Full Version: Ford C-Max Club
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford C-Max Club
Pages: 1, 2, 3
  1. Pinned: Fix Boot Lid Lock Random Opening Problem (13 )
  2. Iphone And Bluetooth (0 )
  3. C-Max Drl - How To (2 )
  4. Lookong At Getting A C Max (7 )
  5. High Fuel Consumption (6 )
  6. Gears Jamming When Trying To Change (4 )
  7. Killed My Bus... Oops! (5 )
  8. What's This Noise? (Video Included) (25 )
  9. Electric Windows (10 )
  10. Moved: Brake And Abs Flash Randomly (-- )
  11. Focus C Max Zetec Tdci - Timing Belt Issues? (1 )
  12. 2005 C-Max Engine Wont Start (0 )
  13. High Brake Light (2 )
  14. What's This Connector? (2 )
  15. Engine Light (4 )
  16. Installing Parking Sensors (7 )
  17. Bumper Seperation? (2 )
  18. Which Diesel Engined C-Max To Go For? (5 )
  19. Cmax Throttle Not Responding Correctly (0 )
  20. 07 Focus C-Max 1.6 Tdci Style Has Wrong Steering Wheel (2 )
  21. Focus C-Max Egr Valve Aaaargh! (6 )
  22. Replacing Washer Bottle Neck (2 )
  23. 2010 C Max Diesel (3 )
  24. Gear Box (3 )
  25. Red Stereo But Green Cluster Backlighting...is This Right? (7 )
  26. Soggy Carpets In C Max! (1 )
  27. Help Please (1 )
  28. Water Ingress Issue (10 )
  29. Ford Cmax Steering/braking Vibrations (4 )
  30. Nightmare - Major Advice Needed! (17 )
  31. Does This Fit? (11 )
  32. Ford C Max 2.0 Tdci 2012 Help Please (7 )
  33. Over-Revving C-Max 2004 (1 )
  34. Spare Bulbs Set (3 )
  35. Epb Numbers (2 )
  36. Engine Management Warning Lights (5 )
  37. Ford C Max 1.6 Tdi 54 Plate Cutting Out !!!!!! (19 )
  38. Whirring Noise At High Speeds (7 )
  39. C Max Not Max Power (4 )
  40. C-Max Passenger Seat Plastic Trim (5 )
  41. Keyfob Problem (6 )
  42. Cant Remove Headlight Assembly... (6 )
  43. Cmax 2004 2L Tdci Timing Belt Oe Serial Number? (0 )
  44. Parking Sensors For C-Max (2 )
  45. Downloadable Manual? (5 )
  46. 1 Litre Ecoboost God For Towing Small Trailler (4 )
  47. 2005 Cmax Audio/bluetooth System (4 )
  48. Focus C-Max Electrics ? (1 )
  49. C-Max 2.0Tdci Lumpy On Acceleration (3 )
  50. Focus C MAx 1.8 Zetec poor idling and stalling (1 )
  51. Ford Focus Cmax Blowing Black Smoke (1 )
  52. 1.8 C Max Duratec Petrol Plz Help (3 )
  53. Mk1 53 Plate C-Max Gone Into Engine Idle Mode (2 )
  54. Cmax 1.8 Duratec Judder Or Miss Fire? (3 )
  55. Air Filter (0 )
  56. C-Max Ignition Barrel Key (3 )
  57. Cmax 2.0 Tdci (0 )
  58. Cmax 2.0Tdci Burning Smell (0 )
  59. Battery Light On (4 )
  60. Dual Mass Flywheel (3 )
  61. Jack And Axle Stand Advice (2 )
  62. New Member - General & Specific Cmax Advice Please. (0 )
  63. CD6000 aux in (2 )
  64. 1.6 Or 1.8 Zetec Petrol? (2 )
  65. Cigarette Lighter Not Working (3 )
  66. Dab Aerial (0 )
  67. Rear Window Spoiler (0 )
  68. Key Won't Open Car (2 )
  69. Clutch Burning Around Town And Gearbox Crunching (2 )
  70. Cmax 1.6 Petrol Mpg (3 )
  71. Eac Fail Message On Dash (1 )
  72. Ford C- Max Radio Problems (Turns On Randomly) (0 )
