Full Version: Ford S-Max Club
Pages: 1, 2, 3
  1. Pinned: smax official trouble topic (65 )
  2. Pinned: newbei questions (13 )
  3. Activity Kit (0 )
  4. Stereo Dilemma. (17 )
  5. Air Filter Replacement (1 )
  6. Headrest Dvd Lcd Screen (5 )
  7. Passenger Door Won't Unlock With Remote Fob (6 )
  8. Bike Carrier / Tow Bar For S-Max (7 )
  9. Noisey Fan Motor, Being Sold A Pack Of Lies By Dealer (14 )
  10. 2011 Smax Occasional Knocking Noise - Video Inside! (7 )
  11. Cycle Carrier (1 )
  12. Auto Box On 09 2Litre D (2 )
  13. Cant Get In My Car- Help Please (1 )
  14. Bonnet Release Cable Snapped (9 )
  15. Roof Bars - Lost Mounting Bracket (2 )
  16. Replacing A 2008 2.2 Tdci Engine Injector & Pump Question (9 )
  17. Thule/other Roof Rack For S-Max (2 )
  18. S-Max Spare Wheel (13 )
  19. Power Fold Mirrors (1 )
  20. Is Buying An Old Very High Mileage S-Max A Massive Gamble? (7 )
  21. Ford S-Max Steering Wheel Not Turning All The Way Right (2 )
  22. Steering Locking-Up (0 )
  23. 18 Inch Wheels & Tramlining (3 )
  24. Replacing The 6006Cdc Stereo - Help Needed (7 )
  25. Streaky/blank Central Display (8 )
  26. White Smoke And Rough Idle On First Start (0 )
  27. Where Is Rear Fusebox! (1 )
  28. Ford S-Max 2011 Drl L+R (1 )
  29. Ford Smax Active Suspension (0 )
  30. Changing Speaker In Rear Door (0 )
  31. Will A 2012 Smax Titanium Wheel Fit A 2006 Smax Zetec?? (1 )
  32. Will 2012 S Max Titanium 17 Inch Wheels Fit A 2006 S Max Zetec? (2 )
  33. 2.0 Tdci Struggling To Start (4 )
  34. Which Software Obd. (14 )
  35. Dual Mass Flywheel (4 )
  36. Engine Malfunction Loss Of Power (5 )
  37. Bluetooth (3 )
  38. Problem With Alarm Sounduing And Front Wipers Not Working (10 )
  39. Faulty Tail Light (2 )
  40. Engine Warming (2 )
  41. Smax 2.0 Tdci Boot Area Water Ingress (6 )
  42. Ford S Max Dual Mass Flywheel (4 )
  43. S-Max Aircon Faulty Since Service? (8 )
  44. S-Max Tailgate Lock & Warning (0 )
  45. Low Mpg On My Smax (3 )
  46. Warning Light (5 )
  47. Wiring A Headrest Dvd System Into Fuse Box - S Max (4 )
  48. Ford S Max Full Computer Diagnosis (4 )
  49. S Max Front Headrests (3 )
  50. Help! Diesel In Engineoil !!! (9 )
  51. Which Jack Kit For The S Max (9 )
  52. S Max - Spacesaver To Fit 18" Titanium Alloys (8 )
  53. Speedometer Is Showing 0 Mph All The Time! (9 )
  54. '07 Temp Gauge And Heater Issues (4 )
  55. Ford S-Max Where Do These Hose Connects. (0 )
  56. Anyone Know What This Part Is Called. (30 )
  57. S-Max Wipers On Permanently (8 )
  58. Ford S-Max Won't Start Or Even Fire Up (4 )
  59. Low Washer Fluid Level Warning (1 )
  60. Replacement Key (7 )
  61. Dab With Nav System In 2012 Smax? (1 )
  62. Not Workin (2 )
  63. Ford S-Max Gearbox Stud Hole Broken (9 )
  64. Trouble Starting S Max (5 )
  65. Changing Unlock So It Opens All Doors On A Single Press (8 )
  66. Luggage Cover (5 )
  67. Convers+ (35 )
  68. Thinking Of An S Max 2.0 Tdci (3 )
  69. Diy Oil An Filter Change (8 )
  70. S-Max Roof Bars For Non-Panoramic Roof - Will They Fit Panoramic Sunroof? (2 )
  71. S-Max Water In Passenger Footwell (More Like A Pond) (2 )
