Full Version: Heater blower direction
penyffordd13
Hi all i hope someone can help.
I have a MK2 1998 LX Verona, and when i turn the blowers on the air is continuously direct to the windscreen vents. Doesnt matter which dial setting on for the direction, if i put it to blow on the floor it still blows on the windscreen. The car has aircon and it would be nice if i could get it to blow from somewhere else.
Thanks in advance
Jason
TheStig
[quote name='penyffordd13' post='2669' date='Aug 8 2008, 08:03 PM']Hi all i hope someone can help.
Thanks in advance
Jason[/quote]
sounds like the heater/blower control panel is knackered,i had sort of the same problem on my old mondeo,but mine would only blow to the floor,don't matter what i put the settings on,cannot say for sure thats whats wrong with yours. TheStig
penyffordd13
[quote name='TheStig' post='2670' date='Aug 8 2008, 08:14 PM']sounds like the heater/blower control panel is knackered,i had sort of the same problem on my old mondeo,but mine would only blow to the floor,don't matter what i put the settings on,cannot say for sure thats whats wrong with yours. TheStig[/quote]
And whats the damage for a new one of those and is it easy to fit?
TheStig
[quote name='penyffordd13' post='2671' date='Aug 8 2008, 08:24 PM']And whats the damage for a new one of those and is it easy to fit?[/quote]
£10-£15 on the internet for a good used one,loads of money for a new one from ford :rolleyes:
TheStig
ive still got my old mondeo,but not sure if the blower control is the same as yours? i think it is :)
penyffordd13
I have read on another mondeo group that it could be a blocked vaccuum pipe or something.....any ideas?
TheStig
[quote name='penyffordd13' post='2674' date='Aug 8 2008, 08:35 PM']I have read on another mondeo group that it could be a blocked vaccuum pipe or something.....any ideas?[/quote]
not sure really??does the fan speed and cold/hot knobs work?
penyffordd13
[quote name='TheStig' post='2675' date='Aug 8 2008, 08:40 PM']not sure really??does the fan speed and cold/hot knobs work?[/quote]
Yeah just the direction of the air flow doesnt work
TheStig
[quote name='penyffordd13' post='2676' date='Aug 8 2008, 08:49 PM']Yeah just the direction of the air flow doesnt work[/quote]
90% sure its the blower control,£5 on eay cannot go wrong,worth a try?
penyffordd13
Yeah its worth it but i am going to do a little more digging first. But thanks for your help anyway!!!!
TheStig
[quote name='penyffordd13' post='2678' date='Aug 8 2008, 09:05 PM']Yeah its worth it but i am going to do a little more digging first. But thanks for your help anyway!!!![/quote]
no problem mate anytime :)
check that the main vacume pipe is not pushed on to far at the bulkhead as this has the same effect as the pipe being blocked also check the pollen filter as restricted airflow will cause the system not to alter direction
penyffordd13
[quote name='mintalkin' post='2691' date='Aug 9 2008, 02:01 PM']check that the main vacume pipe is not pushed on to far at the bulkhead as this has the same effect as the pipe being blocked also check the pollen filter as restricted airflow will cause the system not to alter direction[/quote]
Excuse my ignorence but can you tell me esactly where those items are please?
vacume pipe is black and on the back of the toggle switch
Where is the pollen filter?
centre - passenger side under plastic cover at the base of the windscreen
Time to change - approx. 10 minutes
How Easy to change - moderate
Tools Needed?
torx key or torx screwbit
Fitting Stage 1:-
The filter is under the plastic cover at the base of the windscreen on the passengers side. Remove screw caps from the that are accessible with the bonnet down. Then remove the screws underneath.
Fitting Stage 2:-
Open bonnet and remove the screws along the bottom edge of the cover. Peel away rubber strip along the front edge of the cover. Gently lift off the plastic cover, taking care not to break it.
Fitting Stage 3:-
The old filter should now be clearly visible in its holder. The plastic filter holder is retained by a spring clip at the base of each end. Unclip these then lift out the filter and holder.
penyffordd13
[quote name='mintalkin' post='2709' date='Aug 10 2008, 05:11 AM']vacume pipe is black and on the back of the toggle switch
Tools Needed?
Fitting Stage 1:-
Fitting Stage 2:-
Fitting Stage 3:-
The old filter should now be clearly visible in its holder. The plastic filter holder is retained by a spring clip at the base of each end. Unclip these then lift out the filter and holder.[/quote]
I removed the pollen filter and it was full of crap. I will get a new one on Monday. Just as a test tho...i went into the car while the pollen filter was removed and checked to see if the blowers would change direction with no obstruction where the pollen filter was........but still no change....just blowing onto the screen. I have the HAynes workshop manual arriving this week then i will look how to remove the centre console around the switches to check those. If everything is ok is it worth buying a second hand switch from Ebay or alike?
Sharky
Hi there it will be a cable or a resister on the back of the controls
sharky
Full Colour Version: Heater blower direction
