Full Version: Eggy Smell
mcouchard
Hi my second thread today.
When I put the cabin fans on either with of without A/C it gives a pungent eggy smell any ideas. I'm hoping to sell the car asap and so this kind of needs sorting. I replaced the cabin/pollen filter only a year ago so it can't be that dirty yet, I noticed the smell after washing the car and wonder if it could be water ingress?
Any thoughts would be very helpful,
Thanks, Matthew
hawker
I would still say its the A/C.
You can get A/C cleaners quite cheaply. Its worth giving one a go.
cyb
As above it is probably the air con system needing a good clean, use something like this from Halfords...
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_224996_langId_-1_categoryId_165632
mcouchard
[quote name='cyb' date='21 May 2010 - 01:32 PM' timestamp='1274444523' post='82752']
Thanks I ordered some generic A/C cleaner off Amazon, will see how it goes.
cn be caused by a build up of moisture in the pipes vw had a system where it automatically blew the pipes through to prevent this not sure if the ford does the condensation like a fridge if not cleaned causes the bacteria especially in warm weather toi build upo causing that smell youre getting most of these in car ones dont usually work getting it drained flushed and cleaned then refilled is best as it clears all the insides out
adz01
Hi Matey,
Its definately your air con, alot of people say they get an eggy or farm yard smell in the cabin when either the heater (on cold) or air con is on.
[u][b][size="4"]What causes this?[/size][/b][/u]
well when you use air con, a few people will put it on recycle as the air con is less harsh, for example when i have the air con on (with recycle off) it gives me headaches, this is because its so cold, air con removes the moisture from the air by compressing it, hence the coldness.
now when your aircon has been run on recycle, even once, bacteria from when you breath is put back into the system, this then grows and bacteria when concentrated will start to smell, hence the smell of eggs or farmyard.
air con cleaner is a fix, but a temporary one.
there are 2 things to do to ensure this doesn't come back.
have your air con drained and re filled and have your filter replaced (as the filter most certainly will contain bacteria spores.
£40-60 is what you'd be looking to pay for a re-gas and another £10 for a filter if fitted yourself. if sent into a garage or fords it will cost you more say £20-25, but at fords the cost could be much higher, its not a specialist thing so any garage can do it for you.
hope this helps :)
Adz
Full Colour Version: Eggy Smell