  72. Smax Sport X Bi Xenon (0 )
  73. Non Linear Throttle Response. (2 )
  74. Tyre Load Rating (4 )
  75. Winter Wheels Sizes (0 )
  76. Reversing Camera (1 )
  77. Snow Chains / Spare Tyre And Going Abroad Advice (2 )
  78. Noisy Steering (2 )
  79. Smax 2.0 Tdci Water Leak (2 )
  80. Transmission Fault (8 )
  81. X Sport (203) Engine Malfunction / Transmition Failure (3 )
  82. S-Max Pollen/cabin Filter - How To Change It? (9 )
  83. Whining Noise When Running (2 )
  84. Smax Battery Drain (7 )
  85. S-Max 2.0 Tdci 163 Powershift Transmission Fault (0 )
  86. Heater *mostly* Blowing Cold (1 )
  87. Key Not Detected (1 )
  88. S-Max Headlights (2 )
  89. Near Side Headlight Unit Not Working (5 )
  90. Drl (5 )
  91. Led Puddle Lights 501 (5 )
  92. Smax Premature Exhaust Failure (14 )
  93. S-Max Clutch (0 )
  94. Coolant Leaking (5 )
  95. Whole List Of Problems. (3 )
  96. Engine Management Light On (2 )
  97. Oil Leak/smoke? (2 )
  98. S Max Cruise Control Problem (3 )
  99. Fault Code P2187 (8 )
  100. Problem With My S Max 1,8 Tdci (3 )
  101. Retrofit Bluetooth / Voice Control. (5 )
  102. Engine Hesitation And Juddering, Any Ideas? (4 )
  103. S-Max (5 )
  104. Cam Belt Or Chain (3 )
  105. S-Max With 1.6Tdci 115 Engine (0 )
  106. Help Needed Please (3 )
  107. Sat Nav/radio Fault (6 )
  108. I'm A Ford Master Tech (3 )
  109. New Dvd Nav Disc & Headlight Malfunction & Seatbely Rattle. (2 )
  110. Sony Dab Radio (2 )
  111. Dvd Colour Sat Nav (2006) Bluetooth Gone! (3 )
  112. Cutting Out Problem (5 )
  113. Ford Smax - Engine Hesitation At Approx 1800 To 2500 Revs (3 )
  114. Help Accessing Usb Port In S-Max (2 )
  115. Power Steering (8 )
  116. Another Starting Problem With S Max (1 )
  117. Heated Windscreen Partially Working (8 )
  118. Fuel Filler Flap (3 )
  119. Exhaust Problem - 2011 S-Max (2 )
  120. Is A Parcel Shelf Standard (3 )
  121. Keyfob Reprogramming (5 )
  122. Handbrake Broken? (1 )
  123. Power Steering - We Think? (2 )
  124. S-Max Changing Rear Brake Pads (3 )
  125. S Max/ Focus St Alloy Swap (3 )
  126. Ice Problem (6 )
  127. S-Max 56 Fly Wheel Problem (7 )
  128. 07 S-Max Engine Problem, Please Help! (2 )
  129. S-Max Starting Problem (7 )
  130. Headlight Adapters For Driving On Ohe Right (5 )
  131. Radio Upgrade... (3 )
  132. Rotten Exhaust On My S Max (2 )
  133. 'engine Warning Light' On (3 )
  134. 60,plate Smax Engine Problems (2 )
  135. Smax Not Starting 1St Time, Cruse Control Not Working (3 )
  136. Engine Malfunction And Yellow Traction Controle Light (4 )
  137. Driver Elec Window Help (3 )
  138. S-Max Bonnet Latch Problems (20 )
  139. Headrest Dvd Lcd Screen (1 )
  140. Daytime Running Lights (13 )
  141. Fuel Pressure Senor (0 )
  142. Spare Wheel (13 )
  143. Just Orange Line At Bottom Of Computer Display (8 )
  144. Glow plug light (8 )
  145. 07 Smax 2.0 Tdci Starting Woes (4 )
  146. Middle Row Seat Belt Height Problem (0 )
  147. Puddle Light Replacement (2 )
  148. 2.0Tdci Help Please? (10 )
  149. Configure sat nav from kms to miles? (1 )
  150. Brighter Day Light Running Lights (4 )
Full Colour Version: Ford S-Max Club
