Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88
  1. 2012 Focus Headlight Condensation (3 )
  2. Coil Packs (5 )
  3. passenger footwell wet (7 )
  4. St 170 Got This Code P1518 Something About Inlet Flaps Stuck Open (2 )
  5. Mk2 Focus Tdci Build/mod Thread (34 )
  6. Dab Unit To Replace A Standard Radio (2 )
  7. Leaking Yellow Air Con Lube Focus Mk1 2.0 16V (0 )
  8. Few Focus Issues (0 )
  9. 1.8 Tdci Turbo Hose Pipe (3 )
  10. Mk3 Cruise Control ' Stutter' (1 )
  11. De Cat Focus St 170 Is It Worth It (4 )
  12. Mpg Focus St 170 Wat Mpg Do You Get Or How Much Miles Per Tank (3 )
  13. How Do I Adjust Door Striker Etc To Make Doors Seal Better (2 )
  14. Tyre Pressure Monitor Titanium Help (9 )
  15. Focus Zetec (1 )
  16. Badge Overlays. (2 )
  17. 17's On 15's???? (5 )
  18. 2008 Focus Dashboard Display Units Of Measurement (4 )
  19. Rear Reg Lights Legal? (11 )
  20. Should I Buy Or Is This A Bad Move? (Please Help) (8 )
  21. Wiper Blades (8 )
  22. Personalised Number Plates (4 )
  23. Pictures In Topic (3 )
  24. Oil Sump Plug (5 )
  25. Additional Speakers... (5 )
  26. Few Questions (10 )
  27. Starting Issuel (1.8 Petrol) Focus Titanium (24 )
  28. Help Please:s Airbag Light On (3 )
  29. Which Fuel (2 )
  30. Cold Starting Problem For The 1.8 Tdci (0 )
  31. Diesel Vs Petrol? (19 )
  32. Laguna Alloys Fitment Query Advice Wanted (11 )
  33. Dab Radio Tuning (10 )
  34. Aux Belt Noise Help (17 )
  35. Sluggish When Moving From Standstill (2 )
  36. Attention Ford Focus 1.6 Tdci Dpf Owners (1 )
  37. Mk 3 Audio Controls (3 )
  38. Heated Rear Window (1 )
  39. Window Tinting (27 )
  40. Can You Help Identify A Part? Electric Window Problem (0 )
  41. Has Anyone Fitted One Of These Cd Players.......? (1 )
  42. Re-Align Wing Mirrors For 2005 Focus Titanium 1.8Tdci Etc... (3 )
  43. 2005 Ford Focus Power Drain (8 )
  44. New Focus Help (2 )
  45. Warning Light Comes On.. (9 )
  46. Occasional Problems With Starting (0 )
  47. Rear Fog Light Conversion (4 )
  48. Diesel Aux Heater (10 )
  49. Warning Light Comes On.. (0 )
  50. Warning Light Comes On.. (0 )
  51. Key Fob/ Blade Transponder Thingy Quiestion (Help Im So Confused!) (16 )
  52. What Is This Cable? (13 )
  53. Ford Focus 1.6Tdci (56) - Loss Of Power (22 )
  54. Angel Eyes For 08 Focus (11 )
  55. Changing Thermostat On 2006 1.6Lx (0 )
  56. Head Restraint Alternative (7 )
  57. Bulb Part Numbers Needed Focus Tdci 2006 (4 )
  58. Engine Temperature Never Quite Reaches Optimum Always Around 5-10 Degrees Off (5 )
  59. Ford Focus 2008 Mk 2.5 (Facelift) Aftermarket Hu (4 )
  60. Cambelt Cost (4 )
  61. Registration Plate Bolt Threaded Help Please! (10 )
  62. New Focus Titaniums ? What Price ? (2 )
  63. Mk1 Handbrake Cable (4 )
  64. Replacing Indicator Bulbs (2 )
  65. Focus Mk1 Boot Wiring Loom (4 )
  66. 1.8 Cdti Vs 2.0 Cdti (2 )
  67. Power Steering Fluid (1 )
  68. Any Help To Fix This Coolant Problem On Focus 2006 Hatchback Please? (6 )
  69. Wanted Tddi Injector Pump (3 )
  70. Power Steering Pump (0 )
  71. Possible Tdci Problem (4 )
  72. Help Please (0 )
