Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86
  1. Rear Fog Light Conversion (4 )
  2. Diesel Aux Heater (10 )
  3. Warning Light Comes On.. (0 )
  4. Warning Light Comes On.. (0 )
  5. Key Fob/ Blade Transponder Thingy Quiestion (Help Im So Confused!) (16 )
  6. What Is This Cable? (13 )
  7. Ford Focus 1.6Tdci (56) - Loss Of Power (22 )
  8. Angel Eyes For 08 Focus (11 )
  9. Changing Thermostat On 2006 1.6Lx (0 )
  10. Head Restraint Alternative (7 )
  11. Bulb Part Numbers Needed Focus Tdci 2006 (4 )
  12. Engine Temperature Never Quite Reaches Optimum Always Around 5-10 Degrees Off (5 )
  13. Ford Focus 2008 Mk 2.5 (Facelift) Aftermarket Hu (4 )
  14. Cambelt Cost (4 )
  15. Registration Plate Bolt Threaded Help Please! (10 )
  16. New Focus Titaniums ? What Price ? (2 )
  17. Mk1 Handbrake Cable (4 )
  18. Replacing Indicator Bulbs (2 )
  19. Focus Mk1 Boot Wiring Loom (4 )
  20. 1.8 Cdti Vs 2.0 Cdti (2 )
  21. Power Steering Fluid (1 )
  22. Any Help To Fix This Coolant Problem On Focus 2006 Hatchback Please? (6 )
  23. Wanted Tddi Injector Pump (3 )
  24. Power Steering Pump (0 )
  25. Possible Tdci Problem (4 )
  26. Help Please (0 )
  27. Just Looked At New Focus Zetec S (8 )
  28. Ford Focus Grill (1 )
  29. Stiff Front Suspension? (2 )
  30. Cant Open Bonnet.help!!! (7 )
  31. Not Turning Over In Cold Weather (5 )
  32. Courtesy / Map Light Upgrade (15 )
  33. Buying A Ford Focus 1.4 (1 )
  34. Cable Photography And Advice About A High Mileage Diesel Focus (6 )
  35. Condensation In Headlights And Rusty Doors (3 )
  36. Focus 2003 Ghia Steering Wheel (2 )
  37. Non-Running 2010 Ford Focus (25 )
  38. Reppiz's Build Thread: Ford Focus Tdci 1.6 Zetec (Climate Pack) (2 )
  39. Aluminium Sports Pedals? (4 )
  40. Where Do You Mount Your Phone/mp3 Player? (4 )
  41. Focus 1800 Zetec (25 )
  42. Cylinder Head Temp - Ford Focus (2 )
  43. Roaning Noise (3 )
  44. Stop Start Doesn't Work Very Often (45 )
  45. Mpg Horror Story? (8 )
  46. Abs And Traction Control Lights On! (0 )
  47. Oxygen Sensors (2 )
  48. Mpg For A 1800 Zetec (6 )
  49. Whirry Focus Auto! (0 )
  50. New Aluminium Pedals (4 )
  51. Water In The Well (1 )
  52. Dash/cluster/module Fault In 56 Plate Focus (6 )
  53. Focus 1.8 Sport (2006) - Turns Over But Wont Start (2 )
  54. O2 Sensors (0 )
  55. Door Cards How To?! (0 )
  56. St170 Gearstick Problem (0 )
  57. Bluetooth And Usb In Ford Focus! (2 )
  58. Trip Computer (4 )
  59. Focusclicking In Reverse (9 )
  60. Recommend A Good Website/company For Brakes And Disks (1 )
  61. Heating Problem 03 Focus. (2 )
  62. Tyre/wheel Size Help (0 )
  63. 1800 Zetec Timeing Marks (3 )
  64. Power Drain (2 )
  65. Ford Focus 1.8 V Reg Estate No Fuel Issue (1 )
  66. Mk3 Beeping (9 )
  67. Headlight Bulbs. (8 )
  68. Focus 2003 Front Speaker Template (0 )
  69. New Zetec S !!!!! (75 )
  70. Focus Built In Handsfree (8 )
  71. Door Locking (4 )
  72. Headlight Adjuster/motor Noise (2 )
  73. Passive Key (0 )
  74. Drivers Side Headlight Adjuster/motor Noise (0 )
