Full Version: Ford KA / StreetKA Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9
  1. Ford Ka Ms Design Low Mileage (0 )
  2. Streetka Rear Brake Upgrade (2 )
  3. Strange Looking Part (1 )
  4. Ka Cabriolet Broken Back Window (3 )
  5. Alarm Going Off After A Jump Start (3 )
  6. Fitting Dab Aerial To 2010 Mk2 Ka (8 )
  7. Streetka Brake Upgrades (12 )
  8. 55 Reg Ka Unpredictable (15 )
  9. Ms Design Ka Mk2 (0 )
  10. Bluetooth On Ka Mk2 (1 )
  11. Streetka Over Heating. :( Help! (9 )
  12. Clutch Advice Needed. (4 )
  13. Trip Computer - Lights (1 )
  14. Engine Light - Help! (4 )
  15. Engine Management Light (1 )
  16. 2004 Ka Pulls Right (3 )
  17. Help Wiring Radio/cd In 2010 Ka (3 )
  18. Double Din (4 )
  19. 2003 Streetka Front Windscreen Replacement (1 )
  20. Who Has Modified Their Ka? Styling And Mods? (5 )
  21. Spark Plug Alternatives (2 )
  22. Lack Of Power Sportka (8 )
  23. Scraping Noise When Turning Wheel Streetka 2004 (3 )
  24. Howdy! (14 )
  25. Roof Trim - Gutter Strip (0 )
  26. Abs Pump Replacement (0 )
  27. How To Play Music From Phone (3 )
  28. Does Anyone Know How To Reconnect Alarm Sensor In Boot? (2 )
  29. Help - Sun Finally Out And Can't Release Roof Storage Compartment!! (2 )
  30. Whirring Sound (3 )
  31. Connecting Ipod Touch (5 )
  32. Sport Ka - 2 Problems (1 )
  33. 1.2 Ka Drinking Fuel (6 )
  34. Odometer (3 )
  35. Streetka Hardtop Weight (4 )
  36. Connecting An Ipod To A Sportka (3 )
  37. Water Leaking Into Car! (3 )
  38. Advice! Purchasing A Street Ka (3 )
  39. Help Please - Radio Key Code (2 )
  40. Please Help! Ford Ka Studio Owners Advice Needed (3 )
  41. 03 Plate Ka Alternator/battery Problem? (4 )
  42. Streetka Rocker Cover Gasket Torque Setting??? (1 )
  43. Drivers Door Won't Lock With Key (2 )
  44. 2009 Ka Parking Brake Failure (0 )
  45. 2003 Ford Ka - Engine Management Light, Revving, Throttle Body (7 )
  46. 2006 1.3 Duarte Engine Starting Problems (3 )
  47. Abs Warning Light And Speedo Not Working (8 )
  48. Sport Ka 04 Cooling Issues Help Please (1 )
  49. Ford Ka Mk11 09 Rust Problem (7 )
  50. Help.! Ford Ka 05 Plate Heater. (7 )
  51. Streetka Problem B2256 Window Heater Short To Ground (7 )
  52. Speed Warning (2 )
  53. Help!! Pram Streetka (21 )
  54. Grinding Noise When Driving Ka (1 )
  55. Streetka - New Ngk Plugs - Then Check Engine Light On - (1 )
  56. Warning Light (2 )
  57. Glove Box Removal 2002 Ka (0 )
  58. Check Engine Light - Walkthrough On Diagnostic If Possible :) (2 )
  59. Help Heaters Don't Work (7 )
  60. How To Take The Spare Wheel On Ford Streetka (5 )
  61. Does The Streetka Have A Special/sports Gearbox? (3 )
  62. Streetka Hardtop (3 )
  63. Pulls To One Side When Hitting Drains. (5 )
  64. Mothers 52 Reg Ford Ka. (1 )
  65. 52 Reg Ford Ka. (6 )
  66. Speedo, Rev Counter And Trip Problem (2 )
  67. Ford Ka Blowers (2 )
  68. 2004 Streetka Front Subframe Chassis Mounting Badly Corroded (2 )
  69. Testing Heater Control Valve (1 )
  70. 2005 Ka Speed Sensor A (5 )
  71. Streetka Knocking Noise (5 )
  72. Streetka Lower Arm (1 )
  73. Water Up My Tail Pipe (Not A Euphemism) (6 )
  74. Overheating Ford Ka 1.3 05 Reg (1 )
  75. Streetka Problems (3 )
