Full Version: Ford KA / StreetKA Club
Pages: 1, 2, 3, 4, 5, 6, 7, 8, 9
  1. New Ka Bt / Usb Question (0 )
  2. 15" Alloys On A 05 Streeka? (0 )
  3. Remote locking causes indicators to flash (6 )
  4. Help (3 )
  5. Stalling Problem & Friction Noise When Wheels Turned Right... (3 )
  6. 05 Street Ka With A Squeek (3 )
  7. K&n Air Filter (1 )
  8. Sportka Se Mpg (2 )
  9. Ka Gearbox Problem-Please Help! (8 )
  10. Ford Ka Water Leak - W Plate (0 )
  11. 'cancheck' On Radio Display (1 )
  12. Ford Ka Stereo Removal And Code (3 )
  13. MYKA R.I.P (10 )
  14. Ford Ka Radio Buttons (1 )
  15. Ka Problems (7 )
  16. Speaker Wiring (3 )
  17. Odometer Resetting (0 )
  18. Ford Ka Cylinder Pressures And Slipping Clutch? (1 )
  19. Leaking :( (0 )
  20. Streetka (7 )
  21. Power Steering Fluid Level (4 )
  22. Very Noisy Sportka (1 )
  23. Split Streetka Rear Window!!! (4 )
  24. Radio Code (2 )
  25. Ford Ka Loose Of Power, Headgasket??? (2 )
  26. Tail Light Lens Cover (1 )
  27. St200 Or Engine Swap?? (0 )
  28. Rust Around Fuel Cap And Back Wiper (1 )
  29. What To Do Now? (2 )
  30. Leak in brand new Ka (40 )
  31. Best Tyres (1 )
  32. Ford Ka Ecu Change (2 )
  33. Help (3 )
  34. Engine Smell (8 )
  35. Streetka Locking Petrol Cap Flap (4 )
  36. Ford Meet (0 )
  37. Aircon Now Working (0 )
  38. New Owner (4 )
  39. Leak (3 )
  40. 1999 Endura E Pcv System (0 )
  41. Streetka Water Temp Kit (0 )
  42. Noisy Brake Pedal (7 )
  43. Heated Rear Window (0 )
  44. Mounting hardware hardtop StreetKA (4 )
  45. Radio Displays Cancheck (0 )
  46. Poor Consumption & Power Loss!!.... (4 )
  47. Hoses For Ka Heater Control Valve (0 )
  48. Ka Battery Light (0 )
  49. Ka (4 )
  50. Mk2 Ford Ka Up Front Lighting Problems (0 )
  51. Rear Brake Shoes (2 )
  52. Ka Write Off (1 )
  53. 2003 Duratec Ka 02 Sensor Help Please (4 )
  54. Streetka Hardtop Roof (0 )
  55. Streetka Remap (0 )
  56. Streetka 1.6 2003 Alarm Problem (0 )
  57. Streetka - Indicator & Horn Problems (4 )
  58. Power Steering Oil Capacity (1 )
  59. Ford Ka Audio System Key Code (1 )
  60. Streetka - Urgently Need 16" Alloy (2 )
  61. Bluetooth Usb Option And Ipod Issue (1 )
  62. Wet Inside Windshield, Ka T 1999 (1 )
  63. Ford Ka 06 - Overheating After 10 Miles (4 )
  64. Failed Mot :( (4 )
  65. Ka 1997 Central Locking - Locking & Unlocking Problem (1 )
  66. Mk2 Ka Mpg Computer? (13 )
  67. Need Urgent Help With Ka (2 )
  68. Girlfriends Possible Ford Ka (5 )
  69. Streetka Rear Screen (1 )
  70. Bluetooth (2 )
  71. Ford Ka Problem (3 )
  72. Ka Parts (0 )
  73. Identification Of Parts (2 )
  74. Leather Gear Knob (0 )
  75. 56 Plate 1.3 Ka Weird Noise Over 60Mph (5 )
  76. Brake Warning Light (1 )
  77. Ka Clock Illumination (0 )
  78. Mot Advisories (11 )
