marv_666
March 12, 2010, 4:40 pm
[font="Comic Sans MS"][size="3"][b][u]Y-reg 2.0 TDCi[/u][/b]
Just had a look at my mates Mondeo as he's losing power steering fluid.
It 'appears' that it's leaking from the pump, from the join between the two halves of the casing, on the underside of the pump.
Is there a common fault with either the gasket failing, or the casing cracking there?
Hope someone can narrow down the cause before i get up to my elbows in PAS fluid! (nice!?)
Many thanks.
Marv.[/size][/font]
March 13, 2010, 2:24 am
[quote name='marv_666' date='12 March 2010 - 10:50 PM' timestamp='1268433629' post='71038']
Many thanks.
Marv.[/size][/font]
there was a problem with the bolt connecting the power steering fluid to the pump whaere it leaks and needs replaced with a modified one from ford but i havent heard of the pump leaking between the casing before
chris bowman
March 13, 2010, 5:06 pm
cant see how that could happen and be repairable from the manual. looks like new pump!
March 15, 2010, 11:51 am
[quote name='chris bowman' date='13 March 2010 - 11:16 PM' timestamp='1268521566' post='71177']
the banjo bolt that connects the pipe to the pump would cause thee oil to run down that way but i cant see how the pump is one piece and doesnt split in 2 unless it has somehow got a hole in it somewhere
chris bowman
March 15, 2010, 1:28 pm
if it is a split unit it would been buying a repair kit. dont know of where ud get one
