Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88
  1. Couple Of Questions.. (7 )
  2. Newbie (Hi All ) Needs Focus Advice Pls (33 )
  3. Engine Swaping Query (18 )
  4. So Pleased With My Focus (11 )
  5. Temperature Guage Problem (6 )
  6. Servicing / Radio Code (4 )
  7. Just Fitted Electric Mirrors (5 )
  8. Car Feels Jerky/less Stable At Low Speed After Tyre Change (10 )
  9. Old St Or New? (9 )
  10. Strange Dash Fault? (3 )
  11. Nearside Drive Shaft Play At Gearbox End (10 )
  12. Mk1 Focus Engine Swap (4 )
  13. Just Bought A Bunch Of Stuff To Clean The Car... (34 )
  14. Immobiliser Light Flashing (2 )
  15. Bleeding Brakes (12 )
  16. Remap What's The Catch (27 )
  17. 59 Zetec S 1.8 Ipod Plug In ? (8 )
  18. A/c Condenser Replacement (6 )
  19. Recomended Mechanic/garage South East London? (3 )
  20. Engine Malfunction (7 )
  21. D P F Top Up? (7 )
  22. My Focus Mk2.5 Saloon (6 )
  23. Interior Bulbs (1 )
  24. Air Con (9 )
  25. Premium Petrol & Knock Sensor (7 )
  26. Passenger Footwell Flooded (9 )
  27. Broken Garage Door?? (59 )
  28. Focus Maintenance/repair Manuals For Download (4 )
  29. A Big Thanks (22 )
  30. Door Handle Scratches (6 )
  31. Remove Wax Before Fitting Scuff Plates? (11 )
  32. At Every Start A Sudden Noise Like A Spring Snapping (5 )
  33. Custom Temperature Controls Done (8 )
  34. Where Do I Get One (3 )
  35. New Focus (6 )
  36. Water Ingress Focus 2008 (3 )
  37. A/c Not Working (3 )
  38. Quick De-Badge Question (30 )
  39. Performance Upgrades (10 )
  40. Won't Go Into Gear! (16 )
  41. Mk2.5 Gear Stick Gaiter Clips (13 )
  42. St Pod Modified (6 )
  43. Plucked Up The Courage To Use The Vinyl Wrap :) (29 )
  44. Installing Additional 12V Accessory Socket For Dashcam (18 )
  45. Help - Strange Vent Noise! (19 )
  46. Ford Fair 2012 Pictures (0 )
  47. Dash Display/luggage Comp Open? (8 )
  48. 12V Sockets (11 )
  49. Mpg Trip Computer Problems, Turbo Failure (1 )
  50. Focus Tit X 1.0 (1 )
  51. 2007 Mirror (1 )
  52. Drive Shaft Problems Mk1 Focus (1 )
  53. How Much Psi? (7 )
  54. St170 Spring For Imrc Please Help (0 )
  55. Who Is Going (6 )
  56. Mk3 Led Sidelights (21 )
  57. M.o.t (7 )
  58. Mk3 Zs V's St Front End (9 )
  59. A Few Questions About My Focus Titanium 2008 1.6 Tdci (10 )
  60. Stolen Keys (9 )
  61. Wing Mirror 2.5 Focus (3 )
  62. My Focus St225 (7 )
  63. Ford Focus 1.8 Zetec Estate Over Revving. (3 )
  64. Broken Car... (31 )
  65. New Focus, Play Music From Memory Stick/usb (2 )
  66. Mpg On A 2.0L Focus (7 )
  67. Focus Estate Central Locking Problem (3 )
  68. Personal Injury Claim - Arrrghh!! (12 )
  69. God Knows How Much This Is Gonna Cost Me :( (20 )
  70. Focus Mk2 1.6 Timing Belt Make? (1 )
  71. Ford Focus Mesh Grill Mark1 (3 )
  72. Ford Focus Clutch Replacement Question (5 )
  73. Ford Focus Leaking All Of Its Water (2 )
  74. Focus Esp Mod Button-Completed (24 )
  75. Faulty Esp ? (11 )
  76. Glow Plugs (6 )
