I've just bought a 2009 Fiesta Mk7 1.4 5-dr hatch and need a wiring diagram to hook up the newly-installed towbar.
I am aware that the electrical system is can-bus/multiplex and have the requisite 7-way bypass relay to tap into the various lamp wires. This to be powered from the fused 'Trailer' position in the pax fusebox but without a diagram am not sure if there is a supply wire -or plug/socket already installed from this to the rear of the car. Can't see anything obvious running from the looms.
Can any one help on this and/or have a copy of the relevant wiring diagram? Thanks in advance.
MQ
p.s. Er - Why are 'Daylight running lights' deemed necessary when there are at least 4 lamps installed at the front.....?
