Full Version: ! Guide ! Mk7 Fiesta Bulb Change
Ford Owners Club - Ford Forums > Ford Models > Ford Fiesta Club > Ford Fiesta Guides
Pages: 1, 2, 3
Rogue_Shadow
Hey FOC
About time I pulled my weight around here, So I thought Id make an English guide of how to upgrade/replace the MK7 Fiesta bulbs.
[size="4"][u][b]Covered in this guide:[/b][/u][/size]
[b]# MK7 bulb types
# How to remove the MK7 Headlight (Including pictures of the dreaded retaining Clip MWHAHAHAHAHAHAH ... pfft )
# How to Change over the MK7's sidelight, dipped beam & Indicator bulbs
# How to Safely replace the MK7 Headlight back into the mounting[/b]
[size="4"][u][b]MK7 Bulb Types[/b][/u][/size]
Here is a brief list of the Bulbs for the MK7 Fiesta, these are also noted in your handbook.
Front Lights:
Fullbeam - H1
Dipped beam - H7
Sidelights - W5W
Front Fogs - H11
Front indicators - PY21W
Side (wing mirror) indicators - WY5W
Interior lights:
Interior light - W6W
Reading lights - W5W
Footwell lights - W5W
Rear indicators - PY21W
Brake & tail light's - P21/5W
Rear fog light - P21W
Reversing lights - W16W
Number plate lights - W5W[/b]
[size="4"][u][b]Removing The Headlight:[/b][/u][/size]
To Replace ANY bulbs in the headlight, the headlight itself must first be removed.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo431.jpg?t=1273328149[/img]
The Headlight is fixed to the car by 2 bolts, 1 plastic rivet & 1 clip at the bottom (More on this later)
One bolt at the top of the headlight -
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo433.jpg?t=1273328181[/img]
One bolt & a Rivet at the bottom of the headlight -
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo432.jpg?t=1273328208[/img]
The bolts simple unscrew, store the washer and bolt some where safe. The rivet comes in two parts, both simple pop out and do not require any other motion. There is a small gap that allows you to get your finger nail or screw driver underneath the first part and pull it out.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo436.jpg?t=1273328235[/img]
After the first is removed, the bottom part pops out also
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo437.jpg?t=1273328308[/img]
Before removing the headlight, you need to remove the electrical connector (The purple plug)
The best method to remove this, is to prize a flat head screw driver in and underneath the clip & tilt.
You will hear a small click & with the screwdriver still in place the connector can be removed.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo434.jpg?t=1273328375[/img]
[u]DO NOT[/u] pull the connector from the wires, the connector should come out fairly easily with the screw driver in place.
I removed mine with thumb and fingers of my left hand ... very little struggle at all.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo435.jpg?t=1273328402[/img]
The Headlight is anchored in with little tabs on the headlight itself
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo464.jpg?t=1273328445[/img]
So the best method to remove the headlight is to tilt the headlight slightly away from the engine bay and then pull the headlight up and towards the windscreen.
Place one hand underneath the headlight nearest the bottom (grill) and another underneath the top section where the first bolt was removed. Keep reading if you need more help.
Rogue_Shadow
[size="4"][u][b]Headlight removal - explained[/b][/u][/size]
This is the clip that everyone mentions and dreads, that comes out in the darkness of night and...yada yada ha ha. Its not that bad once you look at it. So here it is
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo438.jpg?t=1273328561[/img]
Its basically a bigger version of the clip that holds your bonnet arm.
Here is is again with the headlight removed - Don't worry I'll get to the removal part, you haven't missed anything.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo439.jpg?t=1273328596[/img]
This picture (below) will hopefully explain the necessary angle needed to lift the light.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo439e.jpg?t=1273328647[/img]
The Yellow Arrow is the direction the clip would most likely to be removed at
HOWEVER, not possible if you look at the green circle, the shape of the grill and headlight DO NOT allow the direction.
