Frankie1973
March 12, 2010, 10:20 am
Hi all, I have a 2001 Focus LX, and the central locking is playing up.
went to open car using remote, car opens except Drivers door.
unlocked door with key
arrive home, proceed to lock car with remote and the locking locks, and then unlocks.
car will lock from the key and activate all doors, i can then press the button to deadlock/indicators flash,
car will unlock from remote, but again not drivers door.
have reprogrammed both fobs, but still no luck,
my next options are to:
disconnect battery for 10-20 mins..
disconnect module (which i believe is under the dash above pedals)
or continue to use the key and not the fobs.
this did happen a couple of weeks ago but i found that by pressing the unlock, when the car was unlocked, followed by the lock, to lock the car managed to reset the module, this is not working this time..
any thoughts..?
March 12, 2010, 1:27 pm
[quote name='Frankie1973' date='12 March 2010 - 04:30 PM' timestamp='1268410849' post='70881']
any thoughts..?
open the effected door by the sound of it drivers locate the torq screw on the lock basically open the door look at the latch on the door theres 3 screws remove th ebottom one nearest the inside of the car and spray some wd40 in replace the screw nad check if it works
Frankie1973
March 12, 2010, 2:09 pm
[quote name='artscot79' date='12 March 2010 - 07:37 PM' timestamp='1268422076' post='70947']
Thanks, I have disconnected the battery for now, and will try that tomorrow, yes it seems to be the drivers lock thats at fault..
March 12, 2010, 2:59 pm
[quote name='Frankie1973' date='12 March 2010 - 08:19 PM' timestamp='1268424550' post='70961']
i had a similar issue i did what i said above spraying the wd40 in the hole at a downwards angle that was 6 months ago and its been fine ever since
Frankie1973
March 14, 2010, 12:50 pm
[quote name='artscot79' date='12 March 2010 - 09:09 PM' timestamp='1268427597' post='70974']
well i disconnected the battery, and sprayed the inside of the lock, but it was the same, then for some reason i opened the boot, and now it works...???
anyway, good for, now, as i have just fitted an alpine head unit and changer, tinted the rear doors and infills and fitted a roller shade.. get in..
