stuk2000
March 27, 2010, 7:15 am
Got a an airbag fault code 51, which is the drivers side seat belt buckle. Changed it for a new one but still get the same problem.
Looking on Wikipedia for the code it says,
DTC B2434: Driver safety belt buckle switch short circuit to ground. Lamp flash code: 51
Possible Source(s):
Driver safety belt buckle switch.
Circuit(s).
DTC B2435: Driver safety belt buckle switch resistance out of range. Lamp flash code: 51
Possible Source(s):
Circuit(s).
DTC B2691: Driver safety belt buckle switch open circuit or short to battery. Lamp flash code: 51
Possible Source(s):
Circuit(s).
Can anyone help please??
April 28, 2010, 2:03 pm
[quote name='stuk2000' date='27 March 2010 - 01:25 PM' timestamp='1269692104' post='74316']
Possible Source(s):
Circuit(s).
Possible Source(s):
Circuit(s).
Possible Source(s):
Circuit(s).
you need the codes cleared its the old code still in the ecu memory so until you clear it you wont know if its fixed either have it done at a garage or disconnect the battery for an hour just make sure you have the radio code etc etc