  76. Droping Roof & Strange Problem Drivers Side Front Indicator (1 )
  77. Ka Troubles (13 )
  78. Ford Ka Crossmember (1 )
  79. Hardtop Wiring (7 )
  80. Covering Up Holes On A Streetka (0 )
  81. Clutch And Fuel Neck Severe Rust Problems. (3 )
  82. Looking For Rear Roof Seal Ka Street 2004 (3 )
  83. Ford Ka Fan Running (1 )
  84. Bumper Stain (5 )
  85. 2010 Ka Problems Just After Warranty (8 )
  86. Any Information Released Yet On The New Ka 2014 ? (1 )
  87. Stumped!!!! (12 )
  88. Mp3 Playback (0 )
  89. Street Ka Cracked Rear Window (3 )
  90. Ka Drivers Side Cv Joint - No Circlip (4 )
  91. Service Light Is On (2 )
  92. Ford Ka Instrument Cluster Light (0 )
  93. Scanner (4 )
  94. 2005 Streetka Air Con - Tis Cd Required Please (3 )
  95. Passenger Door Locking Problem (2 )
  96. Fault Code: P0200 Injector Circuit (0 )
  97. Ford Ka Hard To Get In Gear (2 )
  98. Bonnet Hot On Drivers Side, Plus Headlight Has Condensation 24/7 (1 )
  99. Replacement Keys (0 )
  100. Engine Management - Lambda Sensor (0 )
  101. Rust On Sportka (8 )
  102. 2005 Ford Ka Heater Blower Change? (1 )
  103. A/c Only Blowing Out Hot Air (9 )
  104. Testing Coil Pack (0 )
  105. K.a 09 Squeal !! (3 )
  106. What Is The Phone Symbol On Dashboard Of Sportka?? (2 )
  107. Blistering Paint around filler cap (12 )
  108. Cylinder Head Removal Ka Mk1 (5 )
  109. Squeaky Brakes. (2 )
  110. Street Ka's Life Span (4 )
  111. Streetka Starter Spinning After Engine Switched Off (1 )
  112. Cooling System (2 )
  113. Ford Streetka - Problem With Bolt Securing Hard Top (2 )
  114. 53 Reg Sportka Tickover And Speeding Up Issue (0 )
  115. Remote Key For 2010 Ka (0 )
  116. Ka Hub Bearing (4 )
  117. Ka Abs Issue (0 )
  118. Car Making A Thudding Sound (14 )
  119. Kangaroo Ka (1 )
  120. Steering (1 )
  121. Indicator Problem? (2 )
  122. New Ka Accelerator Pedal (4 )
  123. Ford Ka Heating\cooling (0 )
  124. Ford Ka Lowering Springs (0 )
  125. Ka 1.3 2004 Duratec Engine Warning Light Come On???? (3 )
  126. Ka 1.3 Duratec Engine...leak From Plastic Thermostat Housing. (4 )
  127. Streetka Heater Control Valve (2 )
  128. Both Rear Lights Out (2005 Ka Design) - Which Fuse? (3 )
  129. Abs System Broked (31 )
  130. Diagnostic Test Returns Error? (1 )
  131. Streetka Trouble Starting (6 )
  132. 2005 Ka Gearbox Removal (8 )
  133. Streetka Windscreen Trim (0 )
  134. Ford Ka soaking wet driver's side footwell (27 )
  135. Streetka Electric And Noise Issue (2 )
  136. Problem With Ford Ka. (9 )
  137. Streetka: Roof Button And Water Leaking Problems (0 )
  138. Streetka Central Locking/alarm (9 )
  139. New Back Screen/window For Streetka (7 )
  140. Street Ka Damaged Rear Window (1 )
  141. Streetka Manual (4 )
  142. P-0030 Ho2S Heater Control Circuit 1 Bank 1 Sensor 1 (1 )
  143. Streetka Door Handles Have Broken (Again) - Help (2 )
  144. Rear Suspension Coil Spring (1 )
  145. Heaters Only Blowing Cold Air (3 )
  146. Streetka Windows Not Working And Roof Hatch At Rear Not Opening (3 )
  147. Rust (2 )
  148. Blown Bulbs & Faulty Wireing? (3 )
  149. Eml On After Hcv Change (3 )
  150. Trouble With My Dvd Player (5 )
Full Colour Version: Ford KA / StreetKA Club
