I am wanting to fit a towbar which looks simple enough but am confused about the electrics.
From one of the ads it asks a question:
Do I need a bypass relay kit?
Vehicles fitted with bulb failure devices or cam bus systems and LED systems will require a bypass relay kit. A 7 way bypass is designed for vehicles which have Multi-plex wiring, Cambus systems or Bulb Failure devices which where introduced around the year 2000. This bypass prevents any faults on the towing vehicle's light system by switching power directly from the vehicle's battery/alternator to the trailer/caravan light system, using very small signals from the vehicle's light system, without the vehicles check control sensors system being adversely affected. If your vehicle has none of these you will not require a bypass relay kit. Please call us if you need clarification.
My focus is a 51 plate 2002 diesel 1753 engine estate
How ca i tell if it has or has not the above?
