Full Version: Ford Focus Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85
  1. Using Lots Of Oil. (5 )
  2. Focus Engine Problems (6 )
  3. Anyone On Twitter ? (0 )
  4. Washer Jets Spraying Away From Window (5 )
  5. How To Register / Join (2 )
  6. Mk1 Gearbox Id (2 )
  7. Quick Clear Earth Strap (8 )
  8. Pre Heat Light ?? (3 )
  9. Thermostat Change Help (3 )
  10. Rims (1 )
  11. 05-08 Steering Wheel (5 )
  12. Diesel Focus 1.8Tddi 1999 (6 )
  13. Fitting Optional Cd Changer (2011 Registered Mk2.5) (1 )
  14. 1.6 Zetec - 2.0 Zetec R Upgrade (0 )
  15. Stereo Upgrade Options (1 )
  16. Pioneer Avic-F9220Bt (1 )
  17. Im Having The "time Of The Month" (1 )
  18. New Focus Pedals. (3 )
  19. Bulbs Blowing (3 )
  20. show off your 5 door foci!!! (28 )
  21. Front Lower Rear Wishbone Bushes (0 )
  22. In Phase Car Audio Head Unit (4 )
  23. Ice Swap (2 )
  24. Click Sound (8 )
  25. Central Locking Issues Please Help! (0 )
  26. 1.6 Tdci Clutch Height And Engine Noise (6 )
  27. Air Conditioning (13 )
  28. Engine Management Light (3 )
  29. Ford Focus Estate Tdci 1.6? (6 )
  30. 1.8 Tdci (4 )
  31. Installing A Parrot Mki9100 (3 )
  32. Hanging Rev's On 1.6 Zetec (6 )
  33. Focus Titanium Sports Pack (3 )
  34. Mk2 Estate Tailgate Glass Replacement (1 )
  35. Bad Smell Coming From Vents (9 )
  36. Album Artwork On New Focus Audio (18 )
  37. Misfire (4 )
  38. Trip Computer Light (3 )
  39. New Focus - Voice Control Of Aircon (6 )
  40. Noisy 1.8Td (2 )
  41. Jay Leno And Jimmy Carr Enjoy Long-Distance Chat Using In-Car Wifi (2 )
  42. Coil Pack Trouble Cylinder 4 Misfire Help (3 )
  43. Changing My Car Advice Please (16 )
  44. Temp Gauge (3 )
  45. Slow To Get To Temp (1 )
  46. Changing Drivers Side Mirror (4 )
  47. 1.6 Tdci Tuning Box Do They Work (11 )
  48. Any Advice/hep Would Be Appreciated. (2 )
  49. Please Please Help (3 )
  50. Help Please! (9 )
  51. Cleaned Today After 1 Wk Old ! (18 )
  52. 1.8 Poor Fuel Consumption (3 )
  53. What Are The Best White Look /xenon Headlamp Bulbs ? (0 )
  54. Focus Diesel Thermostat (9 )
  55. Led Side Lights (5 )
  56. Radiator Fan (1 )
  57. Dash Storage (21 )
  58. Changing An Iac Valve (5 )
  59. New Focus Auto Clkmate Control ? (8 )
  60. 2003 Tdci Cut Out And Non Start (0 )
  61. 2007 Ghia - Dashboard Top Compartment Spring (1 )
  62. Headlight Bulb (1 )
  63. Rear Washer Leaking Into Boot (6 )
  64. Turbo Problems (1 )
  65. Sd Card Music With Built In Sat Nav (3 )
  66. Jingles Zetec S (9 )
  67. Windy Noise Whilst Driving (3 )
  68. Interior Lights (17 )
  69. Focus Temperature Gauge Issue (62 )
  70. Steering Clunk (2 )
  71. Picked Up My New Focus (30 )
  72. Help - Noisey Stretch Belt (2 )
  73. New Focus Zetec S (8 )
  74. 99' Focus Rear Disc Brakes (8 )
  75. Haynes Manual For Focus Facelift (6 )
  76. Throttle Position Sensor (4 )
