Full Version: Low Revs
focash mk1
hi there, i have an issue with my focus and wondered if any1 cld shed any light on the problem, once my car is up to runnin temp and runnin smoothly the revs idle too low. i havent had it looked at yet or anything but was hoping some1 wld hace an idea what it cld be. im thinking maybe a sensor but im only guesin.
any help wld be greatly apreciated thank u
Ash
vehicle spec: focus mk1 'x' reg 2000 model 1.6l ghia
[quote name='focash mk1' date='29 April 2010 - 10:37 PM' timestamp='1272576464' post='79995']
Ash
how low are we talking here? i have had issues with the low idling in the past but for now im doing ok and ive not even done anything to it lately. mine was worse when it was cold outside and the engine was at running temperature, not too bad at the moment with the slightly warmer weather.
focash mk1
[quote name='stef123' date='29 April 2010 - 11:29 PM' timestamp='1272583198' post='80016']
Yer mine is similar to that really sometimes its better than others but i can't say it ever really goes away completely. Its idles roughly 850
[quote name='focash mk1' date='30 April 2010 - 01:38 PM' timestamp='1272630484' post='80074']
consideing it sld idle at 700=/-30rpm 850 is high and you wont get it idling higher check youre manual the correct idle is 700=-30 so between 670 and 730 rpm is normal sso you have summat wrong that its idling rough when its actually idling high coil pack idle control valve pcv valve or a sensor the focus will also hunt when idling as the ecu constantly is monitoring the fuel and air and looking for the lowest emissions so it will constantly vary
focash mk1
[quote name='artscot79' date='30 April 2010 - 04:02 PM' timestamp='1272642747' post='80104']
thats interestin to no thanx m8, ill ave to look into it further then, double check the actual idle revs then if still high ill consider valve or sensor,
thanx again
Full Colour Version: Low Revs