The Red arrow is a compromise of both, its at an angle that clears the shape of the grill but still provides enough upwards angle to remove the the light from the clip. I had no trouble removing mine without this guide. No snaps or damage. Provided its not a Freezing cold day causing the clip to be abit more brittle, you should be fine.
Once free, unslot your headlight from the mounting. It would be fairly simple. But for those who want to know how.
Slide it from the top out. Away from the front grill.
[size="4"][u][b]Bulb Replacement: [/b][/u][/size]
Your headlight is now out of the car, looks odd doesn't it lol.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo440.jpg?t=1273328721[/img]
Incase by this point you still have no idea what bulbs you need, ford kindly printed them on the headlight
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo442.jpg?t=1273328803[/img]
These are my replacements
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo441.jpg?t=1273328831[/img]
Philips Silver Vision indicator bulbs and Philips Bluevision (dipped beam with sidelights...bargin B))
Ok Indicator bulbs and sidelights first, flip the headlight over and you'll see a screwcap, turn anti clock wise to open
For those who are unsure of their lefts and rights. Its printed on the cap
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo444.jpg?t=1273328865[/img]
Unscrew that...
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo445.jpg?t=1273328929[/img]
looks confusing doesn't it?
Lets Have a closer look inside
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo448.jpg?t=1273328957[/img]
On the right is the sidelight, notice how ford are kind enough to even print the bulb types on the inside of the headlight.
To the left of the sidelight is the Main Beam (Blinding people light) I don't remove this during this guide. looks simple enough though
TBC...
Rogue_Shadow
Ok
To remove the sidelight bulb holder ( the one underneath W5W on the above picture) Turn the plastic holder a quarter of a turn and pull up and out. Simple
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo449.jpg?t=1273329071[/img]
To remove the bulb, simply pull it out. Time to install your new bulb.
This IS Important, [u][b]DO NOT[/b][/u] handle the glass of the bulb. Use vinyl or latex gloves or tissue paper. Handling the glass directly can damage and or reduce the bulbs lifetime.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo450.jpg?t=1273329096[/img]
No you can put the holder back into the headlight, quarter of a turn and leave it be.
Time for the indicator bulb ... this one IS a pain, but I'll give as much detail as I can.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo451.jpg?t=1273329126[/img]
Below the sidelight bulb is the indicator bulb, all you can see of it is the wires and a Long handle/stalk connected to the bulb holder.
This one is very stiff to remove, luckily this was my second headlight.
To remove, you need to get nice and low on the handle/stalk (don't hold the wires!)and apply a very very very small amount of pressure towards the holder, then turn it anti-clockwise.
This holder is very stiff, when it becomes free it does make a loud Click noise that sounds expensive ha ha. But its fine. you'll see why its so stiff once its out.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo453.jpg?t=1273329153[/img]
The holder and the headlight have tabs that lock it in. Hence why it was so stiff. Have a good look at both the headlight and the bulb holder, these will help you understand how to fit it back in
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo454.jpg?t=1273329176[/img]
Notice the tabs on the out edge of the holder, these need to be lined up with the headlight to slot back in.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo452.jpg?t=1273329222[/img]
This is the indicator bulb, to remove it, one turn anti-clockwise... while not handling the glass. There is ONE way the bulb will fit into the holder again. Line up the notches on the bulb with the gaps on the holder. Slot in and turn clockwise. Done
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo455.jpg?t=1273329288[/img]
Now line up the tabs of the holder with the headlight and put it back in the headlight. This is abit fiddle. Take your time, line up the plastic tabs and you'll feel it go into the headlight. Then its one turn clockwise the lock it in place and seal the deal.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo456.jpg?t=1273329309[/img]
Close the screw cap up and your down with this section of the light. Now for the dipped beams.
The bulbs are behind this rubber cap at the end of the headlight
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo457.jpg?t=1273329337[/img]
It just peels of the expose the bulb
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo458.jpg?t=1273329359[/img]
Rogue_Shadow
Again with Thumb and finger pressure on the side of the bulb holder, turn it anti-clockwise and it will unlock and pull out.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo459.jpg?t=1273329475[/img]
With the bulb holder free, you can remove the bulb. This bulb is removed by pulling it out, I'll show you what part pulls away from what.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo460.jpg?t=1273329512[/img]
If that's still unclear what pull away from what, read on. It may become more clear as we install the new bulb.