  77. Radio/sat Nav Unit (2 )
  78. Headlight Warning Tone (2 )
  79. Disconnecting Negative Battery Cable When Car Is Running (19 )
  80. New Focus - No Engine Cover ? (4 )
  81. Known Faults And Things To Look Out For (2 )
  82. Could This Be Causing A Leak? (7 )
  83. Key Remote Problems (10 )
  84. What Are The Gear Ratios For A 1.6Tdci Old Shape Focus (4 )
  85. Facelift 2008 Focus Lower Grille (13 )
  86. 1.8 Tdci Estate Notchy Steering (1 )
  87. Water Leaking Into The Boot (6 )
  88. Focus Unwell (21 )
  89. Focus Tdci 1.8 Sport , Cold Starting Problem (8 )
  90. Heated Screen Only Works One Side (7 )
  91. Idle Control Valve (4 )
  92. Focus Steering (4 )
  93. Dtc 9202 Fuel Sender Open Circuit (8 )
  94. What Is This & Should It Be Connected? (6 )
  95. Disable Alarm (10 )
  96. 2008 Focus Chasis Rail (3 )
  97. Stained Centre Console Help (4 )
  98. Focus Auto Gearbox Advice (0 )
  99. Engine Management & Juddering (2 )
  100. Warning Light And Power Loss (3 )
  101. Door Rattle (2 )
  102. New Shape Focus Bulbs ? (0 )
  103. Engine Management (2 )
  104. Mk1 Spark Plug Gap (10 )
  105. 03 1.8Tdci Service (5 )
  106. 2.0Tdci Clutch Replacement (9 )
  107. Change Hwadlight Bulbs On New Focus !! (5 )
  108. Ford Focus (4 )
  109. Clutch Help (4 )
  110. Ford Focus (0 )
  111. Pics Uploaded (2 )
  112. Tdc (2 )
  113. Weird Rpm. (7 )
  114. Clutch Worries (2 )
  115. Red Light (3 )
  116. Feels Slower After Service (32 )
  117. No 5Th Gear (0 )
  118. Focus Ghia (5 )
  119. Cylinder Head Question (1.6 16V, 2001) (1 )
  120. Broken Drivers Seat Part On 06 Lx (1 )
  121. Zetec S Seats (0 )
  122. Ford Focus 2.0 Zetec Problem (1 )
  123. Focus 1.6 Zetec Misfire (1 )
  124. Fuel Filter On Mk 2.5 Focus (3 )
  125. Boot Lights (7 )
  126. Stone Chips Focus Mk3 (2 )
  127. Focus 2004 Bonnet Only Opens A Little (3 )
  128. Whats This Part Called---It Rattles/knocks (3 )
  129. Restore Engine Treatment (5 )
  130. What Are The Options After A Dpf Issue (4 )
  131. Melted Leather Steering Wheel Focus Zetec 52 Reg (1 )
  132. Steering Assist Failure (1 )
  133. Help! Ghost Under My Bonnet!!!! (0 )
  134. Td (0 )
  135. Help (8 )
  136. 06 Focus 1.8Tdci Abnormal Turbo Noise (7 )
  137. Focus Push Start Button (1 )
  138. Focus Drl Lights (1 )
  139. Keyless Entry And Push Button Start (7 )
  140. Need Help With Cd Player Code Please :-) (0 )
  141. Dissapointing Ecoboost Economy (21 )
  142. Lights Or Reflectors - New Focus (1 )
  143. Leather Steering Wheel Bubbled (3 )
  144. Bought A Mk2 (6 )
  145. Ford Flip Key Flopping (11 )
  146. Change Radio (13 )
  147. Juddering And Lose Of Power (6 )
  148. Ford Focus Not Starting Every Time (0 )
  149. What Models Have Front Screen Quick Clear ? (4 )
  150. 06 Focus 1.8Tdci Water Pump (0 )
Full Colour Version: Ford Focus Club
