Full Version: Ford KA / StreetKA Club
Pages: 1, 2, 3, 4, 5, 6, 7
  1. Speedo Problem, Help!!!!! (3 )
  2. Cambelt (2 )
  3. Ford Ka Fuel Pump Not Coming On (6 )
  4. Radio Code? (4 )
  5. Leak Into Passenger Footwell!! (2 )
  6. Streetka Cooling Fan (4 )
  7. Ka Problems (4 )
  8. Petrol Leak 96 Ka (0 )
  9. Wet Mats And Condensation (3 )
  10. Gear Knob Query (1 )
  11. Problem With Ford Ka Rear Lightsthe Rear Drive Lights On The Wife's 03 Ford Ka Werent Working The Other Day - All Other Lights Were. I Checked The Bu (4 )
  12. Ford Ka VIN plate missing? (15 )
  13. Ka Central Locking (1 )
  14. Streetka Tyre Wear (1 )
  15. Ford Ka Squeking Noise (0 )
  16. Ford Galaxy 1997 2.3 Petrol . Drive Belt To Loose (0 )
  17. Rust Around Petrol Filler (4 )
  18. Changing Radio/casette For Cd Player.. Secuirty Question (1 )
  19. W Reg Ka Alternator (1 )
  20. Cold Start (0 )
  21. Ka 1997 Problems (2 )
  22. Front Lower Arm? (2 )
  23. Air Con Bulb Trouble (0 )
  24. Ka Dash Vibration/rattle (0 )
  25. Street Ka Headlights (0 )
  26. Ka Clutch Gone (2 )
  27. Bike Rack For Mk2 Ka? (5 )
  28. Looking For A Part (1 )
  29. Looking For A Part - Relay (I Think). (0 )
  30. Cd6000 Code (2 )
  31. Ford Ka Cd6000 Code Problems (2 )
  32. Shuddering (4 )
  33. Radio Help (1 )
  34. Dashboard Lights Faulty (0 )
  35. '98 Ka Steering Problem (1 )
  36. Converting Belgian Mk2 Ka To Uk Spec (0 )
  37. Rear Plastic Window (3 )
  38. Ford Ka 1.6 Zetec Rocam Sohc Tight Head Gasket (0 )
  39. Fuel Warning Light? (0 )
  40. Ford Ka Spark Plugs (4 )
  41. Front Bumper Of My Streetka (1 )
  42. Ford Ka Silver Moondust Spray (0 )
  43. Central Locking Issue Also Usual Sound At Speeds Above 50 Mph (5 )
  44. Central Locking Control Module (1 )
  45. Ford Ka Indicator Stalk Not Cancelling (1 )
  46. Radiocode Cd 6000 Eon Rds (4 )
  47. Ka 6000 Cd Player (0 )
  48. Headlight Not Working (Wiring/connector Problem) (1 )
  49. Leaking Power Steering Pipes (5 )
  50. Ka Studio Wind Down Window Problem (1 )
  51. Streetka Pulling To Left Under Accleration (3 )
  52. Ford Ka 1997 Rear Speakers (0 )
  53. Ford Ka 1997 Dashboard Fascia Question (0 )
  54. Ford Ka Auxilliary Belt Change (2 )
  55. New Disc's And Pads (2 )
  56. Ford Ka Dry Bush On Front End (3 )
  57. How To Get Black Plastics Back To Black? (27 )
  58. Insurance Quotes (5 )
  59. Ford Ka 1.3I Starting When Engine Hot (3 )
  60. Streetka Running Rough (3 )
  61. Radio Code Needed !!!!!!!!!!!!!!! (4 )
  62. A clean Ka is a happy Ka (10 )
  63. Grinding Clutch (1 )
  64. Clear Coat Pencil (3 )
  65. Front Discs Replacement On 2005 Ka (4 )
  66. Fuel Pump Or Ecu Problem (1 )
  67. Intermittent Battery Light (3 )
  68. Protecting The Bodywork On A Streetka (0 )
  69. Ka Brake Hose Help (2 )
  70. Help! - Juddering (Fault Code) (1 )
  71. Engine Stopping When Acceleration Not Pressed (3 )
  72. Streetka Common Problems - Are The Common Problems? (1 )