When inserting your new bulb, there is only one way it will fit into the holder.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo461.jpg?t=1273329550[/img]
Notice the small metal leg sticking out and up (like an L) of the bulb holder. That side of the holder needs to meet with the part sticking out of the bulbs base.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo462.jpg?t=1273329570[/img]
Like so
Insert the bulb into the headlight, one turn clockwise and your done. replace the rubber seal & you have successfully de-tangoed and upgraded your headlight ...
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo463.jpg?t=1273329606[/img]
Finished! Enjoy ...
Rogue_Shadow
[size="5"][b]What sort of guide wouldn't help you put the headlight back in? Honestly people! Grab your headlight lets go ...
[/b][/size]
[size="4"][u][b]
Replacing the headlight back into the mounting:[/b][/u][/size]
Meanwhile at your car lol.
[b]FIRST![/b]
Plug the connector back in and ensure the lights are working! Do not do anything else untill you have otherwise you'll be scrolling all the way back to the top of this guide...bad times.
All working? Are you now blinded by the pure brilliance ... Odds are no, its still daylight ha ha
Anyway ...
So remember the little plastic tabs on the headlight
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo464.jpg?t=1273329829[/img]
Those will play a key part in making this part SO So Simple.
Insert the bottom (narrow) part of your headlight into the mounting first. After all it was this part that made it hard removing it in the first place.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo465.jpg?t=1273329875[/img]
With the headlight in place at the bottom (ensure the plates for the bolt and rivet are UNDER the grill and not ontop)
tilt the headlight and work on getting those plastic tabs into under the bodywork
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo466.jpg?t=1273329894[/img]
During this step, odds are you will head the plastic clip at the bottom of the headlight clip into place and the headlight will fit snug. If this hasn't happened, have a good place around. Don't worry, there is only One way for the headlight to sit correctly and multiple ways to get it there.
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo467.jpg?t=1273329923[/img]
Insert the bottom part of the rivet
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo468.jpg?t=1273329941[/img]
Followed by the top part
Replace the other two bolts and washer, reconnect the connector at the back of the headlight. Close the bonnet and marvel the fact your indicator isn't orange
[img]http://i660.photobucket.com/albums/uu324/Rogue-_-Shadow/Wesley/Bulb%20Guide/Photo469.jpg?t=1273329966[/img]
Now... we wait for the darkness to fall
Result to follow
Hope this has helped or given confidence to those wanting to give it a go.
Rogue Shadow
Rogue_Shadow
[size="7"][size="5"]Space reserved for results
I Shall Take pictures tonight to show off the results
B)[/size][/size]
Update:
The bulbs are brilliant!
My camera phone however is not. So I will need to borrow a decent camera to complete this.
I was also worried that the Full beam would look odd seeing as I didn't upgrade the main beam bulb. Not the case, looks awesome!
Went with a drive my a mate to confirm that it wasn't blinding either.
Pass
Will update asap - Need a decent camera
dannyhilton
If only I had the smart you do fella, your guide would have saved me hours! Top idea too. What lights did you go for and are you happy with the results?
Rogue_Shadow
[quote name='dannyhilton' date='08 May 2010 - 03:10 PM' timestamp='1273330824' post='81194']
Sorry Danny
You post got lost as I was uploading the rest of the guide :lol:
I'll post back the result tonight, so you can judge for yourself the results.
I completely forgot to take before shots. But I'm pretty sure I'll be impressed with the results.
The bulbs I decided on are on one of the pictures above.