  73. 2004 Focus C-Max 2.0 Tdci Laptop Interface (1 )
  74. Acceleration Noise (1 )
  75. Ford C Max Miles Per Gallon Question Fuel Consumption (3 )
  76. Fuse Box And Fuse Number Equipment Info (8 )
  77. Cam Belt Change?? (5 )
  78. Air Con Quandry (2 )
  79. C-Max Sat Nav Traffic Messages (0 )
  80. Front Wheel Bearings (14 )
  81. Air Con Flooded ????? (2 )
  82. Oil Low Again...garage Predicts Major Problems Soon (9 )
  83. Irritating rear end rattle (8 )
  84. Esp Light On Dashboard (0 )
  85. Ford Cmax 2004 Tdci 2L Hestiation Problem (0 )
  86. Bike Rack (0 )
  87. Car Alarm (1 )
  88. New Owner Needs Some Advice Please (9 )
  89. Starting Probz (6 )
  90. New Owner - Bluetooth - Installed Or Not (1 )
  91. Flashing Red Light On Dash (0 )
  92. Lower Front Grill (0 )
  93. Spare Key (2 )
  94. Battery Drain On Focus C-Max 53 Plate Petrol (8 )
  95. Leaking Boot (2 )
  96. Wing Mirror Light (2 )
  97. Overheating Tdci (0 )
  98. Radio Removal (2 )
  99. Help With Location Off Gem And Kvm (0 )
  100. Remote Control Locking (5 )
  101. Engine Fault Light (1 )
  102. Automatic Windscreen Wipers, Electric Heated Windscreen (7 )
  103. Airbag On Constant But Not Always ? 2004 Cmax (3 )
  104. Shudder And Bang (4 )
  105. Cooling Fan Replacement (0 )
  106. Display Units For Trip Odometer (0 )
  107. Removal And Fitting New Sump Pan On 2004 2.0L Diesel Tdci (1 )
  108. Headlight (0 )
  109. Dash Problem (0 )
  110. C Max Modding Any Ideas (0 )
  111. Driver Seat Wobbles (0 )
  112. Picked Up My New Cmax 2011 (3 )
  113. My Car Hates Me. (1 )
  114. Strange Blowing Noise (2 )
  115. C-MAX TDCi Power Loss (49 )
  116. Sony Dab Radio In C-Max Titanium (1 )
  117. Auto Door Locking When Parked? (3 )
  118. Non Start Help (2 )
  119. New Clutch Judder (1 )
  120. Glow Plug Relay (6 )
  121. Diagnosing Smart Charge (12 )
  122. C Max Help Required Please (0 )
  123. Servicing Costs (3 )
  124. Daylight Running Lights (0 )
  125. Front Windscreen Blowers Not Very Powerful (1 )
  126. Water Gurgling Under Dashboard (0 )
  127. Removing Radio (7 )
  128. Diesel Particulate Filter (0 )
  129. Need Radio Keycode Please, Details Inside :) (3 )
  130. Towbar Wiring (2 )
  131. Bottom Half Of Heated Rear Window Not Working (3 )
  132. Sony Sat Nav (0 )
  133. Ford C Max Poor Fuel Economy Need Some Help (0 )
  134. C-Max Steering Problem .. (0 )
  135. P2008 Intake Manifold runner control circuit (1 )
  136. My C-Max Is So Thirsty (0 )
  137. Parking Sensors Question (0 )
  138. Green Lit Odomoter Display...is This Normal?? (1 )
  139. Urgent : Jaguar Wheels On Cmax? (0 )
  140. Rear Wheel Noise (1 )
  141. Phone Button. (2 )
  142. Cvt Fault Facts Request. (2 )
  143. Dpf Tank Fill And System Reset (4 )
  144. Ford C-Max 2.0 Tdci Ghia Eu4 Mpg (3 )
  145. cmax auto gearbox swap (22 )
  146. Bearing Squeal - No A/c (1 )
  147. Gear Change Light. (1 )
  148. Bonnet Release (0 )
  149. C Max Stereo Code (1 )
  150. Sun Blind Clip For C-Max (0 )
Full Colour Version: Ford C-Max Club
