Full Version: Misfire Cylinder 1 - Worth The Repair Costs?
Mark P
I have a 2004 1.3 KA Collection which has done 48,500 miles. It was recently due an MOT and service and in the week or so before it developed a problem whereby the car starts to judder on slowing or braking as though the engine is about to stall. This fault is particularly prevalent when approaching a junction and in 4th gear. The "solution" is putting the clutch down way too early, but this is a bad driving habit as it is effectively coasting especially if 'off gas' before braking, say slowing from 30 mph to 20 mph.
It has always had an intermittent misfire which was picked up on its first service, but it was decided that it wasn't clear what the problem was. It has only ever been serviced and repaired by Evans Halshaw service in Old Trafford which is where I purchased the car (29,000 miles 3 years old).
The 'misfire' has now got so bad that it failed its emissions test. The plugs have been replaced, but the leads are, apparently, fine and a new coil pack was tried and there was no change. Now the plugs have been changed it has now passed its MOT, but the misfire is still there. Evans Halshaw insist that it is only 'slight' - which is nonsense - it is easily as bad as it was before I took it in. They also insist that they would charge 500 in labour to investigate further as this is what it would cost to examine the 'lack of compression' fault in Cylinder 1.
I suppose what I'm asking is for a second opinion before I approach another garage. Is this a common problem? Are EH covering something up? Could another mechanic look at this and fix it reasonably. I already spent 500 just on getting it through the MOT (there were other problems with bushes which have been sorted), so could another garage do it for say 200. At the end of the day, it is annoying to drive with this fault, and any buyer would notice it immediately
Advice please.
[quote name='Mark P' date='05 May 2010 - 07:44 PM' timestamp='1273084444' post='80854']
Advice please.
it could be a temperature sensor it could also be a lambda sensor ide advise ford l;ook at it as they can do a live diagnostic to find out what it is and if there are any fault codes it would be less than 500 quid it would be worth the 70 quid to have diagnostics done by ford see what thy say and go from there
Mark P
[quote name='artscot79' date='05 May 2010 - 07:51 PM' timestamp='1273088469' post='80874']
I will try another Ford engineer then. Evans Halshaw Service is supposed to be a Ford service centre, but they don't seem much cop to me. I would have thought that they had already run such a test.