  73. Tyre Pressures (1 )
  74. Boot Bars Like Peugot 206Cc? (0 )
  75. How To Buy A Used Ford Ka (1 )
  76. Creaking Noise Streetka (2 )
  77. Another Question (0 )
  78. ???? (5 )
  79. KA LOWERING (6 )
  80. Bumpers (0 )
  81. Drivers Door Lock Wont Open KA. (3 )
  82. Alarm With Roof Down (2 )
  83. Ford Ka, Knackered Map Sensor?? (1 )
  84. New Exhaust (1 )
  85. Electric Windows (1 )
  86. Streetka Won't Start And Alarm Going Off (4 )
  87. Ka O2 Sensor Faulty P0118 Code (4 )
  88. Roof Bar Fitting Kit (1 )
  89. Installing Central Locking! (1 )
  90. Help! Manifold Needed! (1 )
  91. 52 Ka Front Pads (1 )
  92. Engine Light On And Car Slightly Over Reving Itself (1 )
  93. Hard Top For Streetka (0 )
  94. Coolant Leak (2 )
  95. 2003 Streetka Roof (3 )
  96. Spark Plug Removal Tool (1 )
  97. Ka Steering Wobble (2 )
  98. Streetka / Ka Brakes. (2 )
  99. Ka Mk2 (8 )
  100. First Service, How Much? (2 )
  101. Mud Flap (3 )
  102. Convertible Roof Motor (2 )
  103. Fuel Injector Clip (1 )
  104. Instrument Panel Swap/tacho (2 )
  105. 2010 Ka Headlight Blub Type (1 )
  106. Fuel Volume Regulator Control (1 )
  107. Heater Problems (5 )
  108. Misfire Cylinder 1 - Worth The Repair Costs? (2 )
  109. Oxygen Sensor Replacement & Wheel Issue (3 )
  110. Stupid Question Re Alarms (5 )
  111. Sportka Front Spring (1 )
  112. Heater Control Valve (1 )
  113. Electric Problem (2 )
  114. Knocking Steering Wheel (5 )
  115. Rear Wiper Blade/ Motor (0 )
  116. Ka Clutch Noise When Starting Engine (0 )
  117. Heater Has A Mind Of Its Own? (4 )
  118. Antifreeze (3 )
  119. Spark Plugs (16 )
  120. Streetka spare wheel (2 )
  121. Streetka Alarm (2 )
  122. Soaking Wet Footwell Again!! (31 )
  123. Ford Ka Won't Lock? (2 )
  124. Locking And Unlocking When Using Fob (0 )
  125. Intermittent Misfiring, Spluttering (12 )
  126. Help With Instalation Of Lights!!! (2 )
  127. Ka Wiper Blade (1 )
  128. Any1 Got Any Coilovers (0 )
  129. Mot And Spare Wheel (4 )
  130. Streetka - Central Locking Not Working (2 )
  131. Ford Ka 2001 Help ? (1 )
  132. Help Needed On Ka Airbag Light Wont Illuminate ! (2 )
  133. Annoying Intermittent Temperamental Problem Pleeease Help!! (1 )
  134. Ka Collection...fitting Oe Remote Central Locking (0 )
  135. Ford Sportka Centre Exaust Mod? (2 )
  136. New Ka Cd Player (1 )
  137. StreetKa Air Con (13 )
  138. Streetka: Roof Compartment Won't Open & Spare Wheel Problem (5 )
  139. Engine Management Light + Stuttering When Cold (11 )
  140. Rear Window Problem (1 )
  141. Air Intake Sensor (2 )
  142. Using My Ipod (1 )
  143. Lights Warning Buzzer (1 )
  144. Engine Warning Light (3 )
  145. New Ka Titanium (7 )
  146. Ford Silly Design? Or Is Mine Broken? (2 )
  147. The History Of Ka Design (1 )
  148. Headlight Condensation (4 )
  149. Ka Battery Removal (11 )
  150. Mot Advise (1 )
Full Colour Version: Ford KA / StreetKA Club