  79. Ford Ka Mk1 Breaking (0 )
  80. Ka & Stop-Start? (1 )
  81. Streetka Rear Light Problem (2 )
  82. Split Hood Rear Window Streetka (1 )
  83. Streetka Misfire (6 )
  84. 57 Plate Ford Ka Speedo Light (6 )
  85. Ford Ka Radio Code ! ! ! (1 )
  86. Blower Resistor Change (2 )
  87. Rear View Mirror (3 )
  88. 't' Reg Ka Struggling On Slopes And Picking Up Speed (7 )
  89. Oil Type (1 )
  90. Breakdown Cover (3 )
  91. Cracked Wishbone Helpp! (6 )
  92. What Is This? (3 )
  93. Fuel Filler Removal (2 )
  94. Original Ka Mudflaps (0 )
  95. Clicking From Under Inlet (0 )
  96. Ka Wheel Bolts (16 )
  97. Front Subframe Replacement (3 )
  98. Hardtop Mounting Brackets (0 )
  99. New Headunit.......help Needed !!! (3 )
  100. Ecu Location On W Plate Ka (1 )
  101. Ford Ka Mud Flaps (2 )
  102. Have I Fixed This Correctly? (3 )
  103. Ford Ka Wheel Size (3 )
  104. 1) unusual engine/clutch noise and 2) unusual clicking engine noise (4 )
  105. clutch problem (4 )
  106. Wig In My Exhaust (10 )
  107. Speedo Problem, Help!!!!! (3 )
  108. Cambelt (2 )
  109. Ford Ka Fuel Pump Not Coming On (6 )
  110. Radio Code? (4 )
  111. Leak Into Passenger Footwell!! (2 )
  112. Streetka Cooling Fan (4 )
  113. Ka Problems (4 )
  114. Petrol Leak 96 Ka (0 )
  115. Wet Mats And Condensation (3 )
  116. Gear Knob Query (1 )
  117. Problem With Ford Ka Rear Lightsthe Rear Drive Lights On The Wife's 03 Ford Ka Werent Working The Other Day - All Other Lights Were. I Checked The Bu (4 )
  118. Ford Ka VIN plate missing? (15 )
  119. Ka Central Locking (1 )
  120. Streetka Tyre Wear (1 )
  121. Ford Ka Squeking Noise (0 )
  122. Ford Galaxy 1997 2.3 Petrol . Drive Belt To Loose (0 )
  123. Rust Around Petrol Filler (4 )
  124. Changing Radio/casette For Cd Player.. Secuirty Question (1 )
  125. W Reg Ka Alternator (1 )
  126. Cold Start (0 )
  127. Ka 1997 Problems (2 )
  128. Front Lower Arm? (2 )
  129. Air Con Bulb Trouble (0 )
  130. Ka Dash Vibration/rattle (0 )
  131. Street Ka Headlights (0 )
  132. Ka Clutch Gone (2 )
  133. Bike Rack For Mk2 Ka? (5 )
  134. Looking For A Part (1 )
  135. Looking For A Part - Relay (I Think). (0 )
  136. Cd6000 Code (2 )
  137. Ford Ka Cd6000 Code Problems (2 )
  138. Shuddering (4 )
  139. Radio Help (1 )
  140. Dashboard Lights Faulty (0 )
  141. '98 Ka Steering Problem (1 )
  142. Converting Belgian Mk2 Ka To Uk Spec (0 )
  143. Rear Plastic Window (3 )
  144. Ford Ka 1.6 Zetec Rocam Sohc Tight Head Gasket (0 )
  145. Fuel Warning Light? (0 )
  146. Ford Ka Spark Plugs (4 )
  147. Front Bumper Of My Streetka (1 )
  148. Ford Ka Silver Moondust Spray (0 )
  149. Central Locking Issue Also Usual Sound At Speeds Above 50 Mph (5 )
  150. Central Locking Control Module (1 )
Full Colour Version: Ford KA / StreetKA Club
