. Focus Jerking In 2 Nd Gear (1 )
  54. Focus 1.6 Zetec Petrol 09 Plate (0 )
  55. Hesitation/missing. (3 )
  56. Focus 1998 Dashboards Etc Issues - Help !! (1 )
  57. Engine Systems Fault - But Car Drives Fine? (10 )
  58. Locked Out Of My 08 Focus... (9 )
  59. Estate Boot Lights (5 )
  60. Profile Automotive Ltd (2 )
  61. Air Con Drain Pipe Leak - Mk 2.5 Focus (7 )
  62. Variator Replacement (5 )
  63. Rear Lights (9 )
  64. Bluetooth Voice Control Number Change (3 )
  65. Ford Focus Windscreen Wiper Problem (10 )
  66. Ford Focus Estate 1.6Tdci Lx (2 )
  67. Low Oil (9 )
  68. First Mot....... Pass! (0 )
  69. Bluetooth And Sony Radio (0 )
  70. Possible Turbo Leak - Where To Look? (3 )
  71. New Focus Owner (5 )
  72. Radio Code On New Focus (2 )
  73. Clutch Travel (7 )
  74. Had The Car Mapped (22 )
  75. Change Battery In Key (7 )
  76. Mk2 Headlights Flashing (3 )
  77. Can Anyone Explain What The Fault Is Please (6 )
  78. Multistalk Adapter (4 )
  79. Stupid Garages (5 )
  80. Problem Help Needed (1 )
  81. Fault Codes Read... (3 )
  82. Plasti Dipped My Alloys And Few Bits Today (22 )
  83. Engine Malfunction (0 )
  84. Can Anyone Help Please - Tddi Starting Problems (1 )
  85. First Time Ford Owner (10 )
  86. How The Hell Do You Contact Ford Dealers For Repair/advice? (2 )
  87. Illuminated Ignition Barrel Wiring Issues (56 )
  88. Ignition Lives Are Suddenly Always On Now... (4 )
  89. Error Code P2135 Tps (6 )
  90. What Mk Is My Focus ? (12 )
  91. Mk 2.5 Footwell Lights (10 )
  92. Looking (8 )
  93. Pollen Filter Cover Being Evil! (1 )
  94. Ford Focus Jerking (1 )
  95. Technical Names.. (3 )
  96. Wheres The Car Jack Usually Located? (1 )
  97. Snap On Solus (0 )
  98. Mk2 Ford Focus, Air Intake Nosie (2 )
  99. Painted Fog Light Surrounds & Grille's (14 )
  100. Scratch Removal (27 )
  101. Speedometer Change (2 )
  102. What Would This Connector Be For? (7 )
  103. Cd Player (6 )
  104. Blown Fuse.. Help!! (10 )
  105. Faulty 1.8Tddi Focus (0 )
  106. Clicking / Knocking Noise (4 )
  107. Full Set Of Seats And Door Cards (1 )
  108. Ford Focus Zetec S 2012 (47 )
  109. Cd Player (0 )
  110. Radio Code (4 )
  111. Hi Iv Just Bought A Focus 1.8 Diesel With A Snapped Cam Belt (2 )
  112. Focus St 170 Questions (1 )
  113. Juddering Focus Tdci Please Help (3 )
  114. Any Where Doing This Little Mod (3 )
  115. Code Errors Help (0 )
  116. Focus St-2 (6 )
  117. Problem With "staggering" Engine (Titanium 1.6 Petrol, 2010) (7 )
  118. Shock Absorbers (2 )
  119. Focus Woes (2 )
  120. Looking For A Sill (8 )
  121. Power Steering Fluid Issue (17 )
  122. Ford Focus Mkii Tow Bar -Chassis Problems (0 )
  123. Strange Starting (2 )
  124. Fuel Fualt (1 )
  125. Ford Focus Estate 08 1.6 Tdci (5 )
  126. Limp Mode (2 )
  127. Petrol Smell (0 )
  128. Anyone Had Any Focus Issues? Advice Please!! (4 )
  129. Engine Problem (9 )
  130. Diesel/petrol Parts (1 )
  131. Fitted Drls To My Mk2 :) (2 )
  132. Grinding Noise Turning Left Right And Just Off Centre (2 )
  133. Wood Grained Dash Kit R/h/d (1 )
  134. Advice Please (18 )
  135. Focus Brakelight Cover (6 )
  136. Bonnet Insulation (25 )
  137. Clutch Slipping, Then Can't Select Gears! (4 )
  138. Engine System Fault Again... (3 )
  139. Advice / Suggestions Wanted Please (6 )
  140. Few Questions About Focus Mkii 1.6 Tdci (15 )
  141. Mk3 Xenons And Sound System (4 )
  142. Ford Focus Lx 1.6L 56 Reg Air Bag Light And Handbrake Light Fully Inpoerative (2 )
  143. Ford Focus 2002 Glow Plug Light Flashing (7 )
  144. 2012 Focus Titanium Chrome Dis Colored (10 )
  145. Engine Warning Light (3 )
  146. 2003 Focus Warped Front Brake Discs?? (3 )
  147. Mk1 Speedo Issue (12 )
  148. 1999 Focus Central Locking Module Replacment {Advice} (3 )
  149. Bluetooth Retrofit Help (20 )
  150. Engine Systems Fault Warning Light Help (4 )
Full Colour Version: Ford Focus Club
