stayfocused
May 13, 2010, 2:15 pm
Hi all,
Has anyone had a problem with their ford focus each time they fill it up, it leaks from the breather pipe.
Call supply photo
May 13, 2010, 4:34 pm
[quote name='stayfocused' date='13 May 2010 - 08:25 PM' timestamp='1273778158' post='81892']
Hi all,
Call supply photo
ill assume if its leaking you have overfilled it?
May 13, 2010, 6:27 pm
are you sure its the breather and not the filler pipe? the filler pipes are crap for leaking
mnevis
July 14, 2010, 9:37 am
[quote name='stef123' date='14 May 2010 - 12:37 AM' timestamp='1273793257' post='81910']
I have the same problem with my 1998 1.8 petrol 5-door Zetec Focus, the breather pipe has been replaced. What is the solution to the filler pipes leaking? What needs replacing? Is it a difficult job? What has to be removed to get at the pipes? Can you gain access from the boot? If it is a common problem how come there is hardly any information on here about it?
mnevis
July 14, 2010, 10:06 am
To add to the above, are the filler pipes made of metal or rubber?
Mr R.E.Tard
November 12, 2010, 3:18 pm
My Mk1 1.8 Zetec fuel filler pipe has corroded fru and is leaking. what is involved in replacing the pipe. does the back axle need to be removed to fit it? any ideas any body?
dezwez
November 13, 2010, 12:46 pm
[quote name='mnevis' timestamp='1279119983' post='88335']
plastic
Mr R.E.Tard
November 18, 2010, 6:39 pm
metal
Fuel Leak
