sparky19620
May 31, 2010, 2:00 am
hi guy's
i took the car for a drive on friday and at 2500 revs i started to her what sounds like a rush of air from where i cannot pin point.its on the drivers side and only starts at 2500 revs and is there in every gear by the way.have driven to work this morning and noticed it was surging a little at around 75 -80 mph.i also noticed a bit of smoke from rear window that have never noticed before.if i stay below 2500 revs all seems ok..any ideas..?
May 31, 2010, 8:48 am
it could be the intercooler pipe from the egr valve(big pipe on the bottom)that has a split in it, this would give you the air escaping sound and black smoke.its a common fault on the tdci.
sparky19620
May 31, 2010, 10:11 am
thanks for that found the hose split..easy enough to change to..cleaned egr as was just slightly dirty...just curious why do some block off the egr and what do they get by doing it
tdci stevie
June 1, 2010, 3:36 am
[quote name='sparky19620' date='31 May 2010 - 04:21 PM' timestamp='1275318669' post='83757']
Better performance have done it on my 04 TDCi 130, and its more responsive and less smokey when you floor it, i also had the split pipe must be a common fault on these engines, £55 plus v.a.t bloody expensive for a rubber pipe
June 1, 2010, 7:21 am
you can block an egr on a eoro 3 engine with no problems, but on the euro 4 engine it will put the eml light on after around 100 miles,if your egr has electrical connections on it,its a euro 4.
sparky19620
June 1, 2010, 12:23 pm
just checked and no electrical connection on the egr,do i have to have anything done after blanking egr off...am new to all this...but learning quickly
tdci stevie
June 1, 2010, 12:31 pm
[quote name='sparky19620' date='01 June 2010 - 06:33 PM' timestamp='1275413036' post='83883']
No just blank it off and stick a ball bearing or plastic bead in the small vaccum pipe that goes in top of EGR and your away mate
sparky19620
June 1, 2010, 1:09 pm
cheers mate will give it a go and see what happens
willsh
June 4, 2010, 12:02 pm
so if you have the connecter and plug on your egr you cant blank it off
June 4, 2010, 4:51 pm
as said before you can blank it off but it will put eml light on at around 100 miles later due to 'egr lack of air flow'