But these are the bulbs I got. I purchased them from those sites also and they came with 2-3 days :D
[url="http://www.carbulbsdirect.com/product_detail.asp?prod=25"]Dipped beam:[/url]
[url="http://www.carbulbsdirect.com/product_detail.asp?prod=31"]Sidelights (Included with the dimmed beam bulbs)[/url]
[url="http://cgi.ebay.co.uk/PHILIPS-SILVERVISION-PY21W-OFFSET-PIN-INDICATOR-BULB-/310125709323"]Indicator bulbs[/url]
182_blue
Brilliant guide, i tried to change to silvervisions on both the front and back lights but i abandoned both tbh LOL
Rogue_Shadow
[quote name='182_blue' date='08 May 2010 - 03:45 PM' timestamp='1273332955' post='81201']
Hopefully this guide will help you out mate,
Dead easy on the front
Not going to bother else where :D
Steve
stickied and I will place it in the how-to guide when we launch it :)
Rogue_Shadow
Thank You Steve :)
stevie j
A realy exellent guide fella well done think i will will have a go now :D
Strutter
And not that long ago you were asking us about it lol.
Going to be ordering a batch of bulbs this week, just have the indicators to do, but was wanting a cold
blue for the main bulb, have one of my own in it already but like the blue tint on the White.
Might even looking into the interor main, mirror indicators and rears.
Great guide an well put together, I'm sure many will come to appreciate it!
AndrewL
What an excellent guide. Infact, I'm going to order the bulbs when I get home! :D
Matt.ZS
Couldn't fault the guide there, explained it perfectly and it only took me 20 minutes, thanks alot.
sussex
What about aligning the dipped beam once the new bulbs are in? Will it be out? and how easy is that to sort?
Rogue_Shadow
Hey Everyone, sorry had laptop trouble
Glad the guide is useful & clear :)
I will try and get the pictures of the new bulbs ASAP, I just need to get my hands on a decent camera for the night shots.
They are LOADS better than standard, that is unarguable.
They look great and light up the road ahead cleaner than the old yellows
The bulbs don't need to be aligned, its not required.
Just plug & Play :D
If I've missed anything else out, feel free to post it up.
I'll check back to answer any questions or worries whenever I can
Strutter
Yep, completly useless and very clear lol.
Rogue_Shadow
[quote name='Strutter' date='15 May 2010 - 11:52 AM' timestamp='1273920163' post='82006']
Shhhhh *Edit* :lol:
Strider
Hi everyone
Whilst on the subject of mk7 headlamps ,does anyone know if there is a way to convert the dip beam for driving on the continent ???
Heres HOPING someone can HELP ,Thanx in advance
oobster
Anyone know how to get the mirror covers off to do the side indicator bulbs?
Adam1982
Really helpful, easily changed the bulbs with the guide, thanks
wozza89
I've just this minute fitted new headlight bulbs to my car, I went for 5k headlights, 55W and silver indicators.
It took me around 1 hour and a half, which I think it could be done much quicker I just took my time :)
Although this is one of the most fiddly things i've ever done! The H1 bulb has to be the most un-user friendly design ever, the metal clip which you have to reach down and grab after you've put the bulb in, is a right pain in the arse!
Why are they making it so hard for people to change bulbs these days? To make more money.... i presume, no wonder you see alot of people driving around with just the one headlight working
I'm happy with the results though! :)
Strutter
...that normal bulbs where fine...I nearly crippled myself changing the indicators!
Kasper-N
Going outside now to change my dipped beam bulbs with a pair of Osram Night Breakers. :D Thanks for the guide!
Beermonster
I've just noticed I have a break light out, is this easy to change? I've looked on the forum but can't seem to find any info on how to do it.
Cortexx
You have to pull the carpet away in the boot to get to a weird bolt which releases the cluster Beermonster, they are a nightmare lol
Beermonster
Thanks I managed to do it, well sort of I got Halfords to do it for me, and they forgot to charge :)
I know how to do it next time
coralreefuk
[quote name='stevie j' timestamp='1273357263' post='81277']
Hi Stevie j,can you tell me where you got your carbon grill from it looks sweet!
