Full Version: Thermostat Fitting Problem/advice
wijcc
My thermostat stopped working, so I change it with one I purchased for a local motor factors store. I looks slightly different for the Ford one fitted on the car originally, but it fitted fine. I gave my car reg number to make sure it was the correct one and on the box it stated that it was for various ford models. It seems to work fine as I have heating back now on the car. But it seems to leak coolant when the car is switched off. It seems to not to leak/leak less coolant if I leave the fan/heater on in the on position when I leave the the car overnight.
I know that you have to line the thermostat, thereis a dot/mark on the thermostat which I put in the same position as the old thermostat’s position. However if I put it in the wrong position will this be causing the coolant to leak?.
I have checked where the coolant is leaking from and it is from the thermostat/thermostat housing.
I have brought a new gasket/seal for the thermostat which I will fit.
Can anyone advice me to the positioning of the thermostat mark.. how to know where the mark should go?
My car is ford focus 1.6 ghia 2001 mark 1.
Thanks in advance guys :)
[quote name='wijcc' date='10 February 2010 - 02:04 PM' timestamp='1265810083' post='64386']
I know that you have to line the thermostat, thereis a dot/mark on the thermostat which I put in the same position as the old thermostatís position. However if I put it in the wrong position will this be causing the coolant to leak?.
Thanks in advance guys [img]http://www.fordownersclub.com/forums/public/style_emoticons/default/smile.gif[/img]
you likely need a new seal for the housing itself the housing is known for leaking im sure it comes as a complete housing so unfortunately it will all need to come out again
wijcc
[quote name='artscot79' date='10 February 2010 - 02:29 PM' timestamp='1265811554' post='64387']
Thanks, I'll give that a try.. any ideas why if I leave the fan/heater control it doesn't leak?
dezwez
[quote name='wijcc' date='10 February 2010 - 04:40 PM' timestamp='1265819429' post='64402']
if i remember right there is a small hole in the thermostat
which should go to the top of
houseing.Got my one wrong put it to the bottom and it leaked water hope this helps
wijcc
[quote name='dezwez' date='10 February 2010 - 05:02 PM' timestamp='1265820727' post='64406']
Yeap, i put the mark/hope on the top left hand side.. as it was with the original theromstat which was fitted on.
I put it on as close as possible to how is it was originally fitted
dezwez
[quote name='wijcc' date='10 February 2010 - 05:42 PM' timestamp='1265823127' post='64414']
its not a mark its a hole which they call the air bleed valve :)
wijcc
[quote name='dezwez' date='10 February 2010 - 05:52 PM' timestamp='1265823741' post='64419']
cool, thanks for clearing up the name..
Its that hole on the rim of the thermostat like in the pic below.. but on my one the hole is the top left hand side as you look at it
[img]https://www.carpartsdiscount.com/auto/archive/pictures/48037/600/1/P/28C2673/ford_focus_04_thermostat_housing.jpg[/img]
dezwez
[quote name='wijcc' date='10 February 2010 - 06:12 PM' timestamp='1265824967' post='64431']
where its mark with red line this should go to the top of houseing :)
dezwez
heres a better picture
the text says arrow shows the position of the air bleed valve. and to the top of housing :)
wijcc
[quote name='dezwez' date='10 February 2010 - 06:50 PM' timestamp='1265827255' post='64443']
cool thanks thats really helpful :)
