Silver Fox
April 13, 2010, 4:59 pm
Hello, I have a 2007 Focus 1.6 Zetec, it's done just over 55'000 miles and yesterday the clutch pedal went all soft and the biting point is now right at the top of the pedal, it has also started to slip when pulling uphill, is this a sign that the clutch is on it's way out? and would this be covered by my 3 year Ford warranty???
catch
April 13, 2010, 5:14 pm
[quote name='Silver Fox' date='13 April 2010 - 11:09 PM' timestamp='1271195961' post='77750']
55k seems early for a clutch going, I've had clutches go on a Focus and a Mondeo, and both lasted circa 80K, but it depends on how the car has been driven. My mechanic has replaced a clutch twice for on old dear around 30k both times. She probably thinks he is fitting crap clutches, but the reality is she having eaten three clutches is obviously crap driver. But that said, if it were a worn clutch I would have thought the slipping would have been progressive, in that it would get worse over time, not just go like that in a day.
hawker
April 14, 2010, 2:57 am
I recently had to fit a new clutch and DMF. It was on 92K at the time.
When stopped, try putting the car in 4th and see if you can pull away. If you can then your clutch is slipping and is on its way out.
catch
April 14, 2010, 4:11 am
[quote name='hawker' date='14 April 2010 - 09:07 AM' timestamp='1271231829' post='77762']
I think you meant to say "cannot" not can.
I'd say put it in third, and progressively raise the revs. If you get to the point where the engine is revving it's @rse off but you ain't moving, you have a clutch related problem, but we already know that. If your car is a petrol model, ignore the reference to a DMF as it's not applicable in your case.
Yes I would say 90 to 100k on a clutch is about right. But if you share the car with your partner who has a tendency to ride the clutch in traffic congestion and the like, it's life expectancy will be shortened.
hawker
April 14, 2010, 5:13 am
[quote name='catch' date='14 April 2010 - 09:21 AM' timestamp='1271236266' post='77768']
no, i mean "can"
if you can pull away in 4th then I've always thought you got problems. It should stall shouldn't it?
catch
April 14, 2010, 6:39 am
[quote name='hawker' date='14 April 2010 - 11:23 AM' timestamp='1271240017' post='77773']
no, i mean "can"
Sorry mate I've been driving for 46 years and I can honestly say your wrong. I fact I just went and did it in the car, level surface and just get the balance between gas and clutch right and away you go. 34,393 miles on the clutch.......purrrrrrrrtect
Silver Fox
April 14, 2010, 6:48 am
Thanks for all the responses, this morning on my way to work, the clutch gave up completely, had to call the AA to be recovered!!! The car was an AA driving school car before I had it, so this could add to the excessive wear of the clutch?
hawker
April 14, 2010, 7:53 am
[quote name='catch' date='14 April 2010 - 11:49 AM' timestamp='1271245140' post='77786']
Ok, fair enough, but I've never been in a car that I could pull away in 4th from a stand. So maybe all the clutches were buggered!
Another method is to find a nice long straight road accelerate gradually upto 30 mph, stick it in top, be that 5th or 6th and floor the throttle to the stop, car will probably labour a bit and accelerate slowly revs climbing with speed. if clutch is knackered the revs will rise quickly for little or no acceleration. this will be testing the friction pads on the clutch tho
CAR PARTS EXPRESS
April 14, 2010, 8:00 am
I would say your clutch release assembly has been leaking causing a slip and pedal going soft then totally burst when you had to be recovered
catch
April 14, 2010, 12:04 pm
[quote name='hawker' date='14 April 2010 - 02:03 PM' timestamp='1271249627' post='77797']
Ok, fair enough, but I've never been in a car that I could pull away in 4th from a stand. So maybe all the clutches were buggered![/quote] could have been the case
[quote]Another method is to find a nice long straight road accelerate gradually upto 30 mph, stick it in top, be that 5th or 6th and floor the throttle to the stop, car will probably labour a bit and accelerate slowly revs climbing with speed. if clutch is knackered the revs will rise quickly for little or no acceleration. this will be testing the friction pads on the clutch tho
Yes that's spot on
AA driving school, sez it all really, I'm surprised they got 55k out of it. Mind you it could be on it's second clutch already.Not wanting to put a downer on it, but I would not touch a driving school car, but you don't always know that. Best motors are ex lease motors I reckon, they usually come with a complete service report. And if it's got high mileage it usually means it's done a lot of motorway miles, best of any miles a car can put on I'd say.
This car I have was 1st owner leased, in 10 months it covered 14,639 miles, 2nd owner had it 3 years 2 months, slept in a garage, and only did 18,070 in all that time.
Clutch Problem
