Full Version: Tyre Pressures
tonyka
what are the correct tyre pressures for a 2000 ka please?
nickdando
[quote name='tonyka' date='06 February 2010 - 01:33 PM' timestamp='1265462636' post='63743']
Tyre Size
155/70R13 Normal load Front 2.2 (32) Rear 1.8 (26) Full load Front 2.5 (37) Rear 2.5 (37)
165/65R13 Normal load Front 2.1 (31) Rear 1.8 (26) Full load Front 2.5 (37) Rear 2.5 (37)
165/60R14 Normal load Front 2.1 (31) Rear 1.8 (26) Full load Front 2.5 (37) Rear 2.5 (37)
That's according to the book I got with my StreetKa and gives the pressures for a standard Ka. I had to purchase the proper StreetKa User Guide from a dealer. The first pressure listed is in Bar, the second in parentheses is in PSI.
Nick
Tweedie90
how can i tell what type out of the three my tyre is?
Amie07
[quote name='Tweedie90' date='06 February 2010 - 03:54 PM' timestamp='1265471073' post='63766']
Hi, don't they usually say the size on them? mine do. Though they are the originals so perhaps that's why.
If not pop into a tyre place and I'm sure they would put you right? :D
thesilverfox
[quote name='Amie07' date='06 February 2010 - 07:19 PM' timestamp='1265483346' post='63809']
You are quite correct. [b]All[/b] tyres should indeed display their diameter size (inches), width (mm), and profile (% of width).
Tweedie90
[quote name='thesilverfox' date='06 February 2010 - 07:57 PM' timestamp='1265485630' post='63812']
thank u much obliged!
thesilverfox
[quote name='Tweedie90' date='06 February 2010 - 11:55 PM' timestamp='1265499944' post='63879']
They should also display the speed rating too, as well as the date of manufacture (little known fact there).
Full Colour Version: Tyre Pressures
