Help
Members
Calendar
Full Version:
Ford C-Max Club
United Kingdom - General Ford Discussions by Model
Ford C-Max Club
Pages:
1
2
3
P0047 Fault
(2 )
Split Turbocharger Outlet Hose
(4 )
Focus C-Max 1.6 Tdci (Manual)
(0 )
Missing Sensor?
(0 )
Dash Board Display
(1 )
Battery Light Stuck On Dash
(3 )
Window Mechanism Removal
(0 )
Powershift Or Manual
(19 )
Engine Coolant Temperature
(2 )
C-Max Roof Bars
(0 )
Cvt History And Fluid Change
(10 )
Clutch Issue
(1 )
Aircon Condensor Replacement
(0 )
Cvt Trans Fluid
(2 )
Hoping For A Simple/cheap Cure!
(0 )
Overheating Focus Cmax When Pulling Caravan
(2 )
Ecu Problem
(1 )
Bonnet Release Catch Issues
(0 )
Pcm Problems
(1 )
Fuses In The Fuse Box
(0 )
Help - Cmax Bonnet Wont Open !
(4 )
towing with C-max
(4 )
MPG Units in KM
(1 )
voice commands
(4 )
C-Max Glow Plug Warning Light.
(1 )
Ford Cmax Problem
(1 )
Please Help! Problem With Handbrake
(1 )
Reversing Light Switch Location
(3 )
A Wheel Bearing Or Not A Wheel Bearing......
(2 )
Shiny Dashboard Problem
(3 )
C- Max MPG
(37 )
Cmax 2005 Towbar Help
(6 )
Why Do My Revs Go Up When The Car Is Idle???
(1 )
Drivers Electric Window
(0 )
Dvd 7500 Code Missing
(0 )
C-Max (2007 - 07 Reg) Zetec - 6000Cd Upgrade Possible ?
(0 )
Newbie
(1 )
Help!
(1 )
Battery Light On
(8 )
Sat Nav
(0 )
Fuel Light
(5 )
C-Max Radio Code Needed 6000Cd
(1 )
Rear Hatch
(9 )
Help Needed Radio Code For 6000Cd
(1 )
Can Any Body Help Cmax Radio Code Needed
(2 )
Brake Reservoir
(2 )
Ford Econo Check
(0 )
Wiring Diagram
(4 )
Another Radio Code
(1 )
Potential Newbie
(1 )
How Do I Clean The Fuel Tank Breather
(0 )
Radio Code And Engine Management
(5 )
Dvd 7500 Entertainment
(0 )
Ford Factory Fitted 7500 Roof Mounted Dvd
(1 )
Rear Wash Wipe / Front Wash Wipe Wired Wrong?
(2 )
Radio LOCKED
(4 )
2.0 Tdci Hesitation Problems
(6 )
My C-Max Zetec Tdci 1.6
(1 )
Replacing Brake Pads
(0 )
Haynes Work Shop Manual
(1 )
Cvt Gearbox
(0 )
Paint,body Finish
(2 )
Oil Pressure Light Staying On
(1 )
Removing Dashboard Inlay
(1 )
How To...heated Front Window
(1 )
SPARE WHEEL ?
(13 )
Space Saver
(4 )
C-Max 2.0Tdci Ghia
(2 )
Rear Park Censors Fault
(3 )
C-Max Electronic Boot Release Fault
(2 )
Engine Light On This Morn,another Electrical Misery
(3 )
Quick Clear Windscreens
(3 )
Noisy Clutch
(3 )
Hi all.
(1 )
Anti Hijack
(1 )
Cmax 2.0 Tdci Faults
(0 )
1.8 Or 2.0 Diesel
(1 )
Cigar Lighter Fault
(3 )
overhead courtesy light console
(3 )
Losing Power On Excelleration When Cold
(1 )
C-Max 1.6tdci Automatic Problems
(1 )
1.8 tdci
(2 )
drivers door lock cont'd :-(
(1 )
front parking sensors
(2 )
Damaged sidewall & alloy - advice required
(2 )
Hard to start
(2 )
car audio
(0 )
Not good on Fuel-Whats your views??
(3 )
Unlocking the car
(4 )
lock driver door
(1 )
Alarm
(3 )
Parking Sensors
(10 )
C Max auto/CVT?
(4 )
Mood lighting
(5 )
cruise control
(2 )
Lighs flash on start up
(1 )
CMAX Wet fuse box - electrics going mad!!
(2 )
C-Max sorted at last
(0 )
C-Max 1.8ghia 54reg
(1 )
EGR Valve
(5 )
FAO Scottish Members
(0 )
C-Max replacement leather front seats??
(1 )
temp gauge on max, without apparent actual overheat
(2 )
transmission fluid level
(2 )
C-Max completely dead
(3 )
central locking
(1 )
Aircon
(1 )
catatylitic converter
(1 )
Wet floor Focus
(0 )
Ford Focus C-Max 06 ISOFIX car seat
(1 )
SERVICE RESET
(1 )
flat spots
(2 )
electronic hand brake
(10 )
(5 )
auto or not auto
(3 )
dvd player roof mounted
(2 )
C-Max titanium 09 lower grille
(0 )
Turbo
(2 )
C-Max Stereo
(0 )
1.6 TDCI CVT AUTOMATIC GEARBOX
(3 )
Code 15 fuse blowed on a 1.6 litre Ford Focus C-Max Zetec 2006
(0 )
P1412 fault code - EGR Valve
(1 )
Simple question Wheelie
(4 )
C-MAX TDCI GHIA O5 ALARM
(2 )
Tuning Chip Advice / Brakes
(5 )
Is is worth getting an 08 plate cmax
(3 )
SRS ECU
(6 )
badges
(2 )
c max spare wheel
(5 )
car won't stop
(3 )
servicing schedule
(1 )
FORD C-MAX ZETEC
(2 )
C-Max brake fluid top-up
(2 )
workshop manual
(0 )
Privacy Glass or Blinds
(2 )
Selective windscreen demister
(8 )
gunk
(2 )
Faulty indicators
(0 )
Workshop Manual
(3 )
How Long For Display Lights To Go Out?
(2 )
Change Alternator
(9 )
Adjusting the back seats
(3 )
Servicing
(0 )
Ford focus C-max starting problem under 0 °C
(2 )
Key Battery
(4 )
getting my cmax
(1 )
miles with full tank
(4 )
Just checking
(5 )
EPS - Alarm
(0 )
Door seals
(4 )
Ford C-Max Club
click here
Invision Power Board © 2001-2013
Invision Power Services, Inc.