  75. Dash Board & Rear Lights (2 )
  76. Upgrades (14 )
  77. Strange Chirp/beep (1 )
  78. Ford Focus 1.6 Shim Order (2 )
  79. Focus Mk2 Headlight Switch (16 )
  80. Ford Coolant (4 )
  81. New Project I'm Doing Next (24 )
  82. 1.8 Tdci Exhaust Smell In Cabin (1 )
  83. Focus 1999 Fuse Diagram (5 )
  84. Adding Drivers Side Roof Grab Handle (5 )
  85. Rear Wiper Problem (4 )
  86. Torque App With Obdii Bluetooth Scanner (2 )
  87. Seat Question (4 )
  88. Door Handle Leds (4 )
  89. 1.6 Tdci Engine Types (0 )
  90. Focus 1.6 Chic Advice ? (6 )
  91. Mk3 1.6 Ecoboost Tuning Box... (0 )
  92. Engine Warning Light On (13 )
  93. Focus Mk2 Estate Front End Grip + Dpf (9 )
  94. Rear Seatbelts Too Short - Longer Replacements Available ? (3 )
  95. Focus Titanium Ecoboost Price? (10 )
  96. Focus Mk 3 58 Plate Central Locking Query (2 )
  97. Starting Issue 56 Plate 2.0 Focus Ghia (2 )
  98. Locking Problems With Y Reg Ford Focus Estate (0 )
  99. 1.6Tdci Oil Change (2 )
  100. Engine Management Light On (54 Reg Tdci) (10 )
  101. Audio Equipment Issues (0 )
  102. Engine Malfunction Warning (2 )
  103. 1.4 Milage (7 )
  104. Please Help (13 )
  105. Mk3 Tech That Isn't Quite Up To Scratch (9 )
  106. Rear Hub Nut Size (0 )
  107. Another Problem - Bunny Hopping, No Burning Smell? (11 )
  108. Fuel Filter Upgrade (5 )
  109. No Engine Cover (9 )
  110. Speedo Mileage Illumination (2 )
  111. Advice Regarding Replacing An Srs Module (3 )
  112. New Focus Sat Nav (93 )
  113. Mk2 Focus 1.8 Tdci Ghia/zetec Climate (Buying Advice) (4 )
  114. Focus 1.8 Turbo Diesel Black Smoke (7 )
  115. Timing Belt (0 )
  116. Mk 1 Ford Focus Won't Start (6 )
  117. Help With Diesel Fuel Consumption Please (10 )
  118. Focus St-3/st-2 (2 )
  119. Reverse Camera Problem? (10 )
  120. Bulb Light Changing (40 )
  121. Broken Tailgate Handle (9 )
  122. Adding Stereo Steering Wheel Remote (14 )
  123. Plug And Play Power? (10 )
  124. St170 -Vs- Civic Type-R (3 )
  125. Wheel Rubbing On St170 (2003) (6 )
  126. Proud New Owner! (3 )
  127. Wheel Whine (7 )
  128. Colour Coding (5 )
  129. Electrics (5 )
  130. Information About Focus Mkiii? (1 )
  131. Zetec S Body Part Numbers (11 )
  132. Dtuk Tuning Box (2 )
  133. Central Locking Problem? (6 )
  134. Mk3 Mods... (3 )
  135. Steering Pulls To Left (7 )
  136. Start Button (11 )
  137. Radio Interference (0 )
  138. Hissing Brake Pedal (1 )
  139. 1999 Focus Bonnet Wont Open (1 )
  140. Drivers Door, Central Locking Problem (1 )
  141. Ford Focus Central Locking (3 )
  142. Noise From Below, 2005 1.6Tdci Focus (4 )
  143. What Oil? (9 )
  144. Anti Freeze (3 )
  145. Radio 6000Cd With Phone (2 )
  146. New Focus Titanium - Soon To Be Owner (5 )
  147. Transmission Cooling Light And Engine Management Light Flashing On (0 )
  148. Just Got My Focus Back...some Questions/help Needed (0 )
  149. Groaning When Pulling Away (0 )
  150. Unable To Fill Focus With Diesel (7 )
Full Colour Version: Ford Focus Club
