Ian P
July 26, 2008, 3:42 pm
Just had dual mass flywheel replaced fro second time in 93000 miles. Vehicle now sluggish, appears to not have turbo coming in at 1800 - 2000 rpm, but later ata about 3000 and without the normal rush of acceleration. Anybody experiemced anything similar ?
it once had aloose indution pie which felt the same, but all appears ok with that this time.
jock0909
July 28, 2008, 3:22 am
[quote name='Ian P' post='2391' date='Jul 26 2008, 09:42 PM']Just had dual mass flywheel replaced fro second time in 93000 miles. Vehicle now sluggish, appears to not have turbo coming in at 1800 - 2000 rpm, but later ata about 3000 and without the normal rush of acceleration. Anybody experiemced anything similar ?
it once had aloose indution pie which felt the same, but all appears ok with that this time.[/quote]
I have had the same thing with mine and it turned out that the pipes were loose, since the garage fixed them I have not had any problems with it.
I don't know of any other things that it could be.
croc86
March 3, 2010, 1:53 am
[quote name='jock0909' date='28 July 2008 - 08:32 AM' timestamp='1217233354' post='2411']
I too had the same problem. The garage found that there was a nipped vacuum hose as a result of the tight fitting and lack of space between gear box and turbo when replacing clutch and flywheel. Once the vacuum hose was unblocked, everyhting was back to normal.
wilberforce
May 20, 2010, 1:40 pm
Interesting thread.
I have a 53 plate TDCi with almost 90K on the clock. Owned from new, serviced at the right times, had the timing belt done as it was being serviced and thought I may as well.
However, recently, there is a clatter when I press the clutch in. Could this be the release bearing on it's last legs or maybe something more serious? Clucth still works, no slippage.
I'd also be interested how much the dmf cost Ian P to get replaced as if I'm getting the clutch sorted, I may as well go the whole hog and get the dmf sorted as well.
Anyone got any thoughts?
Sluggish TDCi 1.8
