Full Version: Non Starter
brucie
Mondeo Mk3 1.8lx 2002. She turns over but fails to start. Spark at plugs, fuel cut off switch is depressed, no blown fuses, cannot hear fuel pump priming itself. Is there any other checks I can do before replacing the fuel pump? Most times it would start straight away sometimes after a few turns, now not at all.
[quote name='brucie' date='09 March 2010 - 12:41 PM' timestamp='1268137889' post='69906']
sounds like a fuel issue to me might be a new pump time if you have plenty of spark im assuming that the coil pack is fine
[quote name='artscot79' date='09 March 2010 - 07:22 PM' timestamp='1268161931' post='69973']
i would start by checking any fuses and relays specific to the pump and then check all wiring to it and any earths.
also check that there is power getting to the pump.
brucie
[quote name='stef123' date='09 March 2010 - 07:43 PM' timestamp='1268163232' post='69981']
Ordered 2nd hand one £42 so no great expense if not the pump. Question - can i hook up replacement before installing to see if it runs, thus ensuring its not a wiring fault. Dont want to do any damage. Power is getting to pump, meter reads when ignition turned on.
cheers
L S Auto Repairs
Have you checked to see if your getting fuel up to the fuel rail?
Spark at end of HT leads?
There a 3 amp engine management fuse that blows in the engine compartment check that.
brucie
[quote name='L S Auto Repairs' date='11 March 2010 - 01:02 AM' timestamp='1268268725' post='70460']
Fuse ok, there is a spark, what is the best way of checking fuel at the rail? If the pump has gone would there still be enough pressure for injectors to inject fuel? Plugs are bone dry.
[quote name='brucie' date='11 March 2010 - 09:49 AM' timestamp='1268300383' post='70481']
with the pump gone there will be no fuel in the rail as youll have used what was left in the pipe turning it over
Full Colour Version: Non Starter