  77. Spare Key Question (2 )
  78. Focus Oil (6 )
  79. Mixing Semi Syn And Fully Synthetic Oil (4 )
  80. Slightly Lumpy Idle (10 )
  81. Whats Suposed To Be Behind The Ashtray Flap? (10 )
  82. Ford Focus 2001 Oil Change (3 )
  83. Just Test Drove The New St!!!! (17 )
  84. Painting Callipers Red... (65 )
  85. Replacement Locking Wheel Nuts (4 )
  86. Temp Guage Showing In The Red!!! (3 )
  87. You Will Never Guess What ='( ='( (51 )
  88. Black Box Scam (0 )
  89. Aircon Question (6 )
  90. Steering / Suspension / Bearings Concerns. (2 )
  91. Squeek When Turning Engine Off? (6 )
  92. Travelpilot Fx (9 )
  93. Satnav / Dvd Stereos (15 )
  94. Wiring More Power Outlets (8 )
  95. Re Painted Bonnet Lip On Focus Mk2.5 (11 )
  96. St170 Auto Air Deflector (1 )
  97. Best Oil For High Mileage Zetec (3 )
  98. Here's My Focus With The New Gel Badges And A Few Pics For Rh1O :) (107 )
  99. Whining Noise (49 )
  100. Starting Issues.. Grrr (12 )
  101. Rear Footwell Lights. Red. Thanks To Lenny :) (16 )
  102. Gear And Handbrake Gaiter Change (5 )
  103. Rubber Rubbing Noise (9 )
  104. Engine Systems Fault (35 )
  105. Throttle Body Swaps (0 )
  106. The Ultimate Green Focus For 2012 (2 )
  107. Mk 1 Focus Alloys (12 )
  108. Revise Schedule (2 )
  109. Anyone Fitted The Aluminium Pedals (43 )
  110. How Strong Is It? (2 )
  111. Ford Assist (2 )
  112. Focus Mk2 Map Light Bulbs??? (1 )
  113. Spare Tyre / Space Saver (28 )
  114. Mk2 Lowering Help (4 )
  115. Unable To Update - Very Annoying - Electrical Fault (1 )
  116. 150Ps And 182Ps In Titanium X (0 )
  117. Temp. Sensor (4 )
  118. My Ford Focus (23 )
  119. Alloy Wheel Search Help (5 )
  120. Coil Pack (0 )
  121. Headlight Trouble (1 )
  122. Filler Flap (7 )
  123. Which Brake Discs/pads? (0 )
  124. Low Windscreen Wash Warning Light/message (13 )
  125. Clicking Noise On Startup (5 )
  126. Dpf Removal And Ecu Remap Problem (8 )
  127. Door Lock Stuck/jammed (1 )
  128. Few Updates On My Focus. (34 )
  129. Will Ford Ever Learn? (3 )
  130. Rear Tyre Tread Wearing On The Inside (10 )
  131. Ford Focus 1.4Cl 2002 Problem Oil Spark Plugs (5 )
  132. Mk1 Exhaust! (2 )
  133. Mk1 Throttle Body Upgrade (0 )
  134. Egr Cooler (0 )
  135. Footwell Led's (Red) (2 )
  136. Exhaust Tips (19 )
  137. Pipe Under Bonnet (2 )
  138. My Mk2 Zetec Photos (27 )
  139. Ford Focus Ghia 03 Reverse Light Not Working.............. (3 )
  140. Pollen Filter (29 )
  141. Hello New Guy Few Questions (1 )
  142. Electric Issue When Changing Gear????? (1 )
  143. What Is This And Where Does It Go? [Pic] (4 )
  144. Factory Fit Sunroof (6 )
  145. Ford Focus 1.6 Lx Trouble Going Into 3Rd Gear (1 )
  146. 04 Focus - Fuel Guage Not Moving, Fuel Light Stays On! (1 )
  147. Front Interior Light Information Please. (4 )
  148. Fit Folding Wing Mirrors? (4 )
  149. Squeal On Startup (14 )
  150. Auto Lights (Of Sorts) (15 )
Full Colour Version: Ford Focus Club
