keith43
March 12, 2010, 6:00 pm
i had a replacement engine fitted recently. when i picked the car up, it felt different. the revs were running higher than normal, but only whilst it was cold. It now has a whistling / whining noise also, but not immediately. I have a daily run to work of roughly 3 miles. when i pull up to stop. the revs are around 1500 - 2000 and the noise is really loud. this is out of gear? if i blip the throttle, it eventually goes off. As ive mentioned, my car didnt have this problem before the replacement engine was fitted. the garage say that its the charcoal canister! I dont belive them! They have put the engine in with the inlet manifold attached. Could it be this, as they didn't fit my original one back on?
A speedy response would be greatly appreciated from anyone with knowledge of what this might be.
cheers
Keith
March 13, 2010, 2:21 am
[quote name='keith43' date='13 March 2010 - 12:10 AM' timestamp='1268438431' post='71054']
cheers
Keith
in simple terms no its not the charcoal cannister the high revs could be the idle control valve obviously youre old one didnt do it so a simple swap with that idle control valve would sort it also the throttle position sensor could be sticking
keith43
March 13, 2010, 1:19 pm
[quote name='artscot79' date='13 March 2010 - 08:31 AM' timestamp='1268468475' post='71066']
thanks for the reply.
If its the ICV; is it easy to change? Would this make the whistling / whining noise? It only happens when i 1st start the car up. Why would this be? Cheers peeps........
March 13, 2010, 4:14 pm
[quote name='keith43' date='13 March 2010 - 07:29 PM' timestamp='1268507960' post='71144']
a whistling noise could be down to air escaping with it idling open the bonnet and see if you can track it down
Frankie1973
March 14, 2010, 12:44 pm
whining noise could be the auxilary belt...
keith43
March 16, 2010, 3:50 pm
[quote name='artscot79' date='13 March 2010 - 10:24 PM' timestamp='1268518455' post='71172']
Thanks for the advise fella. All sorted. the garage finally saw sense (and my mad eyes!) and changed the ICV. Suprise - suprise, the problem ceased...
March 16, 2010, 4:19 pm
[quote name='keith43' date='16 March 2010 - 09:00 PM' timestamp='1268772625' post='71953']
another happy ending glad you got it sorted