Cheers Andy
Liverpool-S
For the interiour main light, i.e in the headliner when the doors open you say it is a W6W?
I cannot seem to find a W6W bulbs, did you mean a H6W mate ?
B14TCH
cheers guys :-))) will give it go today wish me luck lol
rickycowslip
you say this is required for ALL bulbs, yet I've just managed to change both H7 dipped bulbs without the need to remove the whole unit - merely prized off the rubber covers and twisted out the holders. Yes its fiddly, and removing the fuse cover makes it slightly easier, but once you've done it once its an under-a-minute job... I will be using your handy guide to change the side lights though, fancy blue ones came free with the headlamps...
Rogue_Shadow
If you have tiny hands like mine, yes you don't need to remove the whole unit. However its alot easier, less chance of touching the glass of each bulb during replacement (reduce bulb lifespan) & guaranteeing a secure fit. :huh:
Regardless,
Glad people are making use of the guide :)
mrkemery
Magic guide,
But can you tell me how to replace the off side front fog light unit please it got stoned the other day. 54.00 inc vat :) cant change just the lens, never mind hey.xxx
noulzy
[quote name='Rogue_Shadow' timestamp='1301435727' post='120712']
Regardless,
Hi Rogue, wonderful guide!! Would not have the patience to do that (well maybe I would) I added some led strips under my headlamp units (LOOKS AWESOME!!! I will post pictures next)
I was wondering... I asked some local dealer (Mauritius) to change my headlight and full bulbs, but I was a bit scared of using counterfeit parts (very common here) and we actually changed them and tested first without reconnecting... and they started smelling like burnt plastic, so I reoved it. Do you reckon the Philips 55W blue vision are perfect for this? That's the ones you installed right?
And also is there a guide for the back lamps?
Rogue_Shadow
[quote name='noulzy' timestamp='1303881385' post='124511']
Thank You :D
Shouldn't smell of burning plastic, that's for sure. I've not had any trouble with my bulbs (headlights or sides) since installing them along time ago. So the 55's in my opinion are perfect.
I haven't changed anything else on my ZS so I haven't looks at any other bulb replacements :unsure:
I know that other members have changed Every single bulb on the fiesta, so if you search the forum you should come up with someone with knowledge.
Or if your reading this and you have changed those bulbs like the fogs and rear lights feel free to add some photo's/ instructions or make your own guide
I know that the rear lights are quite fiddly to change, pulling down the carpet and unscrewing it from the hold or something.
100_times
I'm looking at replacing my footwell lights with these:
http://cgi.ebay.co.uk/2-X-501-W5W-WIDE-ANGLE-1-RED-LED-BULBS-HID-XENON-LOOK-/120598355405?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1438ddcd
First off, are these the correct bulbs? Also, opinions?
Rogue_Shadow
[quote name='100_times' timestamp='1305378047' post='127246']
Yep
Footwell lighting bulbs are the same as Front Sidelights
Tato
[quote name='Rogue_Shadow' timestamp='1305584267' post='127605']
Yep
Hi mate, could you post some pictures with the results (night)?
ford=win
great guide very useful, thanks
i was thinking the front bumper had to come off until i read this
Rogue_Shadow
[quote name='Tato' timestamp='1305877157' post='128110']
I'll take some night photos of my Footwell lights as soon As I get a chance mate
ROB S140
i keep seeing people with blue light but i dnt seem to find some good ones what would you recomend as they look realy nice.
ROB S140
[quote name='Liverpool-S' timestamp='1295793144' post='110892']
ROB S140
were did you get your lights from mate as i want some they look good.
jonny_sutton
how do you get the main lights out ? taken rubber seal of got the bulb holder out just dont no how to get the bulb out of the holder ?
many thanks
MRC89
Hold it with a tissue and you have to twist quite hard iirc
jonny_sutton
okay ill give it a try cheers
ONETrueSaturday
Thanks for the guide mate, helped me alot!! ;)
figs122uk
This helped alot, but saying that - its very simple too do once having a scan through the guide (y)
thank you