  73. Just Looked At New Focus Zetec S (8 )
  74. Ford Focus Grill (1 )
  75. Stiff Front Suspension? (2 )
  76. Cant Open Bonnet.help!!! (7 )
  77. Not Turning Over In Cold Weather (5 )
  78. Courtesy / Map Light Upgrade (15 )
  79. Buying A Ford Focus 1.4 (1 )
  80. Cable Photography And Advice About A High Mileage Diesel Focus (6 )
  81. Condensation In Headlights And Rusty Doors (3 )
  82. Focus 2003 Ghia Steering Wheel (2 )
  83. Non-Running 2010 Ford Focus (25 )
  84. Reppiz's Build Thread: Ford Focus Tdci 1.6 Zetec (Climate Pack) (2 )
  85. Aluminium Sports Pedals? (4 )
  86. Where Do You Mount Your Phone/mp3 Player? (4 )
  87. Focus 1800 Zetec (25 )
  88. Cylinder Head Temp - Ford Focus (2 )
  89. Roaning Noise (3 )
  90. Stop Start Doesn't Work Very Often (45 )
  91. Mpg Horror Story? (8 )
  92. Abs And Traction Control Lights On! (0 )
  93. Oxygen Sensors (2 )
  94. Mpg For A 1800 Zetec (6 )
  95. Whirry Focus Auto! (0 )
  96. New Aluminium Pedals (4 )
  97. Water In The Well (1 )
  98. Dash/cluster/module Fault In 56 Plate Focus (6 )
  99. Focus 1.8 Sport (2006) - Turns Over But Wont Start (2 )
  100. O2 Sensors (0 )
  101. Door Cards How To?! (0 )
  102. St170 Gearstick Problem (0 )
  103. Bluetooth And Usb In Ford Focus! (2 )
  104. Trip Computer (4 )
  105. Focusclicking In Reverse (9 )
  106. Recommend A Good Website/company For Brakes And Disks (1 )
  107. Heating Problem 03 Focus. (2 )
  108. Tyre/wheel Size Help (0 )
  109. 1800 Zetec Timeing Marks (3 )
  110. Power Drain (2 )
  111. Ford Focus 1.8 V Reg Estate No Fuel Issue (1 )
  112. Mk3 Beeping (9 )
  113. Headlight Bulbs. (8 )
  114. Focus 2003 Front Speaker Template (0 )
  115. New Zetec S !!!!! (75 )
  116. Focus Built In Handsfree (8 )
  117. Door Locking (4 )
  118. Headlight Adjuster/motor Noise (2 )
  119. Passive Key (0 )
  120. Drivers Side Headlight Adjuster/motor Noise (0 )
  121. Dash Board & Rear Lights (2 )
  122. Upgrades (14 )
  123. Strange Chirp/beep (1 )
  124. Ford Focus 1.6 Shim Order (2 )
  125. Focus Mk2 Headlight Switch (16 )
  126. Ford Coolant (4 )
  127. New Project I'm Doing Next (24 )
  128. 1.8 Tdci Exhaust Smell In Cabin (1 )
  129. Focus 1999 Fuse Diagram (5 )
  130. Adding Drivers Side Roof Grab Handle (5 )
  131. Rear Wiper Problem (4 )
  132. Torque App With Obdii Bluetooth Scanner (2 )
  133. Seat Question (4 )
  134. Door Handle Leds (4 )
  135. 1.6 Tdci Engine Types (0 )
  136. Focus 1.6 Chic Advice ? (6 )
  137. Mk3 1.6 Ecoboost Tuning Box... (0 )
  138. Focus Mk2 Estate Front End Grip + Dpf (9 )
  139. Rear Seatbelts Too Short - Longer Replacements Available ? (3 )
  140. Focus Titanium Ecoboost Price? (10 )
  141. Focus Mk 3 58 Plate Central Locking Query (2 )
  142. Starting Issue 56 Plate 2.0 Focus Ghia (2 )
  143. Locking Problems With Y Reg Ford Focus Estate (0 )
  144. 1.6Tdci Oil Change (2 )
  145. Engine Management Light On (54 Reg Tdci) (10 )
  146. Audio Equipment Issues (0 )
  147. Engine Malfunction Warning (2 )
  148. 1.4 Milage (7 )
  149. Please Help (13 )
  150. Mk3 Tech That Isn't Quite Up To Scratch (9 )
Full Colour Version: Ford Focus Club
